Go Back   Doom9's Forum > General > DVD2AVI / DGIndex
Old 21st January 2010, 01:48   #1061  |  Link
TheProfosist
TheProfosist's Avatar
Originally Posted by neuron2 View Post
Thanks. I am trying hard to give people their $15 worth.
its definatly worth it so far just for the VC-1 compatibility not to metion everything else
TheProfosist is offline   Reply With Quote
Old 21st January 2010, 01:51   #1062  |  Link
Originally Posted by TheProfosist View Post
whats the easiest way to tell if the material you have is 3:2 pulldown?
That's not easy to answer, because you have hard and soft pulldown. If it is hard pulldown, then only stepping through the video and examining the fields will be reliable. See the first two questions here for how to examine your video:
http://neuron2.net/faq.html
If it is soft pulldown, then look at the coded and playback counts in the Info dialog. If you have playback = 1.25 * coded, then you have pure 3:2 pulldown. You can also look at the Film % field and if it is close to 100% then you have 3:2 pulldown. But the Film % is not yet implemented for AVC.
like how can i tell the difference between something being interlaced and 3:2 pulldown?
See above.
Old 21st January 2010, 02:07   #1063  |  Link
TheProfosist
so from this picture i would use fieldop=1 instead of deintelace for TFF?
http://bayimg.com/NajBpaaCN
am i going to be more likely using fieldop=1 that deinterlacing? because previously i deintelace all content and didnt even know about 3:2 well i had heard about it but thats it.
and what would it look like if im supposed to leave it at 29.970 and deintelace instead
sorry about all the questions im knew to someof the ideas but so far yoiur programs is better and faster than what i was previously using
Old 21st January 2010, 03:16   #1064  |  Link
tormento
Acid fr0g
tormento's Avatar
You opened more files than the program supports and I guess that a resulting memory overwrite caused the license error problem. Does it ever happen when loading less than the supported 512 files?
The same thing does not happen if I put all the files in a single directory. Strange enough!
I don't know what a chapters.txt file is or what it should contain.
It is something like
CHAPTER01=00:00:00.000
CHAPTER01NAME=Living Weapon
CHAPTER02=00:05:00.750
CHAPTER02NAME=A Better World
CHAPTER03=00:09:31.937
CHAPTER03NAME=Aboard Serenity (Main Titles)
CHAPTER04=00:14:49.088
CHAPTER04NAME=Going for a Ride
and so on. It is used in many container muxer and, to me, every single file imported should give a new chapter, at least for the first release. The best thing should be the possibility to "collapse" many files in a single chapter at will, giving full edit capability.
If you provide stream samples, I can tell you.
I'm trying to catch the files you need.
It's possible and it's already on my to-do list.
Thanks!
@turment on Telegram
Old 21st January 2010, 04:17   #1065  |  Link
@TheProfosist
That's pure soft 3:2 pulldown, so you need fieldop=1.
You can see that the film % is 99.99.
It's all covered in the documentation.
Old 21st January 2010, 04:26   #1066  |  Link
TheProfosist
@TheProfosist
ok thanks i just want to make sure because im am going to have to re-encode a ton a material that that should have been applied to but only a de-interlacer was applied
i will report back with results
thanks again
Old 21st January 2010, 04:28   #1067  |  Link
Where did you get that material and what is it?
Old 21st January 2010, 05:47   #1068  |  Link
TheProfosist
so the content is from DVD, BD, or RAW(high quality/bitrate encodes that use a range of formats)
for most 29.970i content i was just deinterlacing using TDeint and after indexing a few of the DVD i have found that I should have reversed the pulldown instead.
Old 21st January 2010, 08:24   #1069  |  Link
Efenstor
The max is currently 512. I'll increase it to 5000 in the next build.
Thanks!
Efenstor is offline   Reply With Quote
Old 21st January 2010, 11:16   #1070  |  Link
TheProfosist
after reversing the pulldown there is stil some lines left over do i need to run a deinterlacer as well? if so can this be done using DG NV tools? a picture is below
http://bayimg.com/GAjdnaAcN and http://bayimg.com/gAJdoAacN
sorry about the weird resolution the program was acting weird the video is fine resolution wise 616x480 no black borders at all
Old 21st January 2010, 12:46   #1071  |  Link
MOS-Marauder
Somebody recently posted in a MeGUI thread using only 3 instead of 4 memory slots helped making NV tools work.
I'll have a card shortly, it will be:
G512P Sparkle (R) 9400GT 512MB DVI/TV
I'll test it on Win 7 Ultimate 32bit, I might also be able to test it on XP since I should still have my old XP partition. If it's related to the memory on the card, how about then testing source files with smaller resolution?
It was me U had 4 x 2 GB Ram in my 4 Slots and alway got Driver Crashes. Removing one helped me.
(Win7 64 Bit)
The Resolution doesnt matter in my case...it happened on SD and HD Sizes.
Chris
MOS-Marauder is offline   Reply With Quote
Old 21st January 2010, 14:01   #1072  |  Link
well i encode anime. go to my website link should be in my sig.
I asked where you got the file and you point me to your site pushing torrents! Struck for rule 6 and signature link deleted. Do not restore it.
Old 21st January 2010, 14:24   #1073  |  Link
Alf Bundy
Alf Bundy's Avatar
I have a problem with DGindexNV 2003 (I don't know with previous versions, I only have my license since yesterday).
I tried my first encode using DGindexNV, but the result ended out of sync.
But not a constant or progressive delay.
At some points in the episode, dialogue is suddenly cutted and audio continues further, generating an instant few seconds delay with the video.
This problem is not present in the source files (MPG from PVR = Mpeg2 + MPA 48Khz stereo 320kbps .mpg).
So I tried using the free DGindex to index my source files and I discovered something strange :
With DGindex, demuxed audio is 128.519 Kb for 54 min 50 sec. (wich is correct and does not produce sync problem.)
With DGindexNV, demuxed audio is 127.650 Kb for 54 min 27 sec.
I have 3 different episodes, and the same problem happens all the time with DGindexNV.
Is it possible that DGindexNV 2003 wrongly demux MPA ?
Alf Bundy is offline   Reply With Quote
Old 21st January 2010, 14:31   #1074  |  Link
Not likely but possible. Please post a link to a sample file such that when demuxed with DGIndex and DGIndexNV audio streams of different lengths are produced.
I just did a test demux of a DVD and the audio streams demuxed by DGIndexNV and DGIndex were binary identical.
Old 21st January 2010, 15:28   #1075  |  Link
TheProfosist
my site is just a blog i blog on it yes details of my release are on my blog because its my blog sorry. but i encode initially for my self and my personal use. and i had the link im my sig becuase its my site/blog no different than others having links to their sites or blogs.
i wasnt trying to push torrents on u just to show you what i had previously encoded and how it was done. ignore the dl links and i wont put the link in my sig its not all that important i get enough stuff daily already (not because of that exact thing but the overall situation)
but for source it comes mostly from DVD (usually R1 or R2J) or BD (usually RA or RAJ) and 99% of it is anime.
what i used to do was just deinterlace with TDeint(custom settings or cource) but after indexing a few more dvds i foiund that i should reverse the pulldown instead
after reversing the puldown usiong fieldop=1 after reversing there is stil some lines left over do i need to run a deinterlacer as well? if so can this be done using DG NV tools? a picture is below
sorry about the weird resolution of the pics the program was acting weird the video is fine resolution wise 616x480 no black borders at all
AVS script:
LoadPlugin("C:\Program Files (x86)\megui\tools\dgindexnv\DGDecodeNV.dll")
DGSource("C:\TEMP\Lain\07 - Cvt Vid\01.track_224-002_Track1.dgi",resize_w=616,resize_h=480,fieldop=1)
once again sorry about the sig link im not trying to offend you or go against site rules mabye im just nieve? but neverthe less im greatful for your and the communities continued help
Old 21st January 2010, 15:32   #1076  |  Link
@Profosist
Stop asking about this stream or you'll get a rule 16 strike and be suspended. Also, followup about rules to PM or you can get a rule 3 strike.
Old 21st January 2010, 16:15   #1077  |  Link
Alf Bundy
Alf Bundy's Avatar
Here is a sample (100Mb - 1min 36") that produces different lenght and size audio when demuxed with DGindex or DGindexNV :
http://dl.dropbox.com/u/2137721/0120...omposite_1.mpg
Audio lenght when demuxed with DGindex = 1min 36" (like the source)
Audio lenght when demuxed with DGindexNV = 1min 29".
This sample was cutted from a 1Gb file with DGsplit 1.0
I can post more samples if you need.
I made 2 scripts to test this sample (scripts played with MPC-HC).
DGindex :
video=DGDecode_MPEG2Source("E:\Recode\DGindex.d2v",cpu=4)
audio=MPASource("E:\Recode\DGindex Tc0 L2 2ch 48 320 DELAY -80ms.mp2")
AudioDub(video,audio)
DelayAudio(-0.080)
ConvertToYV12()
-> Sync is OK like in the source sample.
DGindexNV :
video=DGMultiSource("E:\Recode\DG NV.dgi")
audio=MPASource("E:\Recode\DG NV Tc0 L2 2ch 48 320 DELAY -80ms.mp2")
DelayAudio(-0.080)
ConvertToYV12()
-> at 1min 21", audio "jumps" and the rest is out of sync.
About the video, both indexers always produce the same amount of frames.
Old 21st January 2010, 16:16   #1078  |  Link
@Alf Bundy
That's a great problem report. I wish all were as complete. I'll investigate and report back.
Old 21st January 2010, 19:56   #1079  |  Link
meatwad
meatwad's Avatar
Originally Posted by MuLTiTaSK View Post
@neuron2
i got good news to report DGIndexNV IS WORKING WITH StaxRip 1.1.4.1
settings
Hi, I followed all of the steps as indicated in the images, but StaxRip 1.1.4.1 crashes after the indexing is done. It will still work as long as I don't close the crash window. It's crashing the nvcuda.dll:
Problem signature:
Problem Event Name: BEX
Application Name: StaxRip.exe
Application Version: 1.1.4.1
Application Timestamp: 4b4b9949
Fault Module Name: nvcuda.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4b4c13da
Exception Offset: 0c8143e9
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Sometimes it doesn't say nvcuda.dll unloaded and instead gives the version number. Also, after it's done encoding the video it will crash again and you're forced to exit the program. My OS is Windows 7 Ult. 64bit and I wonder if that's why I'm getting this error? Have you tested it with a 64 bit OS yet?
meatwad is offline   Reply With Quote
Old 21st January 2010, 20:25   #1080  |  Link
stax76
stax76's Avatar
@meatwad
DGSource support was added in test build 1.1.4.3 so you need a newer build.
