Old 26th May 2009, 13:39   #2981  |  Link
LordSNK
Make sure you:
1) Load your files
2) Click start
3) Select "AVCHD for optical media"
4) multiAVCHD will create AVCHD folder
4) Burn its contents (BDMV folder) to a DVD-RW disc.
*** You got me worried, so I just burned a compilation to a DVD-RW disc and (of course) it works perfectly as expected in my PS3.
I try but don't works.
So I delete the MultiAVCHD folder and I reinstall it.
Then it works again.
Thank you very much
In a future release will it possible to choose language for audio and subtitles?
LordSNK is offline   Reply With Quote
Old 26th May 2009, 15:01   #2982  |  Link
@deank
Here is script which improves reflections in your SLIDE Menu.
http://www.mediafire.com/file/wwjm2u...enu-example.7z
Old 26th May 2009, 15:11   #2983  |  Link
Gaidamak
Strange working Author and Menu features. Preview not working. Result menu on BD/AVCHD is green square without any symbols. Under Vista. One of older versions (maybe one or two months ago) works more correct.
Gaidamak is offline   Reply With Quote
Old 26th May 2009, 15:27   #2984  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
You're probably the only one with 'non-working' multiAVCHD. Don't blame the software - check your configuration and avisynth installation.
Dean
Old 26th May 2009, 15:30   #2985  |  Link
drelin
I saw the preview of the futur version and it's apparently great ergonomic (specially the import of audio & sub tracks).
Very good preview.
Great thank for the job.
drelin is offline   Reply With Quote
Old 26th May 2009, 17:25   #2986  |  Link
fbimatrix
Why I am getting the error 80029946 ?
fbimatrix is offline   Reply With Quote
Old 26th May 2009, 17:28   #2987  |  Link
deank
deank's Avatar
Why were there 300 earthquakes here for the last 2 days?
How could you expect me to answer your question?!
Old 26th May 2009, 17:37   #2988  |  Link
fbimatrix
I tried to play the release star wars , 1080p , I converted and all . but when I put it on ps3 gives an error that the file cannot be played error 80029946 ? , does anyone knows what may be happening?
Old 26th May 2009, 17:54   #2989  |  Link
Next time learn how to use google amigo. It took me 10 seconds to find answer
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3 (workaround is to transfer files to ps3 via TVersity) (added 24th Sept 2007)
http://boardsus.playstation.com/play...158519#M154384
Old 26th May 2009, 21:21   #2990  |  Link
fbimatrix
I ve seen this , but how Will I use the program with AVCHD? I just use AVCHD not the tvserty
Old 27th May 2009, 05:33   #2991  |  Link
LHL-bLuECoDe
Subtitles dont work
Hello.Well i put 10 media files in multiAVCHD with their subtitles (spanish). Everything went fine, i got my new folder BDMV and CERTIFICATE. My Samsung BDP-1500 plays it ok but the subtitles doesnt appear. What am i doing wrong?. I used carrousel menu style. The movie plays fine and menu plays fine but the subtitles dont. Thanxs in advance and sorry for my english .
LHL-bLuECoDe is offline   Reply With Quote
Old 27th May 2009, 06:12   #2992  |  Link
drpaulng
http://forum.doom9.org/showthread.ph...54#post1283554
This may help??
Paul Ng
drpaulng is offline   Reply With Quote
Old 27th May 2009, 06:21   #2993  |  Link
Cela
Current version v2.7 b613,
Settings > Delete all files in temp folder UNchecked
BUT all files in temp folder(except mediainfo.txt) get deleted.
Sometimes I would need to keep for instance the result of the first demux step:
D:\_TEMP\avidump.264
D:\_TEMP\avidump.ac3
In general, intermediate result could be quite handy, sometimes.
Please make that work again in the next release!
Cela is offline   Reply With Quote
Old 27th May 2009, 08:28   #2994  |  Link
Gaidamak
Sorry for my terrible English, It would a good thing to set autochapter interval editable (5,10 min etc.)
Old 27th May 2009, 08:44   #2995  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Deank,
May I suggest you to use Aften instead of FFmpeg to transcode to AC3 format ? Aften is multithreaded...
for Stereo Input:
FFmpeg -i input.mkv -vn -acodec pcm_s16le -ac 2 -f wav - | aften.exe -readeof 1 -b 384 - output.ac3
Multichannel Input:
FFmpeg -i input.mkv -vn -acodec pcm_s16le -ac 6 -f wav - | aften.exe -readeof 1 -b 448 - output.ac3
In addition, is it normal that when I select a specific frame as thumbnail (not frame 0), the preview doesn't use it ?
Old 27th May 2009, 08:45   #2996  |  Link
drelin
Custom chapters list is yet avialable, see the first post for more informations.
It's work fine.
Old 27th May 2009, 08:49   #2997  |  Link
johns0
johnisme
You wont see the thumbnail you pick in preview,it will be there when you author the folder and burn it.
johns0 is offline   Reply With Quote
Old 27th May 2009, 09:10   #2998  |  Link
Gaidamak
It's work fine.
Thank you. Once more problem. Two BDMV folders on input. I get an error on processing second folder.
After change order of folders I get same error on second (ex-first) folder.
Old 27th May 2009, 10:31   #2999  |  Link
deank
deank's Avatar
Check if all files in the second folder follow the long names format... all should be .clpi/.m2ts/.mpls... you can't have one in 8.3 format and other in long format.
To all: Please be a bit more patient. I'll be ready with the new version soon. A lot of bugs were found in 613 and fixed.
Dean
Old 27th May 2009, 10:54   #3000  |  Link
Gaidamak
Dean
It's not depend on filenames. As I wrote above, after changing folders order in Media window, first (ex-second) folder passing OK, second (ex-first) give error. I'd try use very short folder names - all the same.
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
