25th October 2012, 22:46 | #801 | Link |
Software Developer
Okay, after some debugging I found the cause of the issue!
When FAAD2 prints out the current Progress, it first writes the text "[x%] decoding <filename>" into an internal buffer, before it then actually prints that text out to the console. And, as this text includes the filename, the size of the buffer that is required to hold the text, depends on the length of the file name, obviously. For some reason, however, they made the buffer only 200 characters long. With very long file names this can be too short and we get a nice buffer overrun!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th October 2012 at 01:44. |
26th October 2012, 06:29 | #802 | Link |
how do u fixed? Can I suggest to simply use cout<< operator to concatenate and push out the strings, or use something like strCount() or size_of() to know how long the filename is?
powered by Google Translator |
26th October 2012, 12:47 | #803 | Link |
Software Developer
I increased the buffer from 200 to 300 char's, which should be enough, assuming file name won't exceed MAX_PATH char's. But to be sure, and because in UTF-8 encoding one "character" can take multiple char's (bytes), I also replaced the highly unsafe sprintf() with the safe snprintf_s(). Using the "cout" object is not possible in a plain C program, that is C++ stuff. And sizeof() doesn't tell you anything, if you have char* pointer.
BTW: It seems all the reason why they print into a buffer first, instead of using printf() right away, is because they are going to pass the same text into SetConsoleTitle() too. (The patch will be included in the LameXP repository, as always)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 26th October 2012 at 14:24. |
27th October 2012, 16:32 | #804 | Link | |
Software Developer
LameXP v4.06 RC-3
The following mirrors are still available: #1 #2 #3 #4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 29th October 2012 at 00:11. |
29th October 2012, 00:07 | #805 | Link | |
Software Developer
LameXP v4.06 RC-4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st November 2012 at 01:51. |
1st November 2012, 01:51 | #806 | Link | |
Software Developer
LameXP v4.06 RC-5
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th November 2012 at 18:33. |
4th November 2012, 18:34 | #807 | Link | |
Software Developer
LameXP v4.06 has been released
4th November 2012, 18:44 | #808 | Link |
Life's clearer in 4K UHD
Downloading and installing now.... Many thanks
8th November 2012, 01:49 | #809 | Link |
at last LameXP doesn't have any conflict with Comodo on the new version.
The bad news is it doesn't recognise qaac.exe. If you care for presentation, there's a mispell in spanish "Mostar DropBox", where it should be "Mostrar". You're welcome : P edit: found the hidden gem qaac.exe v.1.39, working great now, thanks! Last edited by Dogway; 8th November 2012 at 01:57. |
8th November 2012, 12:46 | #810 | Link | ||
Software Developer
So I guess, whatever the problem in Comodo was, they have fixed the bug on their side... See also: http://lamexp.sourceforge.net/doc/FAQ.html#96205e91 Please follow the install instructions here: http://lamexp.sourceforge.net/doc/FAQ.html#71a113b0 You may need to update your QAAC add-in for LameXP, if yours is too old... Quote:
If you think you can improve the Spanish translation, please feel free to have a look at: http://lamexp.sourceforge.net/doc/Translate.html I will fix this one typo for the next release. So thanks for the report.
8th November 2012, 17:37 | #811 | Link | |
I didn't do anything to Comodo (update database nor software) so I don't know, maybe it was something on your side (without noticing) or that I correctly enabled permissions, although I doubt I didn't do this the first time. Thank you. |
15th November 2012, 19:05 | #812 | Link |
Software Developer
For anybody who cares, here is the first Visual Studio 2012 build of LameXP: http://www.mediafire.com/file/rl546g...Build-1188.exe As one might expect, this build will not run on Windows XP (or even older). It also will need a CPU with SSE2 support, because Visual Studio defaults to /arch:SSE2 now and I didn't see a reason to change that. If the binary doesn't run on older OS anyway, it doesn't make any sense to still care about archaic CPU's. Other than that, you shouldn't see any difference with the new build.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th November 2012 at 20:39. |
15th November 2012, 20:22 | #813 | Link | |
15th November 2012, 20:55 | #814 | Link | |
Cheers manolito |
15th November 2012, 21:27 | #815 | Link |
Software Developer
Don't worry, I won't drop Windows XP support!
Maybe I will make the switch to VS2012 after Microsoft has finally released the "Update 1" for VS2012, which is supposed to restore Windows XP targeting support, yay I don't know if it will be possible to restore Windows 2000 support the same way I could do it with VS2010, so I might be forced to drop Windows 2000 support. (Currently I'm still undecided whether my eyes will be able to permanently bear the clunky interface of VS2012, but "Update 1" is also supposed to bring back some colors ^^)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th November 2012 at 21:30. |
20th November 2012, 11:12 | #816 | Link |
Opus codec coding question
I ripped some CDs and coded them with Opus. The quality is great but one thing seems to be a bit weird to me. As I ripped them from CDs the source is sampled at 44 kHz, but if I compress it with Opus and play with AIMP or foobar the players show 48 kHz sampling rate. Are the files resampled? Is it usual behavior for the codec orI am doing something wrong?
20th November 2012, 11:45 | #817 | Link |
Software Developer
Please see:
http://www.hydrogenaudio.org/forums/...dpost&p=808895 Opus does not natively support 44Khz. The idea is that since 48Khz can store a 44Khz signal, this simplifies the algorithm. Then, it just stores the original format and size so that a decoder could decode to the same values, but a decoder is allowed to decode at another samplerate. [...] Every non-48Khz input rate will internally be converted to 48Khz. So the output will always be at 48Khz. If you don't trust the internal resampler then you could always go and use something like SoX. See also: http://wiki.xiph.org/OpusFAQ#How_do_...ted_by_Opus.3F Note that it's generally preferable for a decoder to output at 48kHz even when you know the original input was 44.1kHz, not only because you can skip resampling but also because many inexpensive audio interfaces have poor quality output for 44.1k. [...] input files at these rates [above 48 kHz] are internally converted to 48 kHz, and then only frequencies up to 20 kHz are encoded. The reason is simple: lossy codecs are designed to preserve audible details while discarding irrelevant information. Since the human ear can only hear up to 20 kHz at best (usually lower than that), frequency content above 20 kHz is the first thing to go.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th November 2012 at 12:05. |
28th November 2012, 02:00 | #819 | Link | |
Software Developer
LameXP v4.07 Alpha-4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd December 2012 at 00:41. |
2nd December 2012, 08:33 | #820 | Link |
Not sure if someone has reported it yet... but (at least on Linux / Kubuntu 12.10 ... running LameXP on top of Wine) I have got a consistent problem when the tags of the files being encoded have quotes on the name.
For example, if the file has a title tag like (and named also): マジカ"ルゼ"アクション編曲バトル! ... the file won't convert and will threw a error. This have happened to me with flac files, but they have something in common... the tags are UTF-8 encoded (so far I know). Now, I'm not sure if this also happens on Windows (because I do not have a windows box at hand), but this error has been consistent with me, with the 4.06 final version, so I decided to report it. Other one I have seen that threw me the error is: ゆうかぜ (Yoshino Yoshikawa "Pollarstars" remix) Hope it is helpful. Last edited by LoRd_MuldeR; 2nd December 2012 at 21:24. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
