15th May 2020, 19:17 | #59561 | Link |
if this verification is for your 3D LUT then this is accurate.
but if it changes so much that pretty much means your device is setup very inaccurate which may make creating a 3D LUT hard. but what so ever i highly recommend you to create a gamma 2.4 3D LUT for SDR sources. and feel free to make a screen with control+alt+shift+3 and a colorful scene. what so ever this 3D LUT show you the creators intent. |
16th May 2020, 02:13 | #59562 | Link |
Other than the 2.2 gamma, which should be 2.4 for sdr content, the measurement looks fairly on target.
Disable Calibration in madvr, Set up the dispcal verification screen as follows, and run that and post. We need to take a look at your screen's native behavior. https://imgur.com/a/oTy51ld Use the Default madvr profile drop down from at top. then input the settings exactly.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 16th May 2020 at 02:32. |
16th May 2020, 05:06 | #59563 | Link |
The settings page you put up is unreadable for any inputs to change ?
edit :nvm used an image app to lighten numbers Here you go... https://gofile.io/d/RR6OmU This does not look so good.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65" Last edited by madjock; 16th May 2020 at 05:25. |
16th May 2020, 07:07 | #59564 | Link |
Holy freakn' crap.. Hahahahahha..
If that's what you've been looking at, no wonder you think right = wrong. You need a COMPLETE overhaul First thing, It's EITHER a levels mismatch, as in your TV is expecting 16-235, and receiving 0-255, OR it just natively has a really borked tone curve. I'm reasonably sure it's the FORMER. Since that measured tonecurve shape is the common consequence. Set Picture Style to Monitor Also this is an exerpt from your manual , you need to fix this part first. It looks like you have to set it to -Optimal- on either hdmi 2 or hdmi 3 port https://imgur.com/a/eNmZwok You're going to set gamma to 2.2 gamma on the TV. The SDR LUT will take care of conversion to 2.4 later. Turn off all post-processing settings like picture clean, etc. dynamic contrast. Then go to the 1070 , and you should set to rgb full 444 3840x2160 THEN UNPLUG the HDMI from the GPU, then plug it back in, and check that everythign sticks. NVidia does wonky things sometimes when you change settings, Don't reboot, reboot doesn't work the same as unplugging.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 16th May 2020 at 07:24. |
16th May 2020, 07:18 | #59565 | Link |
I think you'll find the Philips panels are limited range (mine is, so is use limited - full - panel (there is no option to change the TV range)).
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
16th May 2020, 07:32 | #59567 | Link | |
On many newer sets, the PC mode makes an exception for 0-255 when other modes lock to 16-235. Either way, he has a colorimeter, he can measure and know for sure. @ madjock, in your case, it's monitor mode in the picture style setting. I'm actually more surprised madjock was watching that this entire time thinking nothing was wrong, kekekeke... Here is a reference for what the TV's native tuning should approximate Before any software correction is done. This is my TV using only the 11point gamma. I watch movies @ 60 nits in the dark. https://imgur.com/a/g9Mxt5K
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 16th May 2020 at 07:40. |
16th May 2020, 07:50 | #59568 | Link |
There is no PC mode on my Phillips panel. There is a monitor mode, but that just switches off any/most processing. From what I have read, and experienced, my Phillips, at least, is always fixed at limited range.
If there is something I have missed, I'd be grateful for any additional insight...
16th May 2020, 07:59 | #59570 | Link | |
Ghetto | 2500k 5Ghz |
16th May 2020, 08:02 | #59571 | Link |
I agree, but It's still limited range - checked and triple checked with test files and changing the levels in Madvr.
16th May 2020, 08:07 | #59573 | Link |
set the GPU to full range load this page: http://www.lagom.nl/lcd-test/black.php
and tell me what you see. |
16th May 2020, 08:13 | #59574 | Link |
In chrome only upto 20 is visible (the whole of the bottom row is visible) so it's being clipped.
16th May 2020, 08:20 | #59576 | Link |
Yep, tested in both.
I knew this before I decided to buy. I now have it properly configured. For the money, I rate this panel (and IMHO, it is certainly a step up from the Samsung KS8000 for SDR).
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 16th May 2020 at 08:38. |
16th May 2020, 09:06 | #59578 | Link |
if you use the device outside madVR you set madVR to full range and the GPU to limited.
if you only care about madVR and the rest can be clipped you can use the madVR limited GPU full version. do your self a favour and just use GPU limited. |
16th May 2020, 09:07 | #59579 | Link |
Madvr limited (although sometimes get a bug in madvr where it will still output full range, so I use custom 15.5 - 235...yes, I know it should be 16 in theory), and GPU full, then run some test files to adjust TV settings to your preferences.
As far as using calibration measurements etc, the other guys can help there. EDIT - see, ask a question, and get two different answers lol. Each to their own.
16th May 2020, 09:09 | #59580 | Link | |
As I said in the post on the previous page, DO those settings i mentioned, Unplug hdmi and replug, don't reboot. reboot does nothing.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 16th May 2020 at 09:12. |
