Old 9th August 2014, 11:05   #241  |  Link
masterkivat
変身!
masterkivat's Avatar
The usual guy from where I was downloading "l-smash works" (yet other binaries like custom x264 builds) stopped, it's a shame.
Hope that more people get interest in sharing their own compiled versions, which is something that I don't master
masterkivat is offline   Reply With Quote
Old 10th August 2014, 01:07   #242  |  Link
burfadel
Yeah, quickest way for a project to die is the unavailability of binaries. If people can't get binaries they can't use it!
Old 11th August 2014, 11:16   #243  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
You can get my L-SMASH-Works builds here. Require Visual C++ Redist 2013 (32-bit, 64-bit) and Windows Vista or later.
Also my L-SMASH builds can be found here.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
Last edited by the_weirdo; 17th March 2015 at 03:16. Reason: update link to newer builds
the_weirdo is offline   Reply With Quote
Old 11th August 2014, 14:47   #244  |  Link
for maintaining their availability.
Old 12th August 2014, 04:51   #245  |  Link
masterkivat
変身!
, "weirdo"-san.
Old 12th August 2014, 06:52   #246  |  Link
bennynihon
Is there a way to mux in a subtitle track using the L-Smash muxer? What about setting one of two audio tracks as the default track? Thanks
bennynihon is offline   Reply With Quote
Old 13th August 2014, 04:14   #247  |  Link
burfadel
Originally Posted by the_weirdo View Post
Here are my builds:
L-SMASH Works r729 32-bit
L-SMASH Works r729 64-bit
Thanks, very much appreciated!
Old 27th August 2014, 06:03   #248  |  Link
gnol009
Any chance for FFinfo() in FFMS2.avsi can work with LWLibavVideoSource()?
gnol009 is offline   Reply With Quote
Old 27th August 2014, 08:56   #249  |  Link
Probably only if L-SMASH Works would expose similar internal variables as FFMS2. The support has to start in the plugin DLL.
Old 8th September 2014, 14:40   #250  |  Link
Reel.Deel
@Selur
Can you please update the links in the first post with the link here. And also make it clickable
Reel.Deel is offline   Reply With Quote
Old 13th September 2014, 01:14   #251  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Looks like WebM/VP9 decoding is completely broken in the latest builds. Oh well, I have a copy from 2013 that seems to work right, I can use that just for webm.
Old 13th September 2014, 12:48   #252  |  Link
Are_
Not a single problem here at my linux box with my own compiles. Linked against ffmpeg and using vapoursynth filter.
Are_ is offline   Reply With Quote
Old 15th September 2014, 18:56   #253  |  Link
Reel.Deel
Do you know which version from 2013?
Old 15th September 2014, 20:03   #254  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
I had already gotten a report and a sample of VP9-in-WebM from someone through ask.fm and 2ch.
And he says that binaries linked with ffmpeg have the problem but with libav have no.
I'll look into this later.
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 17th September 2014, 14:00   #255  |  Link
fvisagie
Many thanks for helping keep this alive .
What is the difference between the builds in the top-level folder linked and those in the with-Libav subfolder? They both seem to support the LWLibav...Source() functions, so I'm a little confused by the distinction between these different builds.
fvisagie is offline   Reply With Quote
Old 17th September 2014, 14:48   #256  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
Those builds in top folder are linked with FFmpeg libraries, while those builds in "with-Libav" are linked with... Libav libraries. You can read the differences between FFmpeg and Libav here. However, in general, they should work the same. Some cases, FFmpeg builds may be better than Libav builds, or vice versa.
Old 17th September 2014, 15:49   #257  |  Link
fvisagie
Thanks, that explains a lot.
I'd like to stick with what worked for me from the now-dead download link before. Comparing the LSMASHSource.dll size of L-SMASH-Works_r725-g92d69d8.7z I got from there and also looking at the build_info.txt shipped with that version
L-SMASH-Works r725 ( lwinput.aui, lwmuxer.auf, lwdumper.auf, lwcolor.auc, LSMASHSource.dll, vslsmashsource.dll )
Source:
L-SMASH-Works: git-92d69d8 ( https://github.com/VFR-maniac/L-SMASH-Works )
L-SMASH: git-4433160 ( https://github.com/l-smash/l-smash )
FFmpeg: git-87f2d80 ( http://git.videolan.org/?p=ffmpeg.git )
seem to suggest it was built with FFmpeg, correct?
Old 18th September 2014, 02:13   #258  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
r688v2 from this thread. It's dated August 30, 2013, but it was just the first that came up when I searched for old versions.
Old 18th September 2014, 13:05   #259  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
AFAIK, yes.
Old 18th September 2014, 15:14   #260  |  Link
fvisagie
AFAIK, yes.
Thank you.
