3rd May 2011, 13:02 | #11902 | Link | |
Are you positive you have BDMV_CERT_ONLY=1 set in the config file? [Edit] Ok... I did the testing. It works correctly. Even the files in the root are ignored when BDMV_CERT_ONLY=1 is set. So I have to assume you are mistaken in your testing. Maybe you misspelled it in the config file... Last edited by jdobbs; 3rd May 2011 at 13:57. |
3rd May 2011, 15:52 | #11903 | Link | |
3rd May 2011, 15:56 | #11904 | Link | ||
3rd May 2011, 21:55 | #11906 | Link |
Hello again
I'm having trouble with rebuilding Matrix Revolutions to BD25. The resulting disk is too large (25.670.975.488 Bytes) for a BD25. What can I do here? I attached the log. Last edited by The_Unknown; 3rd May 2011 at 22:03. |
3rd May 2011, 22:17 | #11907 | Link | |
Settings -> Setup: put this number: 24250 in the box next to this text "Custom Target Size" and click in" save changes." |
3rd May 2011, 22:44 | #11912 | Link |
At the moment I do 23400. One thing I noticed is, that BD-RB doesn't reencode the main movie; only the other ones. Which is of course great, because no quality is lost. And also I have to say this is the first disk where I'm experiencing size problems.
Edit: Now with 23400 MB it encodes the main movie, so now I think it will be ok in size. But I noticed, that an audio track called "(2nd) AC3 Plus, Stereo, English" can be deactivated Why can't I deactivate that track, so it could fit the disk?? Last edited by The_Unknown; 3rd May 2011 at 23:11. |
4th May 2011, 00:18 | #11913 | Link | |
If you want more precise sizing, set BD-RB to two pass mode. |
4th May 2011, 01:24 | #11914 | Link | |
4th May 2011, 21:24 | #11918 | Link |
Converting Little Fockers to movie only DVD-5. I tried both the full source and the movie only BD25. Both times it showed "WARNING: Failed to integrate DVD subtitle" in the log. The weird thing is that the subtitles are working in the DVD5. The movie only BD25 worked fine.
BD-25 ----------------------- Code:
[13:29:57] BD Rebuilder v0.37.08 (beta) - Source: LITTLE_FOCKERS - Input BD size: 25.23 GB - Approximate total content: [01:37:47.319] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [13:30:00] PHASE ONE, Encoding - [13:30:00] Extracting A/V streams [VID_00010] - [13:35:59] Reencoding: VID_00010 (1 of 2) - [13:35:59] Collecting video information - [13:35:59] Keeping original video (no reencode) - [13:35:59] Reencoding audio tracks (if req'd) - [13:38:49] Multiplexing M2TS - [13:54:31] Extracting A/V streams [VID_00802] - [13:54:32] Reencoding: VID_00802 (2 of 2) - [13:54:32] Collecting video information - [13:54:32] Keeping original video (no reencode) - [13:54:32] Multiplexing M2TS [13:54:32]PHASE ONE complete [13:54:32]PHASE TWO - Rebuild Started - [13:54:32] Rebuilding BD file Structure [14:10:00] - Encode and Rebuild complete [14:10:00]JOB: LITTLE_FOCKERS finished. BD25 to DVD5 encode ----------------------- Code:
[22:14:17] BD Rebuilder v0.37.08 (beta) - Source: LITTLE_FOCKERS - Input BD size: 21.70 GB - Approximate total content: [01:37:47.328] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [22:14:19] PHASE ONE, Encoding - [22:14:19] Extracting A/V streams [VID_00000] - [22:19:23] Reencoding: VID_00000 (1 of 1) - [22:19:23] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 140,675 frames - Bitrate: 5,706 Kbs - [22:19:23] Reencoding: VID_00000 - [00:25:16] Video Encode complete - [00:25:16] Reencoding audio tracks (if req'd) - [00:26:26] Multiplexing M2TS [00:26:26]PHASE ONE complete [00:26:26]PHASE TWO - Rebuild Started - [00:26:26] Rebuilding stream 00000 [1 of 1] - [00:26:26] Building ALTERNATE OUTPUT Structure - [00:29:11] Converting 1 subtitles to DVD format. - [00:30:32] Starting MPLEX. - [00:33:21] Multiplexing 1 subtitles into stream. - WARNING: Failed to integrate DVD subtitle - [00:35:09] Building DVD File Structure. [00:38:12] - Encode and Rebuild complete [00:38:12]JOB: LITTLE_FOCKERS finished. Full rip to DVD5 encode ----------------------- Code:
[11:35:17] BD Rebuilder v0.37.08 (beta) - Source: LITTLE_FOCKERS - Input BD size: 25.23 GB - Approximate total content: [01:37:47.319] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [11:35:19] PHASE ONE, Encoding - [11:35:19] Extracting A/V streams [VID_00010] - [11:40:13] Reencoding: VID_00010 (1 of 2) - [11:40:13] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 140,520 frames - Bitrate: 5,711 Kbs - [11:40:14] Reencoding: VID_00010 - [13:49:27] Video Encode complete - [13:49:27] Reencoding audio tracks (if req'd) - [13:52:11] Multiplexing M2TS - [13:52:11] Extracting A/V streams [VID_00802] - [13:52:12] Reencoding: VID_00802 (2 of 2) - [13:52:12] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 155 frames - Bitrate: 874 Kbs - [13:52:12] Reencoding: VID_00802 - [13:52:17] Video Encode complete - [13:52:17] Multiplexing M2TS [13:52:17]PHASE ONE complete [13:52:17]PHASE TWO - Rebuild Started - [13:52:17] Rebuilding stream 00010 [1 of 2] - [13:52:17] Rebuilding stream 00802 [2 of 2] - [13:52:17] Building ALTERNATE OUTPUT Structure - [13:54:47] Converting 1 subtitles to DVD format. - [13:55:57] Starting MPLEX. - [13:58:24] Multiplexing 1 subtitles into stream. - WARNING: Failed to integrate DVD subtitle - [14:00:30] Building DVD File Structure. [14:02:36] - Encode and Rebuild complete [14:02:36]JOB: LITTLE_FOCKERS finished.
There are 11 kinds of people in the world, those who know binary, those who don't, & those who think they do. Proud member of America’s most distrusted minority!! Last edited by Giljorak; 5th May 2011 at 01:21. Reason: clarification |
5th May 2011, 00:39 | #11919 | Link | |
5th May 2011, 01:59 | #11920 | Link | |
Playlist 00099.mpls shows 02:12:34, just as the other two playlists. However, the order for .m2ts files is: 00130.m2ts, 00131.m2ts, 00132.m2ts(1). Same for 00135.m2ts(1), 00138.m2ts(1), 00141.m2ts(1), etc... I have never seen this parantheses(1) before after the .m2ts. It also shows 2 - 1080P/ 23.976fps / 16:9 / High Profile 4.1. The second one listed just below the first has : MPEG-4 AVC Video (1). Again this parantheses(1)! EDIT: I did not use BD-Edit, but BDInfo v.0.5.6 Does your disc have a 00132.m2ts file? When 00132.m2ts is played, which is 47 seconds long, it starts as a fight with Bond fighting a guy on the hovercraft, but after 4 seconds, the fight seen is transitioned to a PiP in the left corner of the screen, and the "about the scene" director is now the full screen picture, and he begins discussing the making of. Last edited by Capsbackup; 5th May 2011 at 02:11. |
