Old 31st January 2018, 15:31   #501  |  Link
TheFluff
Excessively jovial fellow
Originally Posted by Aktan View Post
I think it is still related to Intel compiler.
What do you base that on? Most of the NNEDI3 performance-critical code is in hand-written assembler in this version. In the Vapoursynth version (which uses mostly compiler intrinsics in C++ rather than pure asm) you could argue that the compiler could have a big impact, but not in this version. In fact it's been repeatedly pointed out in this very thread that having a special DLL with compiler optimizations for AVX2 enabled is completely pointless - it has essentially no performance impact at all, since there's nothing performance critical that the compiler can actually optimize.
TheFluff is offline   Reply With Quote
Old 31st January 2018, 15:34   #502  |  Link
Aktan
I will admit it was just a bad guess as I'm not that familiar with compilers. I guess I won't be able to compile it then since there was hand written ASM. I based it on the fact that in the past Intel did selectively optimize to only Intel chips in their compiler.
Edit: Just curious, if I use the Release_Intel_W7_Core2_AVX DLL or even the Release_Intel_W7_Core2_SSE4.2 DLL and set opt to 5, would AVX2 still be used? I tried that and I still get the same slow speed. I was expecting it to throw an error like invalid opt mode, but I was just guessing.
Aktan is offline   Reply With Quote
Old 31st January 2018, 15:50   #503  |  Link
TheFluff
What happens if you use threads=1?
BTW, if you're willing to try Vapoursynth, you can try znedi3, an attempt at making NNEDI3 on the CPU competitive with the OpenCL version running on the GPU. IIRC it was something like 50-100% faster than the original VS NNEDI3 on 8-bit input, but I don't know if anyone ever tested it on Ryzen.
Old 31st January 2018, 15:53   #504  |  Link
Aktan
BTW, if you're willing to try Vapoursynth, you can try znedi3, an attempt at making NNEDI3 on the CPU competitive with the OpenCL version running on the GPU. IIRC it was something like 50-100% faster than the original VS NNEDI3 on 8-bit input.
I'll try both in a bit.
Edit: threads=1:
opt	FPS
4	~4
5	0.11 (~1 frame every 9 seconds)
Old 31st January 2018, 16:59   #505  |  Link
pinterf
It's not Ryzen. This one:
nnedi3_rpow2(rfactor=4, cshift="lanczosresize", fwidth=2880, fheight=1920, ep0=2, nsize=0, nns=4, qual=2, pscrn=4, opt=5)
is giving me 0.03 fps for the first 3-4 frames with opt=0 or opt=5
and >3 fps with opt=4
x64 version freshly recompiled with VS2017 15.5
Intel i7-7700 (AVX2), Win10 x64, Avisynth+ 2591 (dev)
pinterf is offline   Reply With Quote
Old 31st January 2018, 17:02   #506  |  Link
Aktan
That's interesting, I guess now to figure out which of the param is actually causing it.
Old 31st January 2018, 17:05   #507  |  Link
jpsdr
No differences in the code, just compiler options, all versions will behave the same.
Old 31st January 2018, 17:10   #508  |  Link
jpsdr
Odd... I don't remember so much differences when testing... But on my tests, i've never changed ep0 and always tested pscrn with 2 or 0.
Btw, with 0, very small frames (480p) to have some frames without having to wait hours...
Don't have time for now, but will redo tests later.
Old 31st January 2018, 17:11   #509  |  Link
pinterf
Missing else
https://github.com/jpsdr/NNEDI3/blob...edi3.cpp#L1725
https://github.com/jpsdr/NNEDI3/blob...edi3.cpp#L1734
fps is OK again for AVX2
(And a request: the AVX2 asm files were missing from the sln file had to add them manually)
Old 31st January 2018, 17:16   #510  |  Link
jpsdr
I was about to said that i'll check if i didn't messed-up something, but you beats me...
About ASM files :
Yes it's normal they are missing, because i want to keep the project on github on VS2010 (if you want to use more than VS2010, you can just upgrade the project), but VS2010 will not be able to to compile the AVX2 asm files, so it will result on a incorrect project if they were included. This is why the AVX2 asm are on others files.
Old 31st January 2018, 17:31   #511  |  Link
Aktan
Awesome catch! Yep, changing prescreen to original (1) where the bug doesn't exist gave me results comparable to AVX.
Old 31st March 2018, 10:11   #512  |  Link
jpsdr
New version, see first post, and i've also added on it a part about the multi-threading.
My github.
Old 3rd April 2018, 12:10   #513  |  Link
jpsdr
There is issue with the Intel versions.
I'll update the release files on github, removing the Intel versions, and keeping only VS version, and adding an VS AVX2 version. Wait at least 24h to check/re-download the files.
My github.
Old 3rd April 2018, 20:30   #514  |  Link
jpsdr
Trashed Intel version, file updated, redownload it.
My github.
Old 7th April 2018, 12:47   #515  |  Link
jpsdr
New version, see first post, updated also the Multi-treading text part.
My github.
Old 25th May 2018, 15:32   #516  |  Link
mp3dom
It seems there's a bug in YUY2 colorspace that create a green vertical bar on the right side of the image under some circumstances (both x86 and x64):
colorbars(width=1416,height=1080,pixel_type="yuy2")
nnedi3(0)
mp3dom is offline   Reply With Quote
Old 25th May 2018, 20:13   #517  |  Link
Taurus
Taurus's Avatar
nnedi3(0)
But only if the width is at some "odd" resolutions...not devidable with mod16.
Older versions show the same behaviour.
Just a short test..
Old 25th May 2018, 20:58   #518  |  Link
jpsdr
Thanks for reporting, i've found what was wrong.
I want to finish something else i'm working on before making new releases of some filters. So, several days before i'll make new builds, but it's fixed on Github.
My github.
Old 26th May 2018, 12:35   #519  |  Link
mp3dom
Old 1st June 2018, 10:01   #520  |  Link
jpsdr
New version, see first post.
My github.
