12th July 2009, 15:09 | #21 | Link | ||||
telecide(vthresh=30) Quote:
12th July 2009, 15:38 | #22 | Link | ||
Software Developer
Instead of interpolating one field (as a deinterlacer would do) it re-orders the fields according to a pattern in order to reconstruct the original progressive frames. Everything that goes beyond that is post-processing, not plain IVTC. But I never doubted that such post-processing is useful Quote:
In my previous post I already admitted that I had missed the post-poressing part of Decomb Telecide before. And I made clear that I now understand it is there (for a good reason). It should have been clear that the "if" statement in my post evaluates to TRUE. No need to nag around on this any further
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 12th July 2009 at 15:41. |
12th July 2009, 16:15 | #23 | Link |
I didn't do any such thing. Why would you say "if" when you already knew it was true? Some strange psychology? Decomb has been around for over half a decade; its functionality is well known. Why would you try to obfuscate this?
12th July 2009, 16:20 | #24 | Link |
Software Developer
As my statement was pretty clear in the original context, I won't further comment on this. We all know what was meant now
Back to topic: telecide(vthresh=30) seems to give much better results. But I'm not sure whether I prefer that over the Yadif version...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 12th July 2009 at 16:28. |
12th July 2009, 16:21 | #25 | Link | |
brontosaurusrex
certain other member |
12th July 2009, 21:02 | #27 | Link |
Software Developer
The screenshot was intended to show the color ghosting that is present in the source clip
12th July 2009, 22:25 | #28 | Link |
Mais oui, Monsieur!
I'm pretty satisfied with the results of combining Decomb Telecide with Vinverse. The post processor in DT doesn't seem to quite catch all the combing leftovers on it's own, so I turned it off and just used Vinverse for cleanup.
AssumeBFF() Telecide(guide=2,post=0,vthresh=30,show=false) loadplugin("vinverse.dll") vinverse() Here's a resulting frame: Now when I tried only using Telecide and it's post processing, the results weren't as good (IMHO). Notice around the edge of the glasses... AssumeBFF() Telecide(vthresh=30) If there was some filter to fix the field "wobble" or distortion, so that they lined up nice and even, I would gladly try it rather than use Vinverse (which I understand is simply a blur/sharpen routine). So far this is the best I've found. Hope everyone's having a great Sunday - and thanks for the help and suggestions. Last edited by LeoH; 12th July 2009 at 22:30. |
13th July 2009, 14:09 | #29 | Link | |
Ok.. but i also see the deinterlacing result..
"Use the defaults, Luke. Use the defaults." > Obi-Web Kenobi Last edited by EasyRider_; 13th July 2009 at 22:56. |
23rd October 2019, 14:57 | #30 | Link | ||
French Registered User
Hello everybody
I'm looking for a specific kind of deinterlacing method. In fact, I want an adaptative method which is mixing the Bob and the Weave method. Here it's explained : https://www.100fps.com/ Quote:
https://shmups.system11.org/viewtopi...50&start=10200 Quote:
I just want to test these kind of specific methods. Thanks for your help ! |
24th October 2019, 03:10 | #31 | Link |
Here we can see the very good deinterlacing method of the XRGB-mini Framemeister with 480i content :
https://youtu.be/nbCt9_87hBo Compared to the Bob method of the OSSC : https://youtu.be/ZMdRZCMBI-k I really think that the method of the Framemeister is impressive ! Is there a way to get a similar method with AviSynth or a VirtualDub filter ? Thanks for your help ! |
26th October 2019, 11:36 | #34 | Link | ||
The QTGMC looks very impressive !
But a bit complicated and slow. Yadif isn't bad with double framerate either and less complicated I tested another surprising deinterlacer called "Smooth Deinterlacer". We can find it here : https://www.guthspot.se/video/AVSPor...hDeinterlacer/ So we can use this function for the best : Quote:
26th October 2019, 11:46 | #35 | Link | |
Also, quality-wise, TGMC/QTGMC blows everything else out of the water, see this clip. Lastly, there's nothing complicated about QTGMC - pick a preset and let it do its thing.
Groucho's Avisynth Stuff Last edited by Groucho2004; 26th October 2019 at 12:07. |
26th October 2019, 13:06 | #36 | Link |
OK. Thanks ! I think I will try !
No, in fact, I was just too lazy too download the plugins required ! It's the complicated thing ! P.S. : Does the QTGMC automatically detect if it's BFF or TFF in the source ? Last edited by SuperLumberjack; 26th October 2019 at 13:08. |
26th October 2019, 13:33 | #37 | Link |
There are so many plugins to install. Each time I get a new error from VirtualDub
It would have been cool to put them all in one pack with the QTGMC... Sorry, even if I'm not completely a noob, I'm still a noob ! Edit 1 : I don't understand what I'm supposed to do with the files from the "FFTW3" archive... So yes, it's a bit complicated with all these plugins. It's why I was lazy ! Edit 2 : I said nothing ! https://forum.doom9.org/showthread.php?t=156028 Last edited by SuperLumberjack; 26th October 2019 at 13:48. |
26th October 2019, 13:56 | #38 | Link | |
I get this error :
26th October 2019, 14:09 | #39 | Link | |
Sory, I used the x64 version of VirtualDub instead of the x86 !
But with the 32 bit version, I still have an error : Quote:
26th October 2019, 14:13 | #40 | Link |
looks like maybe old version masktools.
EDIT: looks like use_expr also requires Avs+. [uses avs+ Expr() ] EDIT: Pinterf Masktools:- https://github.com/pinterf/masktools AviSynthPlus_3.4.0_20191020.exe:- https://github.com/AviSynth/AviSynthPlus/releases
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th October 2019 at 14:23. |
