14th June 2013, 19:28 | #17441 | Link |
I just checked and the one from BD3D2MK3D is identical to the one from MVC Player (at least the version I have). I'm not familiar with a package called StereoPlayer -- but I did purchase StereoscopicPlayer, which has an exe called stereoplayer.exe, which I'm guessing is what you mean -- and that package doesn't include DirectshowMVCSource.dll. I've only seen one version of that DLL.
[Edit] I iust downloaded the latest version of MVC Player just to check -- and the DLL in that one is identical as well. Last edited by jdobbs; 14th June 2013 at 19:43. |
14th June 2013, 23:26 | #17443 | Link |
[06/14/13] BD Rebuilder v0.44.09 (beta) [14:57:25] Source: WARM_BODIES - Input BD size: 43.34 GB - Approximate total content: [04:01:05.116] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [14:57:34] PHASE ONE, Encoding - [14:57:34] Processing: VID_00042 (1 of 23) - [14:57:34] Extracting A/V streams [VID_00042] - [15:11:40] Reencoding video [VID_00042] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 140,640 frames - Bitrate: 15,563 Kbs - [15:11:40] Reencoding: VID_00042, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.44.09 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [15:22:28] - Failed video encode, aborted ---------------- - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.7.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3326], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.44.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok any ideas? |
15th June 2013, 02:08 | #17445 | Link |
@wakko709
I'm curious as to why you keep repeating the stats from Inspect for each failed encode? When a fail happens it's displays in the log already. When multiple fails, check system heat, cleaning your Optical Drive, check the cables, clean the disk, or perhaps a new Optical drive is needed.
16th June 2013, 04:38 | #17447 | Link |
Hello JDobbs,
Coming back to Die Hard 4: I've chosen to check it again. I used Full Backup except the Warnings are there and I cannot uncheck them because they don't show in the list. The extra "Black Hat Intercept Game" (extra) is also there, fully functional, which I want. If I have BD-RB (now 44.14) set to use Movies & Menus (Auto-Blanking Extras) then Warnings are there to be blanked. I also uncheck everything to do with the "Black Hat Intercept" game, so all parts won't be blanked. When I burn this project to a RW disk, my LG Player, when selecting the Instructions from the "Black Hat" menu, only display "Level 4 Instructions" (very quick flash past) which is the very end of the video. The Full Backup mode allows to see the Level 1 instructions and allows stepping though to 2, 3 and 4...then to the main menu of the "game". So, something it being "lost" or overwritten...or ignored in the Movies and Menus process. It seems?? I've also noticed "00049.m2ts" which is where the video "Instructions" are, is a different size from the original. 1.20MB processed with Movie & Menus. 1.25MB for the original. I'm guessing some padding stuff or instructions for BD?? I haven't included any logs because all looks "normal". If you would like anything more, let me know...as per usual. Thanks.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 16th June 2013 at 04:41. |
16th June 2013, 08:14 | #17448 | Link |
i have 2 languages selected.
then bd rebuilder states: input size: 27,97GB (i want to resize to BD25) then i deselect one language, it is again 27,97. is there any possibility to check if it fits on a BD25 w/o reencoding video, before it starts to reencode? so i want to check before if 2 languages fits into BD25 or only one, or if it has to be reencoded anyway. |
16th June 2013, 08:18 | #17449 | Link | |
16th June 2013, 12:56 | #17451 | Link |
@longtom
In your case input size is the size of your movie, Movie Only. To accomplish what you want, BD-RB would have to demux every stream in the movie, add up the sizes for your selections and overhead. If you didn't like the new size and changed something it might want to start again, as the job changed. If you really want to what you plan just set an oversized custom target and FORCE_NOENCODE=1 in your config file. This will give you the actual size of your settings and shouldn't take too much time. |
16th June 2013, 13:40 | #17455 | Link |
hello
as could be done, that bdrebuilder convert mpeg2 to mpeg4 files, without having to dial BD50 to BD25, BD50 eg to BD50 (force encoding). Many movies come in and want to convert mpeg2 to mpeg4. I'm also checking that import dvd function, does not take the whole structure, and the same extras missing quoted above ... it could force the process mpeg2 to mpeg4, without having to choose dvd9 to dvd5 and dvd9 to dvd9 maintain I tried to put FORCE_ENCODE = 1 but I can not |
16th June 2013, 14:18 | #17457 | Link | |
16th June 2013, 14:52 | #17459 | Link | |
DVD_IMPORT_THRESHOLD=1 With that setting, any title that is at least 1 minute long will be included in the DVD import. This setting is documented in the HIDDENOPTS.TXT file. Just a warning, with a threshold set that low you're likely to get some "junk" like previews and warnings included in your import. It varies from disc to disc. Last edited by jdobbs; 16th June 2013 at 14:55. |
16th June 2013, 15:00 | #17460 | Link | |
indeed, it would be possible to add a command to convert (dvd 25fps) to 23,976, to 24 and vice versa, to well, take advantage of the audio and subtitles and more easily mounts to make. ??? |
