19th July 2018, 23:51 | #21 | Link |
thx updated locally.
21st July 2018, 23:23 | #22 | Link |
Cary Knoop
This initiative is wonderful but may I suggest to get a better site to upload?
Zippyshare is giving me not very professional ads to say the least and creates new tabs to download all kind of software of questionable origin. How about using dropbox? |
22nd July 2018, 08:35 | #23 | Link |
Oh you're right. I visited zippyshare only with an adblocker and it looks very clean, without an ablocker not so much....
I changed the download url to dropbox.
23rd July 2018, 15:33 | #24 | Link |
Soul Architect
I use https://mega.nz/ for all uploads and it works wonderfully and is fully encrypted -- for those who don't like ads and who don't like giving all their data to the government.
23rd July 2018, 16:29 | #25 | Link |
I tried Yuuno Editor, but when I try to
%load_ext yuuno |
23rd July 2018, 17:11 | #26 | Link |
yuuno should already be loaded (autoload is active)
Did you try other commands, like %preview core.std.BlankClip(color=[0,255,255]) ? Also more infos are needed, like what os are you using
23rd July 2018, 18:09 | #27 | Link |
First time I heard of "Yuuno Editor". https://pypi.org/project/yuuno/ And it seems all the documentation links are down https://yuuno.encode.moe/installation.html https://yuuno.encode.moe/usage.html https://yuuno.encode.moe/ Maybe I should start another thread on it, but can someone give a quick review pros/cons or comments ? Thanks |
23rd July 2018, 18:26 | #28 | Link |
23rd July 2018, 19:46 | #29 | Link | |
Yes, I tried it, it returns "UsageError: Line magic function `%preview` not found." All the magic functions I try return not found. I also don't get any type of syntax highlight for vapoursynth related functions. I'm on Windows 10 64bit up to date with version 1803. |
23rd July 2018, 20:01 | #30 | Link |
I think I deleted an important folder somewhere. I will post an updated version soon.
25th July 2018, 23:13 | #32 | Link |
New Update (inc newest Waifu2x models)
Please test Yuuno again. Thanks to vsrepo most scripts and plugins can now be updated via one click.
26th July 2018, 21:05 | #33 | Link | |
If it can be useful, there's a software you can you to compare two folders or files, might help you catch the problem (if there's actually one, and it's not just me): Beyond Compare 4 Anyway, thanks for your work! EDIT: don't know if it's a relevant info but: just noticed that in the 06-21-2018 version "Kernel" has a white dot, that reports "kernel idle". While the non working version only reports "kernel connected" Last edited by ThePi7on; 26th July 2018 at 21:17. |
26th July 2018, 22:30 | #34 | Link |
Try this please https://www.dropbox.com/s/eqksin710y...e_test.7z?dl=1
26th July 2018, 23:26 | #35 | Link | |
27th July 2018, 23:49 | #36 | Link |
New release, see first post.
29th July 2018, 01:33 | #37 | Link |
Thank you so much for creating this very useful package.
One small thing may be not important, is that when I run _vs_plugin_check.bat I get the following output : Code:
####################################### VapourSynth Video Processing Library Copyright (c) 2012-2018 Fredrik Mellbin Core R44 API R3.5 Options: - Architecture 64bit - Windows-10-10.0.17134-SP0 Python build: ('v3.6.5:f59c0932b4', 'Mar 28 2018 17:00:18') ####################################### checking dlls in d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins ####################################### Errors: ------- Failed to load d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins\bilateralGPU.dll. GetLastError() returned 126. A DLL dependency is probably missing. Plugin load failed, namespace focus already populated (d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins\libtemporalsoften.dll) Notices: ------- libfftw3-3.dll is a dependency by fft3dfilter or mvtools-sf libfftw3f-3.dll is a dependency by fft3dfilter or mvtools-sf libiomp5md.dll is part of the Waifu2x-w2xc filter libmfxsw64.dll is part of the DGMVCSourceVS filter svml_dispmd.dll is part of the Waifu2x-w2xc filter w2xc.dll is part of the Waifu2x-w2xc filter ####################################### Found 109 dlls. Errors: 2 Notices: 6 Press any key to continue . . . I guess the plugin bilateralGPU.dll needs some additional files to work. About the second error on libtemporalsoften.dll : does this cause any further problems ? |
29th July 2018, 04:35 | #38 | Link |
Helenium(Easter)
In order to use bilateralGPU.dll, you need to have opencv_core320.dll and opencv_cudaimgproc320.dll in the same path.
(Requirements: CUDA-Enabled GPU, OpenCV run-time library with CUDA module) libtemporalsoften.dll and libfocus-em64t.dll have the same namespace. (focus.TemporalSoften)
Monochrome Anomaly |
29th July 2018, 09:34 | #39 | Link | |
Idk which temporalsoften is "better" so I left both for now. You probably will only use Temporalsoften2 anyway.
29th July 2018, 16:57 | #40 | Link | |
What extra package do I need to install then ? |
