28th October 2014, 10:12 | #13301 | Link |
dnxhd is not lossless. It works more or less like mjpeg. I use ut video or magicyuv when I render something in sony vegas.
HERE is new encoding client -> http://www.mediafire.com/download/xy...dingClient.exe Tested and works fine with UT video.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th October 2014 at 12:49. |
28th October 2014, 14:08 | #13302 | Link |
That explains why I had slight differences in the greys using DNxHD, I thought it was a misconfigured vegas option. Indeed it sounded weird it could be lossless being based on jpeg. My bad, lossless is indeed not mentionned anywhere about DNxHD.
Also sorry for the slight off topic but how do you render in UTvideo or magicYUV from vegas ? I have both codec installed but they don't appear in vegas codec list. About the fixed encodingClient, I have just tried and it worked with my UTvideo sample, and with the lagarith sample too, thank you ! |
28th October 2014, 17:47 | #13303 | Link |
30th October 2014, 16:14 | #13306 | Link |
I went from v1.75 to v1.18.1 recently and 2 movies I tried encoding recently (a DVD and a Blu-Ray) have audio out of sync. On the Blu-Ray encode, I did preview the script and the audio was perfectly synced at the time before encoding.
I'd like to stay at the current version but I definitely need to fix this audio sync issue. Should I possibly try re-installing some core components, and if so what versions? |
31st October 2014, 19:43 | #13307 | Link |
Just wanted to say thank you for an awesome tool. I've been using since as long as I remember, and as a thanks, I just want to share this code with you. It should remove the visual glitch when someone presses the ALT key in the program. It took me a long time to figure out what was going on with my own personal Delphi projects, and I thought I would share that. It's unrestricted licensing.
4th November 2014, 04:09 | #13309 | Link |
WMV job adding errors
I've tried 1.18.1 and older versions and still can't seem to add WMV files.
Got the DirectShowSource: I can't determine the frame rate of the video, you must use the "fps" parameter. (C:\Temp\RipBot264temp\job1\getinfo.avs, line 2) Is there anyway to fix this? Using windows 8.1 x64 Last edited by bartimeaus91; 4th November 2014 at 04:20. |
9th November 2014, 20:09 | #13312 | Link |
Use mkvmerge, load your video
At "Global" tab, you will find an option, split mode. Choose the way you want to split your file @Atak I found a bug on v.1.18.1 I set a desirable size on some episodes and start the encoding. If I change the size of a job while encoding, the result size is well away of the target size. If I change it again and restart it, same thing. The result size is well away of the target size. And that's not on a specific file, it's on all files To fix that, I must remove the job and re-add it. |
14th November 2014, 19:30 | #13315 | Link |
Why?
1) I start multiple distributed encoding servers on my machine until it gets to 100% CPU Utilization. That way the encoding gets done as fast as possible. I typically run 3 servers to get 100%. 2) If you leave the priority settings at default (Background) any other active process will run at near full speed until finished. I guess if you had a very slow CPU it might be a concern, but then the best thing to do is upgrade. |
20th November 2014, 20:59 | #13316 | Link |
Today my library is all mp4 and I use MetaX to tag all my files and now I am slowly migrating to x265 which uses mkv as the container and was wondering if anyone is putting metadata with their files and if so what tool they are using? I've tried using MetaX and VLC so far to edit and neither do the trick. I know the mkvtoolbox has an import command where it looks like you supply an xml file with the metadata but hoping for something a little bit more elegant.
Thanks mmmmdonut |
5th December 2014, 17:49 | #13317 | Link |
Problem with importing file
Hi. when i import a Blu-ray mkv file in ripbot, this error appears :
MKV Mediainfo: Code:
General Unique ID : 222865866462087627838380154964499107853 (0xA7AA67928FF6E925A5D5B2662CCA100D) Complete name : C:\torent\BBC Madagascar 2011.BluRay.1080i.AC3.VC1.REMUX.mkv Format : Matroska Format version : Version 2 File size : 12.9 GiB Duration : 58mn 47s Overall bit rate : 31.5 Mbps Encoded date : UTC 2011-05-18 04:58:12 Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32 Writing library : libebml v1.2.0 + libmatroska v1.1.0 Video ID : 1 Format : VC-1 Format profile : Advanced@L3 Codec ID : V_MS/VFW/FOURCC / WVC1 Codec ID/Hint : Microsoft Duration : 58mn 47s Bit rate : 30.4 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.587 Stream size : 12.5 GiB (97%) Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 58mn 47s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 188 MiB (1%) Default : Yes Forced : No |
14th December 2014, 16:27 | #13318 | Link |
Occasionally I come across some blu-rays that have a short little title video before the main title. The problem with some of these titles are they have no audio in them and RipBot264 then have the audio off by the length of time of the of the title video. In the attachment I've provided shows the video has a duration of 10s 890ms so that throws off the audio by that length of time.
My work around for this is when I'm choosing the video to add, I can click edit and deselect the title video and just have the main feature. The only disadvantage to this is the movie will no longer have any chapters. My work around for that is to grab the chapters from the combined version and save them. Go back and choose only the main film, edit the chapters.txt file and subtract the length of time of the title feature from each chapter and then add it back to the Temp Job folder that was created. This is not that big of a deal for a movie as I really only see it about 1 in a 100 films, but I have a few TV shows that also have this issue which adds a lot of time to fix those. Atak, is it possible for RipBot to detect this condition and pad the audio stream by the length of time of the missing audio? |
16th December 2014, 17:52 | #13319 | Link | |
