22nd February 2017, 15:39 | #42661 | Link |
Cpu is an old 4 core i5 760 OCed to @3800.Even with bilinear chroma I can't play high bitrate 4k with Madvr.You see the problem?I can play 4k sources with low bitrate and NGU med chroma though.(GPU is RX 470)
Edit: The 4k file in the example is ~50Mbps.If nothing happens I guess I can settle to 30Mbps and less with ngu med on chroma. Generally speaking it's not a universal solution.Solution would be dxva(native) support.You paid for your card to do HEVC decoding. Last edited by Damien147; 22nd February 2017 at 15:48. |
22nd February 2017, 15:44 | #42662 | Link |
Nope that System wont cut the minimum requirements we talking 2nd Generation Core I5 at least aka Sandy Bridge IPC + Instruction set.
Also overall MadVRs Shader code is known not to be as efficient on AMDs Driver and Sahader Compiler as it is on Nvidias Driver and Shader Compiler per cycle but also here the RX 470 is overall to weak 30 Mbps is a much more sane max depending on the temporal complexity and decoder efficiency 50 Mbps with even higher Temporal based peaks is hardly anymore in the balpark for that IPC with only 4 Cores.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 22nd February 2017 at 16:01. |
22nd February 2017, 15:56 | #42663 | Link |
With the OC I get 2nd Generation Core I5 performance.I don't have problem anywhere else.I can play everything I throw there from hd to 30Mbps 4k with NGU med.I need a better reason to upgrade cpu.
I am not complaining in the example for the load,I am complaining for the dropped frames and also for the NO benefits in comparison with EVR.Useless high cpu load. Last edited by Damien147; 22nd February 2017 at 16:00. |
22nd February 2017, 15:56 | #42664 | Link | ||||
High bitrate 4K HEVC decoding via CPU is *very* demanding. Every current CPU will struggle with that. Maybe the fastest can do it (barely), but I would expect CPU usage to be near 100%. If you have near 100% CPU usage when playing a 4K HEVC file, then most probably you're using software/CPU decoding. If you have near 0% CPU usage, you most definitely are using hardware decoding. So if you look at your madVR vs EVR screenshots, you can see that your madVR screenshot must be from software decoding and your EVR screenshot must be from hardware decoding. My recommendation is to use "DXVA copyback". But "DXVA native" should work fine, too. Decoding a video file and *processing* it runs through totally different hardware circuits, so it doesn't really have anything to do with each other. If the decoder doesn't manage to decode the video fast enough, then even Bilinear won't help, because Bilinear vs NGU is running on the Pixel Shaders, while video decoding has nothing to do with Pixel Shaders. |
22nd February 2017, 16:14 | #42666 | Link | |
If your code isn't excellently Multithreaded and every cycle optimized you should never try to overdo that and go above ~80% But overall it still depends on the whole System configuration and latency and you have to find out what your system is capable of at that Edge and how well you tuned it
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 22nd February 2017 at 16:37. |
22nd February 2017, 16:23 | #42667 | Link |
@Madshi
I pointed the software and hardware decoding thing. I am not complaining for the high cpu load specifically but for the whole result.If you suggest DXVA copyback then ok,I'm gonna use that but: With dxva(native) and 10 bit HEVC I get black screen.With EVR and dxva(native) for the same file I don't get black screen and file plays well. With dxva(copyback) and 10 bit HEVC I get dropped frames and picture slows down and ''skips''. Yes it's a polaris gpu but if I am the only one ignore me. @pose Using latest official mpc-hc.Gonna try nightly to check.Try higher than 30Mbps 4K HEVC . Last edited by Damien147; 22nd February 2017 at 16:40. |
22nd February 2017, 16:47 | #42669 | Link |
Here you are.dxva(copyback) http://imgur.com/a/doUFv
I can play the file well with ''none''. |
22nd February 2017, 16:51 | #42670 | Link |
Are you sure that's really dxva copyback? Because the decoder queue is almost empty, which means that the decoder is not fast enough. How high is CPU usage in this situation? Does DXVA copyback run smoothly when using EVR?
22nd February 2017, 17:07 | #42671 | Link |
Yes,sure.Here is my cpu usage with DXVA copyback http://imgur.com/a/X4Px4 .DXVA copyback with EVR seems better.
With hardware decoder to none I can play well this file with Madvr and same settings.It's a lower bitrate 4K HEVC. Last edited by Damien147; 22nd February 2017 at 17:10. |
22nd February 2017, 17:13 | #42672 | Link |
Damien147, just tested 4K 60FPS 75.6 Mb/s bitrate HEVC video. Latest MPC-HC nightly build. Latest GPU drivers. Win7 64bit. Intel i5 ivy bridge 3.6 Ghz + RX 470.
Hardware decoder: none (software). 100% load on 4 cores. Hardware decoder: DXVA2 (copy-back). 35% load on 4 cores. Hardware decoder: DXVA2 (native). Black screen. Judging by my OSD stats i can tell, that if you have 100% load on all of your CPU cores then it will BOTTLENECK madVR playback. If your CPU has some room then VIDEOCARD is going to bottleneck madVR playback. I also noticed that you have SMOOTH MOTION ON. Try disabling it. On my 60FPS sample it made big difference in rendering times. I also need to remind you that you need to RESTART your video player after you change LAV's hardware decoder settings or changes wont apply. Last edited by pose; 22nd February 2017 at 17:16. |
22nd February 2017, 17:28 | #42673 | Link | |
22nd February 2017, 17:33 | #42674 | Link | ||
Tried mpc-hc nightly and I get same result.So for now I'm gonna stick with hardware decoder to none and low bitrate 4k HEVC..... dxva(copyback)plays well with you?No slow downs and ''skips''? Quote:
Seems smooth with some slow down ''spikes'' I think.Frame rate gets slowed to 21 from 23.976,so it's not ''smooth''. Last edited by Damien147; 22nd February 2017 at 20:31. |
22nd February 2017, 17:41 | #42676 | Link | |
Plays perfectly. Last edited by pose; 22nd February 2017 at 17:44. |
22nd February 2017, 17:43 | #42677 | Link |
QB the Slayer
@Damien147,
Why is defrag running while doing this? If that is running on the drive you are trying to play back videos from it can cause all sorts of problems. I'm not suggesting it is the problem, but you really should be trying to troubleshoot without that running. QB
22nd February 2017, 17:53 | #42678 | Link | |||
If it plays perfectly with same gpu then I am the problem but I don't know where.... Quote:
22nd February 2017, 18:06 | #42679 | Link |
Guys,till now I was avoiding Display Driver Uninstaller but I am gonna use it now because @pose with same gpu has smooth playback with DXVA(copyback).I am gonna report back.
22nd February 2017, 18:08 | #42680 | Link | ||
Although, personally I'd prefer all values to be as unlimited as possible, if only for experimental purposes. Thanks! |
