9th November 2013, 03:01 | #4562 | Link |
x264 encoding failed
Hi all
i have a probleme with staxrip 1.1.1.0 in my pc at home work fine but in another pc who have 64bit + CPU multi core send me an Error x264 encoding failed ------------------- probleme at the x264 Third Pass this is the log file |
9th November 2013, 21:28 | #4564 | Link |
I'm having a bit of trouble merging these four clips together. I'm thinking it may be because one of the clips has no audio (audio recording was accidentally disabled in camera).
Clip1 = QTInput("0802 Haajuhla 1.MOV", audio = 0).AudioDub(WavSource("Silence.wav")).Trim(0,5290) Clip2 = QTInput("0802 Haajuhla 2.MOV", audio = 1).Normalize() Clip3 = QTInput("0802 Haajuhla 3.MOV", audio = 1).Normalize().Trim(0,20030) Clip4 = QTInput("0802 Haajuhla 4.MOV", audio = 1).Normalize().Trim(0,13000) Dissolve (Clip1, Clip2, Clip3, Clip4, 30) The log file also contains this: Code:
Error opening source ------------------------------------------------------------ Unable to Open Movie, err=-50 : H:\Pakkaamattomat\Process video B temp files\0802 Haajuhla 1.MOV (H:\Pakkaamattomat\Process video B temp files\Process video B_Source.avs, line 3) |
29th November 2013, 18:26 | #4565 | Link |
Startup Problem
Hi Stax...
I've been using StaxRip for years...great work, thanks! I am moving my setup to a new system. OS is Windows Server 2008 (64 bit). Microsoft .NET Framework 4 is installed. I extracted the latest StaxRip into Programs folder. When I try to run it, it immediately fails. There is no startup screen to set locations of templates, etc. What is it looking for before that? Microsoft Visual C++ 2010 is installed...but not Microsoft Visual Basic...Do I need that? Thanks, Chris UPDATE - I think I got it.. I found that some other things were not working either, so I found how to enable .NET framework 3.5.1 and Desktop Experience - I assume the Framework is the one that worked, but I did them both together, so... Then I found this as am using Server 2008 as more of a workstation...it includes instructions for the above. http://www.zdnet.com/blog/igeneration/convert-student-free-windows-server-2008-r2-into-windows-7/5593 Last edited by chrisgwd; 30th November 2013 at 20:54. |
8th February 2014, 00:48 | #4567 | Link |
I have this Problem Today:
Not An Avisynth 2 C Plugin: C:\Users\Thomas\Downloads\StaxRip_1.1.7.0_beta\Applications\AviSynth plugins\Yadif\yadif.dll (C:\enc\VTS_01_PGC_02_1 temp files\VTS_01_PGC_02_1.avs, line 2) I Install Avisynth new but not work again :-( Can everybody help me? |
10th February 2014, 16:33 | #4568 | Link | |
a workaround is to create an avsi loading yadif plugin and modify staxrip template to load the avsi instead of yadif plugin |
4th April 2014, 04:04 | #4569 | Link |
There's a glitch in StaxRip when using DGSource and DGDecNV to decode. When you load the video file (say a 1080i file), open the crop window and crop it the way you want, then add the values to the dgi file, StaxRip glitches and sets the video input resolution to something like 832/32 or another random values. Of course, this is absurd and usually not a possible resolution for an encode. I don't get the glitch too often, but it does happen at random times.
13th June 2014, 22:54 | #4572 | Link |
Unique MKV Titles
Can we Use Different Titles when batch encoding MKVs..... |
13th July 2014, 05:55 | #4573 | Link |
Configuration Problem
I have a configuration problem with my computer and Staxrip. The PC is running Windows Server 2008 R2. I've had Staxrip working just fine for a year or so...but now it's not??? I am encoding blurays to .mkv. It looks like DGAVCIndex indexes properly, then x264 fails the process when loading to encode. I can encode the same demuxed files on anther PC using staxrip. I have demuxed content that I previously encoded using the same set-up that I can no longer encode. So, I am pretty sure it has something to do with an operating system update or something similar, but I don't know where to look. Any thoughts? Thanks, Chris |
12th August 2014, 16:29 | #4574 | Link |
FixBlendIVTC
Hey all, I'm trying to encode some PAL 576i Anime DVD's to x264, because the content on the disk was originally NTSC-J content the frame rate should be 23.976 instead of 25fps so when I do an encode I end up with Ghosting.
http://i.imgur.com/AtWDeXw.jpg <-- example of the ghosting. So I'm trying to use FixBlendIVTC(post=3) to fix it, but it doesent seem to be working in staxrip, I get the error "Script Error: There is no function named "FixBlendIVTC" in T:\test temp files\test.avs line 11" I have in my avisynth plugin directory the required dll's and FixBlendIVTC.avs, can some one help me get this to work? Thanks in advance jse12 |
12th August 2014, 21:00 | #4575 | Link |
Big Bit Savings Now !
chrisgwd and maybe jse12:
I had a similar occasion where two .net 3.5 dependent applications wouldn't start anymore after a recent Windows update (Win7U64). A:Sony Vegas Pro10 32bit, but VegasPro 10 64bit works on the same machine. B:Touchbutton/Volume swiper driver for this particular notebook (ClevoX8100, rebranded as mysn XMG8.c) Uninstalling any .net and installing .net 4.52 brought at least B back for me. For Sony Vegas 10 32bit I am still searching for a solution. StaxRip is one of those apps that need .net 3.5
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 12th August 2014 at 21:02. |
22nd September 2014, 04:08 | #4577 | Link |
Where can I find Stax's source code?
I want to find a way to remove the dialog that asks you to save the project when you close the program. Right now I can't batch encode because of this - I'm using another software to monitor a directory for new files and run stax automatically on that file. |
22nd September 2014, 06:40 | #4579 | Link | |
Practising Schemer
gui, h.264, h.265, hevc, mkv, x264, x265 |
