Old 10th November 2012, 12:41   #12861  |  Link
mark0077
Thanks Nev!
mark0077 is offline   Reply With Quote
Old 10th November 2012, 13:46   #12862  |  Link
Skibicki
Skibicki's Avatar
Thanks, this update gave a nice performance boost.
Without A Paddle DVD
Setup
MPC-HC 1.6.5.6174 – audio switcher off – internal filters off + LAV Filters 0.53.1 – mixing on
Working
EVR, avcodec
EVR, dxva2n – no menu highlighting
EVR CP, avcodec
EVR CP, dxva2n – same as EVR
Broken
dxva2cb (all renderers) - play button works but delayed, all others menus behave identical to previous bug report
Without A Paddle DVD is getting stuck on the title menu.
- go to title menu
- hit scene selection
The title screen image will be frozen but when the mouse is moved a finger pointer appears when hovering over the spots where scene numbers would be.
VMR9 R (all decoders) - blank video/only audio during trailers
Win 8.1 -- Core 2 Duo E7300 & Intel Q43 GMA 4500
Skibicki is offline   Reply With Quote
Old 10th November 2012, 14:09   #12863  |  Link
I fixed DXVA2 CB, it wasn't properly flushing the image out of its display queue.
For the other points:
- dxva2n is not supposed to show menu overlays at this time
- VMR9 works fine for me (and since you seem to be on Win7, there is no reason to even try to use it)
Old 11th November 2012, 10:20   #12864  |  Link
CiNcH
CiNcH's Avatar
LAV Video 0.53.1 falls back to 'avcodec' for H.264 it seems, avoiding the 'QuickSync' decoder, see atached image. LAV Video is used inside the DVBViewer for live streams. Splitter is the DVBViewer's own DVB Source filter.
LAV Video 0.51.3 works fine.
Bye
CiNcH is offline   Reply With Quote
Old 11th November 2012, 10:50   #12865  |  Link
Will be fixed in the next version.
PS:
For the record, attachments take very long to be approved here, so avoid using them.
Old 11th November 2012, 13:37   #12866  |  Link
LAV Filters 0.53.2
LAV Video
- Fixed DVD menu still frames with DXVA2 Copy Back
- Fixed Live TV playback with QuickSync
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Nothing big in this version, two small fixes that should make a good stable version now.
Please let me know if you still encounter any DVD issues, in the menu or otherwise.
If you still have a problematic menu, you can extract only the menu from a DVD by simply zip'ing up all the IFO/BUP files, the VIDEO_TS.VOB, and all VTS_xx_0.VOBs (VTS files ending with 0 are for menus, 1 and above are content).
Take care.
Old 11th November 2012, 15:46   #12867  |  Link
husmoaschta
ATI Deinterlacing
Hi!
The filters are doing a great job in my system except one thing:
Using LAV-Video in (any) TV-Software sets my Deinterlacing back to BOB in CCC (HD7950).
Any hints on that?
husmoaschta is offline   Reply With Quote
Old 11th November 2012, 16:26   #12868  |  Link
LAV does not influence any of your drivers settings.
Old 11th November 2012, 17:15   #12869  |  Link
husmoaschta
But when I use the PDVD12-Codec, the DeInt stays at VA ...
Old 12th November 2012, 00:55   #12870  |  Link
MarkT
H.264 live video is fixed with QuickSync decoder. Impressive bugfixing skills. ;-) Pretty solid release I'd say. Thanks!
MarkT is offline   Reply With Quote
Old 12th November 2012, 01:29   #12871  |  Link
MarkT
75 #define IDC_LBL_FORMATS 1065
76 #define IDC_HWACCEL_MPEG2_DVD 1065
Duplicate ID not a problem?
Old 12th November 2012, 02:39   #12872  |  Link
Skibicki
Skibicki's Avatar
The Bad News Bears (1976) DVD
Looks like a player problem. The DVD had copy protect errors with internal filters, LAV Filters and Windows defaults codecs. Decrypting fixed it. I may need some advice on getting a video sample.
working
LAV Filters 0.53.2
EVR CP - dxva2cb
EVR CP - avcodec
intenal filters
EVR, audio switcher on
broken
LAV Filters 0.53.2
EVR CP, dxva2n - copy-protect fail
EVR, dxva2cb - MPC - HC hangs after opening
EVR, dxva2n - copy-protect fail
EVR, avcodec - copy-protect fail
internal filters
EVR CP - copy-protect fail
EVR, audio switcher off - copy-protect fail
Old 12th November 2012, 08:05   #12873  |  Link
RealSnoopyDog
This is a bug in some ATI drivers. Sometimes, the value for deinterlace mode is still correct, but the CCC shows something wrong.
RealSnoopyDog is offline   Reply With Quote
Old 12th November 2012, 09:34   #12874  |  Link
Since those two are not used on the same properties page, its not a problem, but i'll change it anyway, thanks.
Old 12th November 2012, 11:31   #12875  |  Link
ice25
Is there a way to toggle between different subtitles within a file during playback with a keybind?
ice25 is offline   Reply With Quote
Old 12th November 2012, 11:36   #12876  |  Link
husmoaschta
Do you know the registry-value, where I can check this?
THX
Old 12th November 2012, 16:49   #12877  |  Link
mastan
"S"/"Shift-S" in MPC HC.
mastan is offline   Reply With Quote
Old 12th November 2012, 20:13   #12878  |  Link
AndreaMG
AndreaMG's Avatar
Thanks Nev for the new dvd hardware/software decoding option
AndreaMG is offline   Reply With Quote
Old 12th November 2012, 20:16   #12879  |  Link
CiNcH
CiNcH's Avatar
Got a question concerning DVD's copy protection... I can see that LAV uses DeCSS. How about ARccOS? Is it still used on recent DVD's? Does LAV or DeCSS handle this properly?
Bye
Old 12th November 2012, 20:40   #12880  |  Link
The DeCSS code is never used, the DVD Navigator decrypts the disc already.
