6th August 2016, 04:01 | #44 | Link |
I'm Siri
Kind of, some components like SATD were coded in asm and incompatible with high bitdepth, gotta rewrite them completely
And 16bits support is sort of practical still Floating point support is much harder, not sure if it's possible to implement floating point support and integer support both within a single plugin vectors are like, int vx, int vy, int sad for both uint8_t and uint16_t And SAD(sum of absolute differences) for floating point inputs are also floating points obviously, gotta do some reinterpret_cast tricks here Last edited by feisty2; 6th August 2016 at 04:07. |
6th August 2016, 07:46 | #45 | Link |
y8 is possibly easy, possibly working with three planes is hardcoded now.
16 bit/float support is hard (=takes time), but even this modding to YV24 took days and was a nightmare. I have already put high bit depth supporting code here and there and my last internal version has a working MSuper in 16 bits as a first step. And I think I will not cut the possibility of the float version, just for my curiosity (inspired by feisty2) |
6th August 2016, 08:04 | #47 | Link |
I'm Siri
you're gonna get into the floating point SAD trouble if you do plan to mess with fp support,
I did a nasty reinterpret_cast trick to stuff fp SAD in vectors Code:
static inline auto _fakeint(float a) { return reinterpret_cast<int32_t &>(a); } static inline auto _back2flt(int32_t a) { return reinterpret_cast<float &>(a); } |
6th August 2016, 13:33 | #50 | Link |
I never said that I was modding SMDegrain. Ask Dogway if he's interested, I'm sure he can do more efficiently since it's his script. A while back I gave him a few suggestions (post 87-89) but nothing came of it.
Please do not cross-post. SVPflow has nothing to do with this thread. |
15th August 2016, 01:28 | #54 | Link | |
planar = IsYUY2(input) ? true : false so it should work like qtgmc in yv16 and yv24, especially with http://pastebin.com/JtWFN124
See My Avisynth Stuff |
15th August 2016, 12:51 | #55 | Link | |
The old version gave "image heights don't match" when using lsb=true because it assumed the dimensions of YV12 subsampling. |
16th August 2016, 20:44 | #56 | Link |
After-before holiday release for early adopters
16th August 2016, 21:08 | #57 | Link |
47.952fps@71.928Hz
Oh cool, didn't even notice an update for FFTW.
Looking at the Release Notes, it's not critical to little old me.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
16th August 2016, 23:42 | #59 | Link | |
47.952fps@71.928Hz
But, it's good to know that the update is making rounds. For future reference, I'll make note of it.
