23rd July 2013, 20:52 | #921 | Link |
Software Developer
Hi.
MP3 to Wave works fine me. So what exactly does not work for you? And what does your log say? As for Drag&Drop, works fine for me on Windows XP, Windows 7 and Windows 8. However be sure you do not launch LameXP with elevated rights, as this would "block" Drag&Drop (besides that it is not needed at all). "Browse Output File Location" also works for me just fine on Windows 8...
23rd July 2013, 21:05 | #923 | Link |
Software Developer
Nope. You'll need to demux the audio stream with something like tsMuxeR first.
23rd July 2013, 21:06 | #924 | Link |
Life's clearer in 4K UHD
I got a new build today 4.08 Beta-2 dated 2013-07-23....
23rd July 2013, 21:08 | #925 | Link |
Software Developer
So?
24th July 2013, 18:03 | #926 | Link | |
Software Developer
LameXP v4.08 Beta-2:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st August 2013 at 19:29. |
21st August 2013, 19:29 | #927 | Link | |
Software Developer
LameXP v4.08 RC-1:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th August 2013 at 16:46. |
25th August 2013, 16:46 | #928 | Link | |
Software Developer
LameXP v4.08 RC-2:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th September 2013 at 10:32. |
4th September 2013, 10:33 | #929 | Link | |
Software Developer
LameXP v4.08 has been released
http://lamexp.sourceforge.net/ | http://lamexp.berlios.de/ Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 7th October 2013 at 12:18. |
4th September 2013, 20:27 | #931 | Link |
Software Developer
I have uploaded a new "portable" build.
17th September 2013, 16:28 | #933 | Link |
Hi! With the 4.0.8 final-1 it doesn't recognize fhgaac (I'm on w8).
Also as Dogway has [S]claimed[/S] required, why don't change the slider's scale for each aac encoder? (now I don't know how it works, but if is by lists of possibly values as I think, should be quite simple to add an if, or a switch case, statements to change them.) byez
powered by Google Translator Last edited by Motenai Yoda; 17th September 2013 at 16:49. |
25th September 2013, 11:51 | #934 | Link | ||
Software Developer
Are you 100% sure all the required DLL files are in the correct place? Quote:
I rather prefer to keep the GUI code agnostic of the specific AAC encoder and, instead, keep the details in the individual encoder class. The ultimate goal is to keep the GUI code completely agnostic of any encoder. But this will require a new "configuration options" interface to be implemented by the encoder classes, so the GUI can query the supported encoding modes, the supported bitrates as well as the supported VBR levels from the selected encoder - rather than having all that knowledge hardcoded in the GUI code. But this will be a rather massive redesign of the inner workings...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th September 2013 at 17:17. |
29th September 2013, 22:49 | #935 | Link |
there are the exact same files, maybe different versions? I took from your pack and last winamp installer.
edit: now I make a clean reinstall with all new files, and work. edit2: I didn't mean in the gui code, but a method that change that list into an "AACEncodersWrapper" class (or something like this) in the way that each "XXXEncodersWrapper" class can manage XXX lists internally. But now that it's switched from naac to fhgaac, the slider's scale for VBR mode has yet changed. 0.o Last edited by Motenai Yoda; 29th September 2013 at 23:06. |
30th September 2013, 13:18 | #936 | Link | |
Software Developer
2nd October 2013, 15:44 | #937 | Link | ||
Software Developer
http://pastie.org/private/gpbkatoeas1kdtmk5te92g One of my most productive days was throwing away 1,000 lines of code - Ken Thompson
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd October 2013 at 15:46. |
7th October 2013, 12:25 | #938 | Link | |
Software Developer
LameXP v4.09 Alpha-1:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 13th October 2013 at 00:55. |
7th October 2013, 16:11 | #939 | Link |
47.952fps@71.928Hz
Thanks for the update.
It's been a long time since I used this so this should definitely be fun to play with.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
9th October 2013, 17:27 | #940 | Link |
Software Developer
FWIW, I made made a short clip that shows LameXP v4.08 vs. LameXP v4.09 while importing the very same set of 1160 files:
http://www.mediafire.com/download/o5...08_VS_v409.zip (Note that these runs were captured one after another and stacked together afterwards. Also, I have a feeling that without the capturing software, the difference is even larger)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th October 2013 at 18:28. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
