23rd January 2015, 09:56 | #4641 | Link |
Is there reason why there is no option to delete logfiles after job is done without error?
Also future feature suggestion: Please could you separate encoder/job control from main thread to it's own thread. It would be nice to be able to add jobs and edit options while encoding jobs. After all, there is multiple cores in prosessors these days and internet can be used while encoding, so i believe one could add jobs and edit settings of encoder while encoding. At the moment I need to abort job control, this means I need to manually either remove already done jobs from jobs or delete already encoded files, because I want to add more files to queve, where jobcontrol aborts all job strips so it want to encode whole job queve again, even if it was done couple of videos already. I believe this is related to jobcontrol log files also, because it generates those after each encode, thus remembering what was used at job queve. What I would like to see: suspend queve, browse some new files, add to queve -> resume or if one has powerfull prosessor the just adding while encoding support. Last edited by Jeroi; 23rd January 2015 at 10:14. |
23rd January 2015, 14:37 | #4642 | Link | |
Regarding Job processing I plan to add a option to the start button like "Start in new instance", for threads I would need to rewrite half of the code which will never happen. |
24th January 2015, 12:18 | #4643 | Link |
One more "BUG" that annoys me is template saving. Currently you can select settings and save them as template. How ever there is no option to edit template. I mean when I open template it removes all my edited template settings. I would like to save the template settings again to add edited options to the template.
24th January 2015, 12:24 | #4644 | Link |
After opening and demuxing a vob-source with the option "Merge Files" I get this error message.
StaxRip has crashed! Error failed with exit code 2 StaxRip.ErrorAbortException: Error failed with exit code 2 bei StaxRip.Proc.Start() in C:\Daten\Projekte\VS\VB\StaxRip\General\Proc.vb:Zeile 259. bei StaxRip.MainForm.DemuxVobSubSubtitles(Boolean isVobSource) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:Zeile 2131. bei StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:Zeile 1908. |
24th January 2015, 13:04 | #4645 | Link | ||
24th January 2015, 15:05 | #4647 | Link | |
24th January 2015, 20:30 | #4648 | Link |
Hello.
I try to encode an mkv episode from a tv show to mp4 using the version 1.2.0.1 beta and I get an error right before the compressibility test starts. I am using the 64bit 8 bit x264 encoder. The error is the following: "StaxRip has crashed! Error Compressibility Check Compressibility Check failed with exit code -1 E:\My Documents\Downloaded Programs\Video (Play-Convert)\StaxRip_1.2.0.1_beta\Applications\x264\x264 64-Bit 8-Bit.exe: unknown option -- x26x-binary StaxRip.ErrorAbortException: Error Compressibility Check Compressibility Check failed with exit code -1 E:\My Documents\Downloaded Programs\Video (Play-Convert)\StaxRip_1.2.0.1_beta\Applications\x264\x264 64-Bit 8-Bit.exe: unknown option -- x26x-binary at StaxRip.Proc.Start() in C:\Daten\Projekte\VS\VB\StaxRip\General\Proc.vb:line 259 at StaxRip.x264Encoder.RunCompCheck(String executable, String arguments, String[] logValuesToSkip) in C:\Daten\Projekte\VS\VB\StaxRip\General\x264.vb:line 95 at StaxRip.x264Encoder.RunCompCheck() in C:\Daten\Projekte\VS\VB\StaxRip\General\x264.vb:line 69 at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 1928" I have attached the logfile of the encode along with the avisynth script I am using. This script is from a template I create which I have been using for the past years through my many encodes with the latest stable version we had. This error appears during any file I try to convert only with the latest beta version. If I use the 32bit version of the x264 encoder, there is no error. Can anyone identify the error? Last edited by Lentzeris; 24th January 2015 at 20:42. Reason: add text |
25th January 2015, 02:26 | #4649 | Link |
Couble feature request:
Jobs->ADD: Remember last used folder File batch: Add folder with recursive seek. Issues and needs: Because it annoys when adding files to queve it remembers last opened single file folder but not remember the add files dialog last opened folder. Second one is to help adding more files in single step. If recursive folder adding is added, files on different folders are much easier to add. |
25th January 2015, 09:55 | #4650 | Link |
Video preview is crashing for most videos in latest beta when I use the next avisynth filter:
textsub((LeftStr("Y:\New Movies & Series\Series\American Horror Story\S04E02 - Massacres And Matinees.mkv", StrLen("Y:\New Movies & Series\Series\American Horror Story\S04E02 - Massacres And Matinees.mkv")-4))+ ".ass") The example is for an episode of a tv series, and what I am trying to do is add the .ass subtitle file which has the same name as the video file. This command was working normally with previous versions. This is happening with .srt files as well. If I try to hardcode the subtitle or if I remove completely the textsub filter, there is no error. |
25th January 2015, 16:13 | #4651 | Link | |
(schein)heilig
To prevent the subtitles from showing up automatically (maybe because you understand English well enough and only include them as an optional feature) you need to manually flag the English subs as default:no.
Brother John When lost in BeSweet's options, have a look at the Commandline Reference. DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen! |
25th January 2015, 17:23 | #4652 | Link | ||||
@Lentzeris
Next release fixes some comp check crashes. Quote:
@Brother John Good to see you around and thanks for the explanation, it's added and will be released within the next couple of days. |
25th January 2015, 19:09 | #4653 | Link |
Question about audio conversion
Hello...
About audio....How can I convert from 6ch AC3 to 6ch AAC? In this 1.2 version automatically convert 6ch AC3 to 2ch WAV and then to 2ch AAC.... but I can do the conversion directly copying the command line to a dos window and changing the wav file name to sourcefilename.ac3... Thanks for that great program.... |
25th January 2015, 20:05 | #4654 | Link |
Some ideas and a bug maybe
Hello community...
I've found a bug in audio conversion. For AC3 conversion i've set the encoder automatic and the bitrate to 448 kbit/s but when i started the process, the bitrate is set to 640 kbit/s. Is this a bug? Please update the avisynth filters and all applications to the latest and project x to version 0.91.08. So java isn't required for Staxrip. Nice to see that the development will continued... Greets Pat Last edited by Patman; 25th January 2015 at 20:06. Reason: mistake |
25th January 2015, 20:56 | #4655 | Link | |
@Patman & davizator
I've overhauled audio processing by much hoping to eliminate some reported problems, it just needs a little bit more testing. Quote:
26th January 2015, 02:01 | #4657 | Link |
Here is a test build for everybody having a problem with the previous release or anybody wanting to help removing bugs from the next release coming in in 2-3 days.
https://www.dropbox.com/s/flf1s6x622....01.26.7z?dl=0 I've not taken care migrating settings like in the past so I recommend to delete the content of the settings directory with every build. Last edited by stax76; 26th January 2015 at 02:21. |
26th January 2015, 18:04 | #4658 | Link | |
however there is one minor thing i've notice which is still nice to be able to see at a quick look then having to blind guess the numbers.. the cropping colours (cropping part) seems much better on how its able to change based on the colour of your windows theme but i do wonder if the classic style will come back via a option (hardcoded maybe?) the ffmpeg encoding part seems like a nice idea but a suggestion would maybe add a edit box so the user can add there own options if that's possible? keep up the good work stax76 |
26th January 2015, 19:32 | #4659 | Link | |||
There is a option at Tools/Seetings/System/Menu Style, the menu drawing is from me so I hope it looks OK and works. Quote:
26th January 2015, 21:21 | #4660 | Link |
@Alexander
I tried to answer your private message but for some reason the system don't allow to send it. You can also mail me or use the German doom9 forum, it has a StaxRip support thread too. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
