26th December 2017, 13:40 | #5801 | Link |
What to use for master-display when MediaInfo reports 'Display P3' ?
Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Last edited by Selur; 26th December 2017 at 13:49. Reason: added mediainfo output |
26th December 2017, 17:45 | #5802 | Link | ||
powered by Google Translator |
27th December 2017, 21:22 | #5805 | Link |
Pig on the wing
In the docs, it says that --hdr-opt should be used with AQ-mode on. --tune grain disables AQ-mode, so is it OK to use --hdr-opt anyway or better to leave it out? Also, it is said that the input video should be 10-bit 4:2:0. Is it safe to input 16-bit video (because of processing things in Vapoursynth in 16-bit land) if the original source is 10-bit 4:2:0 and signal --input-depth 16?
2nd January 2018, 05:49 | #5807 | Link | |
2nd January 2018, 15:23 | #5808 | Link |
x265 2.6+24-69cfe46e8a3b – merge with stable
Several fixes e.g. in analysis and VBV handling; added support for RADL pictures; renamed options: Code:
--radl <integer> Number of RADL pictures allowed in front of IDR. Default 0 ( --analysis-reuse-mode <string|int> removed ) --analysis-save <filename> Dump analysis info into the specified file. Default Disabled --analysis-load <filename> Load analysis buffers from the file specified. Default Disabled |
2nd January 2018, 18:24 | #5809 | Link | |
Anyone have some context to offer? |
2nd January 2018, 19:55 | #5810 | Link | |
2nd January 2018, 21:40 | #5813 | Link | |
I can see how that could reduce keyframe strobing and improve efficiency with fixed cadence encodes. Are there any downsides to it? Any compatibility issues? |
3rd January 2018, 03:53 | #5814 | Link |
It actually sounds like a feature for closed GOP, because the importance of closed v.s. open GOP is during decoding, frames that are decoded after an IDR frame can be presented before it while only requiring data (in the decoded picture buffer) from the current GOP. Any RADL B frames would simply be dropped when seeking to the IDR frame.
madVR options explained |
4th January 2018, 03:48 | #5815 | Link |
from 2.6(+22 and +24), it seems some problem in my computer.
y4m [info]: 1920x800 fps 24000/1001 i420p10 unknown frame count raw [info]: output file: D:\x265-workspace\output\harrypotter2001\00001.1080.hevc x265 [info]: HEVC encoder version 2.6+24-69cfe46e8a3b x265 [info]: build info [Windows][MSVC 1900][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [warning]: Turning on repeat-headers for HDR compatibility x265 [info]: Main 10 profile, Level-5.1 (High tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(25 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 2 inter / 2 intra x265 [info]: ME / range / subpel / merge : star / 25 / 5 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 1 / 360 / 40 / 5.00 x265 [info]: Cb/Cr QP Offset : -2 / -2 x265 [info]: Intra 32x32 TU penalty type : 1 x265 [info]: Lookahead / bframes / badapt : 60 / 9 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 x265 [info]: References / ref-limit cu / depth : 5 / on / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 0.9 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-19.0 / 0.70 x265 [info]: VBV/HRD buffer / max-rate / init : 100000 / 100000 / 0.900 x265 [info]: tools: limit-modes rd=4 ssim-rd rdoq=2 psy-rdoq=8.00 limit-tu=3 x265 [info]: tools: signhide tmvp b-intra lslices=4 deblock(tC=-1:B=-1) Error: fwrite() call failed when writing frame: 77, plane: 0, errno: 32 Output 82 frames in 139.43 seconds (0.59 fps) DONE 2.5 is OK, and sometimes 2.6 is OK too. Anybody know what's wrong? Windows 10 64bit Update: 2.6+17 was OK. 2.6+22/+24 was wrong. source stream from vspipe.exe Last edited by fisherwei; 4th January 2018 at 08:05. Reason: update |
4th January 2018, 16:12 | #5817 | Link | |
The term "current GOP" can be a bit confusing when we're talking about leading pictures. RADL B pictures require the IDR picture (the first frame of the next GOP) as a reference. But the decoder knows this already, as the NAL unit type of the IDR picture will indicate that leading pictures (from the previous GOP) follow the IDR picture in decode order (it will be an IDR_W_RADL as opposed to an IDR_N_LP - IDR with no leading pictures). |
4th January 2018, 16:45 | #5818 | Link |
x265 v2.6+26-b4edf9b44d23 (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/branch/default DL Link to v2.6+26-b4edf9b44d23 have been fixed. Last edited by Barough; 6th January 2018 at 18:02. |
4th January 2018, 23:12 | #5819 | Link |
Am I right in presuming that the latest "Meltdown" security issue, and the implemented KPTI fix, will not impact x265 much or at all?
From what I understand, its only multiple/regular kernel calls/ints that will cause a slowdown (TLB flush), and presumably x265 doesnt do many? (only file read and writes + text output) Although for me at least, I have Haswell (soon to be 8700k), so it has PCID, which will mitigate TLB flushes. Cheers Divxmaster |
5th January 2018, 01:47 | #5820 | Link | |
"C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m "D:\x265-workspace\output\harrypotter2001\00001.1080.vpy" - | "D:\x265-workspace\bin\x265\x265-2.6+24-69cfe46_vs2015-AVX\x265.exe" --y4m --pool "15,-" --preset slower --tune ssim --profile main10 --level-idc 5.1 --crf 19 --cbqpoffs -2 --crqpoffs -2 --rc-lookahead 60 --me 3 --subme 5 --merange 25 --b-adapt 2 --bframes 9 --ref 5 --aq-mode 3 --aq-strength 0.9 --qcomp 0.70 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --limit-modes --limit-refs 2 --output-depth 10 --rd 4 --rdoq-level 2 --psy-rd 2.0 --psy-rdoq 8 --ssim-rd --deblock -1 --no-sao --no-open-gop --no-rect --no-amp --no-strong-intra-smoothing --no-rskip --tu-intra-depth 2 --tu-inter-depth 2 --ctu 32 --limit-tu 3 --max-tu-size 32 --qg-size 32 --b-intra --weightb --rdpenalty 1 --keyint 360 --min-keyint 1 --vbv-bufsize 100000 --vbv-maxrate 100000 --hdr-opt --aud --hrd --chromaloc 2 --max-cll "552,190" --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --log-level 2 --csv "D:\x265-workspace\output\harrypotter2001\00001.1080.csv" --output "D:\x265-workspace\output\harrypotter2001\00001.1080.hevc" - Code:
import vapoursynth as vs core = vs.get_core() video = core.lsmas.LWLibavSource(source=r'E:\Harry.Potter.und.der.Stein.der.Weisen.2001.MULTi.COMPLETE.UHD.BLURAY-NIMA4K\00001.m2ts') video = core.std.CropRel(clip=video, left=0, right=0, top=280, bottom=280) video.set_output() |
