11th January 2016, 14:47 | #35121 | Link | |
(1) The Intel MediaSDK decoder cannot be loaded for some reason (I doubt it works on XP, for example) (2) The MVC1 media type signals an incompatible stream or is otherwise damaged LAV Source doesn't verify case (2), it just sends the data that is contained in the MKV file, so its possible that there is something in there the decoder doesn't like.
11th January 2016, 15:20 | #35123 | Link | |
There's a keyboard shortcut section on the left part of the config interface of madvr.
11th January 2016, 15:25 | #35124 | Link |
If you are using CUVID you should switch to DXVA2 Copy-Back. Nvidia drivers are broken on Win10 when multiple things use openCL.
MPC-HC 2.2.1 |
11th January 2016, 15:28 | #35125 | Link |
Here is a debug version, it should leave a log on your desktop:
http://files.1f0.de/lavf/LAVFilters-0.67-57-debug.zip
11th January 2016, 16:03 | #35126 | Link | |
your biliteral resizer doesn't do things like that. |
11th January 2016, 16:07 | #35127 | Link |
I have a couple of questions related to the New 3D support.
You mention ' Make sure your OS has 3D enabled in the control panel'. By this are you talking about simply having 3D vision enabled in the NVidia control panel or something else? Also is there any way 3D support will be added for windows 7? |
11th January 2016, 16:17 | #35128 | Link |
I have the exact same problem. On my Nvidia based rig it will not pickup the MVC and only plays the AVC content. On my Intel GPU machine it plays the same MVC content (albeit with some stuttering, but it is a Haswell NUC so that could be the issue). Seems to be an Nvidia issue somehow.
11th January 2016, 16:18 | #35129 | Link |
newer operation systems have an option like this: http://abload.de/img/3doptionx4sj5.png
11th January 2016, 18:54 | #35130 | Link | ||||||||||||||
11th January 2016, 19:04 | #35131 | Link | |||
With ffdshow, madVR behaves the same way if "automatically activate deinterlacing when needed" is disabled; if it is enabled (default) madVR switches the display to 50 Hz regardless of ffdshow's "Double framerate" option state. Quote:
(Thanks for your patience)
Windows 8.1 x64 Magically yours Raistlin |
11th January 2016, 19:18 | #35132 | Link | |
Shouldn't 24fps video doubled by yadiff be 48fps? Why are you getting 50?
madVR options explained |
11th January 2016, 19:46 | #35134 | Link |
Because it uses D3D11 to support 3D output on all GPUs, a feature which is only available in Windows 8 or newer.
11th January 2016, 19:56 | #35135 | Link | ||
i can confrim this also. it happened right after i updated. also this happens all the time Quote:
11th January 2016, 20:16 | #35136 | Link | |
To clarify that, if I understand it correctly, the new feature uses / needs DirectX 11.2, which in fact is only available with Windows 8.1 or Windows 10. Thx, NanoBot |
11th January 2016, 20:55 | #35138 | Link |
Ah, so madVR sees a 25 fps source and thinks Reclock will slow it to 24 fps but LAV doubles the frame rate so Reclock leaves it alone. madVR sets the refresh rate to 24Hz but then has 50 fps video to play?
11th January 2016, 21:10 | #35139 | Link |
Thanks for the latest version of MadVR! I guess now I have a reason to upgrade from Windows7? I guess I am forced to get Win10 or Win8 if I want to use MadVR for 3d blurays when they are supported? I guess it's not that big a deal for me as I have a standalone bluray player.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
