3rd May 2013, 14:46 | #16982 | Link | |
Perhaps I don't understand the option, but I interpreted it as meaning that no file smaller than MIN_M2TS_SIZE will be re-encoded - it will only be copied to the output. |
3rd May 2013, 14:54 | #16983 | Link |
Sorry, I must have had a 60's flashback -- yes that's how it works. If the file is 197MB and it is set to 200, it shouldn't have been encoded. There are some other factors that can override it though, like if it is a part of a multipart sequence.
3rd May 2013, 14:59 | #16984 | Link |
Which season/disc of Justified is showing the issue? I have seasons 1-3, I think (it's a great show, although for some reason I still want to call Timothy Olyphant "Bullock" instead of "Raylan" -- Walton Goggins is great as Boyd Crowder).
3rd May 2013, 17:17 | #16987 | Link |
I remember I had the same problem with poor (unwatchable) menu quality with 'The Lincoln Lawyer' on BD-5. Maybe this happens when the original menu is already heavily compressed, and is then again shrunk in proportion similar to the feature? Perhaps it would help to encode the menus at fix CRF (e.g. same CRF as selected for the Extras)? It may then however be too difficult to re-calculate the remaining space for the rest of the files....
Just some thoughts. |
3rd May 2013, 22:38 | #16988 | Link |
BD Rebuilder v0.44.02 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.44.02). Changes for this version:
May 3rd, 2013 - v0.44.2 - Corrected an issue in which a zeroed language area in a CLPI could cause log issues when working with imported sources. - Added code to check for ALTERNATE output so the warning "Audio and/or PGS size too large. Probable oversize." is suppressed. - Corrected an issue that could result in the wrong SAR when ALTERNATE with 480/576 sources when no-resizing is selected. - Fixed an issue in which, under certain rare circumstances, a PGC may not be imported when importing from DVD. - Added new alternate video options that allow output using the original, untouched video to be kept. - Added a new video option in the SETUP dialog that allows resizing of 1920x1080 sources to 1440x1080. This can help eliminate noise on longer sources when outputting to BD-5/9. - Corrected an error in the importing function in which framerates can be incorrectly read on systems the use "," as a decimal point. - Added check for 1440x1080 source and adjusts encoding aspect ratio appropriately. - Added support for output of 3D source BDs to SBS 3D via the SETUP dialog. This option only supports movie-only (including ALTERNATE) mode and will only function if you have separately installed and properly configured the DirectshowMVCSource() DLL according to it's accompanying documentation. BD-RB must also have write access to it's folder. This feature should be especially useful in making 3D MKV and MP4 files or even DVDs from 3D BDs. The output, of course, requires a monitor or TV that supports SBS 3D. - Added a new hidden option "TYPE_OF_3D" that will allow you to specify an alternate output type for 3D (other that the default SBS). Options include Over/Under and Anaglyph. - Corrected an issue in which, under certain circumstances, individual resized subtitle lines may be inhibited from displaying. - Updated the included version of X264.EXE to the latest release (r2309). - Updated the included version of X264-64.EXE to the latest release (r2309). - Other minor corrections and cosmetic fixes. |
4th May 2013, 01:33 | #16990 | Link | |
4th May 2013, 06:24 | #16992 | Link |
Thank you, JDobbs, I shall check Robin Hood: Prince of Thieves...
4th May 2013, 08:33 | #16993 | Link |
Using 43.06 still. I tried an idea. Using same Rip...as in previous post. The first is MP4.. All .SUP files in the directory show correct bytes even though not used. Second is MKV..
---------------------- [05/03/13] BD Rebuilder v0.43.06 (beta) [21:33:49] Source: SHERLOCK_HOLMES_00100 - Input BD size: 23.04 GB - Approximate total content: [02:08:24.738] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: iPod MP4, 320x240/180, 64Kbs AAC - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [21:33:52] PHASE ONE, Encoding - [21:33:52] Processing: VID_00001 (1 of 23) - [21:33:52] Extracting A/V streams [VID_00001] - [21:40:50] Reencoding video [VID_00001] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,645 frames - [21:40:50] Reencoding: VID_00001, Pass 1 of 1 - [21:41:49] Video Encode complete - [21:41:49] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... - [21:47:18] Processing: VID_00003 (2 of 23) - [21:47:18] Extracting A/V streams [VID_00003] - [21:47:28] Reencoding video [VID_00003] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,067 frames - [21:47:28] Reencoding: VID_00003, Pass 1 of 1 - [21:48:34] Video Encode complete - [21:48:34] Processing: VID_00005 (3 of 23) - [21:48:34] Extracting A/V streams [VID_00005] - [21:48:53] Reencoding video [VID_00005] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 10,915 frames - [21:48:53] Reencoding: VID_00005, Pass 1 of 1 - [21:51:45] Video Encode complete - [21:51:45] Processing: VID_00006 (4 of 23) - [21:51:45] Extracting A/V streams [VID_00006] - [21:51:53] Reencoding video [VID_00006] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,306 frames - [21:51:53] Reencoding: VID_00006, Pass 1 of 1 - [21:52:47] Video Encode complete - [21:52:47] Processing: VID_00007 (5 of 23) - [21:52:47] Extracting A/V streams [VID_00007] - [21:52:55] Reencoding video [VID_00007] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,643 frames - [21:52:55] Reencoding: VID_00007, Pass 1 of 1 - [21:53:36] Video Encode complete - [21:53:36] Processing: VID_00008 (6 of 23) - [21:53:36] Extracting A/V streams [VID_00008] - [21:53:46] Reencoding video [VID_00008] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,525 frames - [21:53:46] Reencoding: VID_00008, Pass 1 of 1 - [21:54:42] Video Encode complete - [21:54:42] Processing: VID_00010 (7 of 23) - [21:54:42] Extracting A/V streams [VID_00010] - [21:55:11] Reencoding video [VID_00010] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 16,702 frames - [21:55:11] Reencoding: VID_00010, Pass 1 of 1 - [21:59:32] Video Encode complete - [21:59:32] Processing: VID_00012 (8 of 23) - [21:59:32] Extracting A/V streams [VID_00012] - [21:59:42] Reencoding video [VID_00012] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,273 frames - [21:59:43] Reencoding: VID_00012, Pass 1 of 1 - [22:00:51] Video Encode complete - [22:00:51] Processing: VID_00013 (9 of 23) - [22:00:51] Extracting A/V streams [VID_00013] - [22:01:05] Reencoding video [VID_00013] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,353 frames - [22:01:05] Reencoding: VID_00013, Pass 1 of 1 - [22:02:46] Video Encode complete - [22:02:46] Processing: VID_00014 (10 of 23) - [22:02:46] Extracting A/V streams [VID_00014] - [22:02:56] Reencoding video [VID_00014] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,768 frames - [22:02:56] Reencoding: VID_00014, Pass 1 of 1 - [22:04:12] Video Encode complete - [22:04:12] Processing: VID_00015 (11 of 23) - [22:04:12] Extracting A/V streams [VID_00015] - [22:04:39] Reencoding video [VID_00015] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 16,089 frames - [22:04:39] Reencoding: VID_00015, Pass 1 of 1 - [22:08:59] Video Encode complete - [22:08:59] Processing: VID_00016 (12 of 23) - [22:08:59] Extracting A/V streams [VID_00016] - [22:09:08] Reencoding video [VID_00016] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,394 frames - [22:09:08] Reencoding: VID_00016, Pass 1 of 1 - [22:10:03] Video Encode complete - [22:10:03] Processing: VID_00017 (13 of 23) - [22:10:03] Extracting A/V streams [VID_00017] - [22:10:42] Reencoding video [VID_00017] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 24,796 frames - [22:10:42] Reencoding: VID_00017, Pass 1 of 1 - [22:17:22] Video Encode complete - [22:17:22] Processing: VID_00018 (14 of 23) - [22:17:22] Extracting A/V streams [VID_00018] - [22:17:31] Reencoding video [VID_00018] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,756 frames - [22:17:31] Reencoding: VID_00018, Pass 1 of 1 - [22:18:32] Video Encode complete - [22:18:32] Processing: VID_00019 (15 of 23) - [22:18:32] Extracting A/V streams [VID_00019] - [22:19:01] Reencoding video [VID_00019] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 13,598 frames - [22:19:01] Reencoding: VID_00019, Pass 1 of 1 - [22:22:42] Video Encode complete - [22:22:42] Processing: VID_00021 (16 of 23) - [22:22:42] Extracting A/V streams [VID_00021] - [22:22:52] Reencoding video [VID_00021] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,981 frames - [22:22:52] Reencoding: VID_00021, Pass 1 of 1 - [22:23:56] Video Encode complete - [22:23:56] Processing: VID_00022 (17 of 23) - [22:23:56] Extracting A/V streams [VID_00022] - [22:24:22] Reencoding video [VID_00022] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,178 frames - [22:24:22] Reencoding: VID_00022, Pass 1 of 1 - [22:28:08] Video Encode complete - [22:28:08] Processing: VID_00023 (18 of 23) - [22:28:08] Extracting A/V streams [VID_00023] - [22:28:16] Reencoding video [VID_00023] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,516 frames - [22:28:16] Reencoding: VID_00023, Pass 1 of 1 - [22:28:55] Video Encode complete - [22:28:55] Processing: VID_00024 (19 of 23) - [22:28:55] Extracting A/V streams [VID_00024] - [22:29:23] Reencoding video [VID_00024] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,684 frames - [22:29:23] Reencoding: VID_00024, Pass 1 of 1 - [22:33:16] Video Encode complete - [22:33:16] Processing: VID_00025 (20 of 23) - [22:33:16] Extracting A/V streams [VID_00025] - [22:33:24] Reencoding video [VID_00025] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,965 frames - [22:33:24] Reencoding: VID_00025, Pass 1 of 1 - [22:34:13] Video Encode complete - [22:34:13] Processing: VID_00026 (21 of 23) - [22:34:13] Extracting A/V streams [VID_00026] - [22:34:41] Reencoding video [VID_00026] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 15,149 frames - [22:34:42] Reencoding: VID_00026, Pass 1 of 1 - [22:38:42] Video Encode complete - [22:38:42] Processing: VID_00027 (22 of 23) - [22:38:42] Extracting A/V streams [VID_00027] - [22:38:48] Reencoding video [VID_00027] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,563 frames - [22:38:48] Reencoding: VID_00027, Pass 1 of 1 - [22:39:15] Video Encode complete - [22:39:15] Processing: VID_00028 (23 of 23) - [22:39:15] Extracting A/V streams [VID_00028] - [22:39:34] Reencoding video [VID_00028] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 9,863 frames - [22:39:34] Reencoding: VID_00028, Pass 1 of 1 - [22:41:58] Video Encode complete [22:41:58]PHASE ONE complete [22:41:58]PHASE TWO - Rebuild Started - [22:41:58] Building ALTERNATE OUTPUT Structure [22:44:00] - Encode and Rebuild complete [22:44:00] JOB: SHERLOCK_HOLMES finished. Code:
---------------------- [05/03/13] BD Rebuilder v0.43.06 (beta) [22:56:14] Source: SHERLOCK_HOLMES_00100 - Input BD size: 23.04 GB - Approximate total content: [02:08:24.738] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 720x480/576, 128Kbs AC3 - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [22:56:17] PHASE ONE, Encoding - [22:56:17] Processing: VID_00001 (1 of 23) - [22:56:17] Extracting A/V streams [VID_00001] - [23:01:16] Reencoding video [VID_00001] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,645 frames - [23:01:16] Reencoding: VID_00001, Pass 1 of 1 - [23:01:49] Video Encode complete - [23:01:49] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [23:04:40] Processing: VID_00003 (2 of 23) - [23:04:40] Extracting A/V streams [VID_00003] - [23:04:50] Reencoding video [VID_00003] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,067 frames - [23:04:51] Reencoding: VID_00003, Pass 1 of 1 - [23:06:11] Video Encode complete - [23:06:11] Processing: VID_00005 (3 of 23) - [23:06:11] Extracting A/V streams [VID_00005] - [23:06:33] Reencoding video [VID_00005] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 10,915 frames - [23:06:33] Reencoding: VID_00005, Pass 1 of 1 - [23:10:17] Video Encode complete - [23:10:17] Processing: VID_00006 (4 of 23) - [23:10:17] Extracting A/V streams [VID_00006] - [23:10:25] Reencoding video [VID_00006] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,306 frames - [23:10:25] Reencoding: VID_00006, Pass 1 of 1 - [23:11:32] Video Encode complete - [23:11:32] Processing: VID_00007 (5 of 23) - [23:11:32] Extracting A/V streams [VID_00007] - [23:11:40] Reencoding video [VID_00007] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,643 frames - [23:11:40] Reencoding: VID_00007, Pass 1 of 1 - [23:12:33] Video Encode complete - [23:12:33] Processing: VID_00008 (6 of 23) - [23:12:33] Extracting A/V streams [VID_00008] - [23:12:42] Reencoding video [VID_00008] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,525 frames - [23:12:42] Reencoding: VID_00008, Pass 1 of 1 - [23:14:04] Video Encode complete - [23:14:04] Processing: VID_00010 (7 of 23) - [23:14:04] Extracting A/V streams [VID_00010] - [23:14:33] Reencoding video [VID_00010] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 16,702 frames - [23:14:33] Reencoding: VID_00010, Pass 1 of 1 - [23:20:38] Video Encode complete - [23:20:38] Processing: VID_00012 (8 of 23) - [23:20:38] Extracting A/V streams [VID_00012] - [23:20:49] Reencoding video [VID_00012] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,273 frames - [23:20:49] Reencoding: VID_00012, Pass 1 of 1 - [23:22:19] Video Encode complete - [23:22:19] Processing: VID_00013 (9 of 23) - [23:22:19] Extracting A/V streams [VID_00013] - [23:22:33] Reencoding video [VID_00013] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,353 frames - [23:22:33] Reencoding: VID_00013, Pass 1 of 1 - [23:24:51] Video Encode complete - [23:24:51] Processing: VID_00014 (10 of 23) - [23:24:51] Extracting A/V streams [VID_00014] - [23:25:01] Reencoding video [VID_00014] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,768 frames - [23:25:01] Reencoding: VID_00014, Pass 1 of 1 - [23:26:44] Video Encode complete - [23:26:44] Processing: VID_00015 (11 of 23) - [23:26:44] Extracting A/V streams [VID_00015] - [23:27:12] Reencoding video [VID_00015] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 16,089 frames - [23:27:12] Reencoding: VID_00015, Pass 1 of 1 - [23:33:11] Video Encode complete - [23:33:11] Processing: VID_00016 (12 of 23) - [23:33:11] Extracting A/V streams [VID_00016] - [23:33:19] Reencoding video [VID_00016] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,394 frames - [23:33:19] Reencoding: VID_00016, Pass 1 of 1 - [23:34:37] Video Encode complete - [23:34:37] Processing: VID_00017 (13 of 23) - [23:34:37] Extracting A/V streams [VID_00017] - [23:35:16] Reencoding video [VID_00017] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 24,796 frames - [23:35:16] Reencoding: VID_00017, Pass 1 of 1 - [23:44:13] Video Encode complete - [23:44:13] Processing: VID_00018 (14 of 23) - [23:44:13] Extracting A/V streams [VID_00018] - [23:44:22] Reencoding video [VID_00018] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,756 frames - [23:44:22] Reencoding: VID_00018, Pass 1 of 1 - [23:45:40] Video Encode complete - [23:45:41] Processing: VID_00019 (15 of 23) - [23:45:41] Extracting A/V streams [VID_00019] - [23:46:06] Reencoding video [VID_00019] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 13,598 frames - [23:46:06] Reencoding: VID_00019, Pass 1 of 1 - [23:51:07] Video Encode complete - [23:51:07] Processing: VID_00021 (16 of 23) - [23:51:07] Extracting A/V streams [VID_00021] - [23:51:17] Reencoding video [VID_00021] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,981 frames - [23:51:17] Reencoding: VID_00021, Pass 1 of 1 - [23:52:50] Video Encode complete - [23:52:50] Processing: VID_00022 (17 of 23) - [23:52:50] Extracting A/V streams [VID_00022] - [23:53:17] Reencoding video [VID_00022] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,178 frames - [23:53:17] Reencoding: VID_00022, Pass 1 of 1 - [23:58:10] Video Encode complete - [23:58:10] Processing: VID_00023 (18 of 23) - [23:58:10] Extracting A/V streams [VID_00023] - [23:58:17] Reencoding video [VID_00023] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,516 frames - [23:58:17] Reencoding: VID_00023, Pass 1 of 1 - [23:59:10] Video Encode complete - [23:59:10] Processing: VID_00024 (19 of 23) - [23:59:10] Extracting A/V streams [VID_00024] - [23:59:34] Reencoding video [VID_00024] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,684 frames - [23:59:35] Reencoding: VID_00024, Pass 1 of 1 - [00:04:59] Video Encode complete - [00:04:59] Processing: VID_00025 (20 of 23) - [00:04:59] Extracting A/V streams [VID_00025] - [00:05:06] Reencoding video [VID_00025] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,965 frames - [00:05:06] Reencoding: VID_00025, Pass 1 of 1 - [00:06:17] Video Encode complete - [00:06:18] Processing: VID_00026 (21 of 23) - [00:06:18] Extracting A/V streams [VID_00026] - [00:06:43] Reencoding video [VID_00026] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 15,149 frames - [00:06:43] Reencoding: VID_00026, Pass 1 of 1 - [00:12:20] Video Encode complete - [00:12:20] Processing: VID_00027 (22 of 23) - [00:12:20] Extracting A/V streams [VID_00027] - [00:12:26] Reencoding video [VID_00027] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,563 frames - [00:12:26] Reencoding: VID_00027, Pass 1 of 1 - [00:13:02] Video Encode complete - [00:13:02] Processing: VID_00028 (23 of 23) - [00:13:02] Extracting A/V streams [VID_00028] - [00:13:19] Reencoding video [VID_00028] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 9,863 frames - [00:13:19] Reencoding: VID_00028, Pass 1 of 1 - [00:16:08] Video Encode complete [00:16:08]PHASE ONE complete [00:16:08]PHASE TWO - Rebuild Started - [00:16:08] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [00:17:17] - Failed to REBUILD
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 4th May 2013 at 08:37. |
4th May 2013, 12:12 | #16994 | Link |
3D encoding problem
@jdobbs
I tried to do a 3D encode, but no avail. I do have a working DirectShowMVCSource.dll Installation, so I don't think the problem is with my setup. Here the VID.....avs: Code:
#Created by BD Rebuilder - v0.44.02 (beta) LoadPlugin("c:\Program Files Video\MVCtoAVI.exe\DirectShowMVCSource.dll") RIGHT=DirectShowMVCSource("C:\TEMP\BD REBUILDER\WORKFILES\00916.SSIF", framecount=178056) LEFT=DirectShowMVCSource("C:\TEMP\BD REBUILDER\WORKFILES\00916.SSIF", framecount=178056,decodeleft=true) LEFT=ConvertToRGB32(LEFT) RIGHT=ConvertToRGB32(RIGHT) MergeRGB(RIGHT,LEFT,RIGHT) Spline16Resize(1440,1080) ConvertToYV12().AssumeFPS(24000,1001) |
4th May 2013, 14:13 | #16995 | Link | |
4th May 2013, 14:18 | #16996 | Link | |||
#Created by BD Rebuilder - v0.44.02 (beta) LoadPlugin("c:\Program Files Video\MVCtoAVI.exe\DirectShowMVCSource.dll") RIGHT=DirectShowMVCSource("C:\TEMP\BD REBUILDER\WORKFILES\00916.SSIF", framecount=178056) LEFT=DirectShowMVCSource("C:\TEMP\BD REBUILDER\WORKFILES\00916.SSIF", framecount=178056,decodeleft=true) LEFT=ConvertToRGB32(LEFT) RIGHT=ConvertToRGB32(RIGHT) MergeRGB(RIGHT,LEFT,RIGHT) Spline16Resize(1440,1080) ConvertToYV12().AssumeFPS(24000,1001) Quote:
4th May 2013, 14:42 | #16997 | Link |
BD Rebuilder v0.44.03 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.44.03). Changes for this version:
- Corrected a bug in v0.44.2 in which encoding 3D sources that were not multipart was not working. (v0.44.03) - Corrected an issue in which a zeroed language area in a CLPI could cause log issues when working with imported sources.(v0.44.2) - Added code to check for ALTERNATE output so the warning "Audio and/or PGS size too large. Probable oversize." is suppressed.(v0.44.2) - Corrected an issue that could result in the wrong SAR when ALTERNATE with 480/576 sources when no-resizing is selected.(v0.44.2) - Fixed an issue in which, under certain rare circumstances, a PGC may not be imported when importing from DVD.(v0.44.2) - Added new alternate video options that allow output using the original, untouched video to be kept.(v0.44.2) - Added a new video option in the SETUP dialog that allows resizing of 1920x1080 sources to 1440x1080. This can help eliminate noise on longer sources when outputting to BD-5/9. (v0.44.2) - Corrected an error in the importing function in which framerates can be incorrectly read on systems the use "," as a decimal point. (v0.44.2) - Added check for 1440x1080 source and adjusts encoding aspect ratio appropriately.(v0.44.2) - Added support for output of 3D source BDs to SBS 3D via the SETUP dialog. This option only supports movie-only (including ALTERNATE) mode and will only function if you have separately installed and properly configured the DirectshowMVCSource() DLL according to it's accompanying documentation. BD-RB must also have write access to it's folder. This feature should be especially useful in making 3D MKV and MP4 files or even DVDs from 3D BDs. The output, of course, requires a monitor or TV that supports SBS 3D.(v0.44.2) - Added a new hidden option "TYPE_OF_3D" that will allow you to specify an alternate output type for 3D (other that the default SBS). Options include Over/Under and Anaglyph. (v0.44.2) - Corrected an issue in which, under certain circumstances, individual resized subtitle lines may be inhibited from displaying. (v0.44.2) - Updated the included version of X264.EXE to the latest release (r2309). - Updated the included version of X264-64.EXE to the latest release (r2309). - Other minor corrections and cosmetic fixes. |
4th May 2013, 15:46 | #16999 | Link |
You'll find it in several other packages in the 3D encoding thread (check signature blocks in some of the later posts for "BD3D2MK3D" or "MVC Player Free" -- both have it included). I personally also purchased the "MVC to AVI" converter here so I'd have a legal copy of the CoreAVC decoder DLL that is needed. It's only 19 euros. If you read the DirectshowMVCSource.txt file it will explain how to install it.
4th May 2013, 16:12 | #17000 | Link | |
Is there anything special with x264-bd.exe which is put into the "mystic" Directory? Any tests you want me to do? Edit: Sorry - my mistake. I left a trim() command for testing purpose in the avisynth script. Apparently this caused the crash. Encoding .... Last edited by Sharc; 4th May 2013 at 16:32. Reason: correction |
