24th August 2009, 12:38 | #4521 | Link |
Megui bugreport (version 1053).
There is a bug in Video preview window at AVS script creator: 1. Press '+' to zoom preview to 2x 2. Press 1x to return preview to normal size. 3. Now if I press again + it scales to 3x, nor 2x! Now if I press 1x and '+' again it zoom to 4x! Seems like button 1x does not reset zoom variable. |
24th August 2009, 13:24 | #4522 | Link |
Yep, exactly ... Little patch to fix this bug :
Index: gui/VideoPlayer.cs =================================================================== --- gui/VideoPlayer.cs (révision 1344) +++ gui/VideoPlayer.cs (copie de travail) @@ -240,7 +240,8 @@ /// <param name="e"></param> void originalSizeButton_Click(object sender, EventArgs e) { - resize((int)file.Info.Width, showPAR.Checked); + zoomWidth = (int)file.Info.Width; + resize(zoomWidth, showPAR.Checked); } private void zoomInButton_Click(object sender, EventArgs e) { Code:
Index: MeGUI.csproj =================================================================== --- MeGUI.csproj (révision 1344) +++ MeGUI.csproj (copie de travail) @@ -834,11 +834,6 @@ <Compile Include="AssemblyInfo.cs"> <SubType>Code</SubType> </Compile> - <Compile Include="Properties\Resources.Designer.cs"> - <AutoGen>True</AutoGen> - <DesignTime>True</DesignTime> - <DependentUpon>Resources.resx</DependentUpon> - </Compile> <Compile Include="Properties\Settings.Designer.cs"> <AutoGen>True</AutoGen> <DesignTimeSharedInput>True</DesignTimeSharedInput> @@ -1111,11 +1106,6 @@ </EmbeddedResource> <EmbeddedResource Include="pause.ico" /> <EmbeddedResource Include="play.ico" /> - <EmbeddedResource Include="Properties\Resources.resx"> - <Generator>ResXFileCodeGenerator</Generator> - <LastGenOutput>Resources.Designer.cs</LastGenOutput> - <SubType>Designer</SubType> - </EmbeddedResource> </ItemGroup> <ItemGroup> <None Include="app.config" /> |
1st September 2009, 09:21 | #4523 | Link |
Constantly learning
This might seem like an extraneous request but would it be possible to get the font in the status window darker? There are many times when I have difficulty reading it. Like I said it might seem extraneous but even people peeping at my pc while it's encoding have had difficulty seeing the time remaining and such. This is but a small request and I understand if other things are given priority, especially since you're doing this stuff for free.
I guess it says something about your work when requests are fixing small errors in zooming and being asked for a darker font in a specific window |
1st September 2009, 11:21 | #4525 | Link | |
http://forum.doom9.org/showthread.ph...32#post1213232 make sure to read all the follow-up posts. I even suggested a fix. Jawed |
1st September 2009, 11:49 | #4526 | Link |
It uses WinAPI standard controls/values used by thousands of applications, the problem is your LCD or your configuration. RipBot264 has serious issues regarding unreadable stuff, maybe it assumes a large resolution which I don't have.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 1st September 2009 at 11:54. |
1st September 2009, 11:56 | #4527 | Link |
MeGUI uses standard controls in a non-standard way.
Windows has a concept of "make a control hard to read to indicate to the user that this information is irrelevant". This is being misused in this case, because the information being shown is highly relevant. Jawed |
1st September 2009, 11:58 | #4528 | Link | |
1st September 2009, 12:16 | #4529 | Link | ||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 1st September 2009 at 12:23. |
1st September 2009, 12:29 | #4530 | Link |
Greyed-out text, deliberately defined by Microsoft to indicate that the text is not meant to be read, should never ever ever be used by an application for text that is meant to be read.
It's irrelevant how readable any developer thinks it is, the UI specifically reserves greyed-out text for text that is not meant to be read. Jawed |
1st September 2009, 12:39 | #4532 | Link |
It seems MeGUI don't use just readonly text boxes since readonly text boxes have black and not grey text, I'm confused.
edit (overlap): maybe it's grey because of the flatstyle used?
1st September 2009, 12:43 | #4533 | Link |
As I already explained before, that's because you are using the wrong kind of control. You should be using a label.
A text box is a kind of control used for entering data. A label is a kind of control for showing data. A label can never be edited by the user. That's why, by default, a text box is accompanied automatically by a label control (when added to a form), which the developer uses to put a description of the function of the text box. The text in this label can not be edited by the user, so does not need locking, and is therefore highly readable. Jawed |
1st September 2009, 12:44 | #4534 | Link | |
Swallowed in the Sea
1st September 2009, 12:48 | #4535 | Link |
Ah, it's disabled, I agree then text should be black like in VirtualDub, DGIndex, StaxRip etc.
1st September 2009, 13:27 | #4537 | Link |
Actually, I agree. In the end, they are used as status indicators, which purpose are to be kept visible. You can think about any kind of status indicators, the most known perhaps the installation progress windows of the main windows installers, they aren't greyed, because the user wants the see the progress at any time it is running, so for me, these should not be greyed out, after all the MeGui status windows do run for hours and hours and especially then, users are interested in taking a keep once in a while how far the process is.
So my conclusion : Better readability, the first shot is better, regarding the Time indicators, these are (for most) the most important parts, so bolding them wouldn't be a bad idea either. |
1st September 2009, 13:30 | #4538 | Link |
@Kurtnoise
Read only text boxes allow focus, text selection etc., I think it's OK but not perfect. Better would be using a label and apply border style using WinAPI overriding CreateParams or using ControlPaint class to paint a border. Maybe there are easier solutions.
1st September 2009, 15:40 | #4540 | Link |
If you want to prevent focus/selection a easy solution is using labels and drawing a border:
Private Sub TestForm_Paint(ByVal sender As Object, ByVal e As PaintEventArgs) Handles Me.Paint For Each i In New Label() {Label1, Label2} Dim r = i.Bounds r.Inflate(1, 1) ControlPaint.DrawBorder3D(e.Graphics, r) Next End Sub Code:
Public Class StatusLabel Inherits Label Protected Overrides ReadOnly Property CreateParams() As CreateParams Get Dim ret = MyBase.CreateParams ret.ExStyle = ret.ExStyle Or Native.WS_EX_CLIENTEDGE Return ret End Get End Property End Class Public Class Native Public Const WS_EX_CLIENTEDGE As Integer = &H200 End Class
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 1st September 2009 at 15:48. |
development, megui, not a help thread |
