22nd May 2011, 12:33 | #9621 | Link |
I thing I am far from what is the right way to make a MKV.
Do I have to use first a program like AnyDVD HD to decode the protection on bluray? I thought ripbot do this. Not? I have DVDFab, for my DVD's, it's ok with this program? Some more info please I am new to all this as you understand. |
22nd May 2011, 12:35 | #9622 | Link | |
1) Install ANYDVD HD
2) Make sure that ANYDVD HD is running in background (tray icon) 3) Open any .m2ts directly from Blu-Ray disc in ripbot264 Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd May 2011 at 12:39. |
22nd May 2011, 13:29 | #9623 | Link |
Quick question. I am doing a quick test trying to mirror some test encode files that I have. One encode is done at High@L3.1. When I choose the 3.1 profile in Ripbot264 I get Main@L3.1. What option do I need to change in the video profile to switch from Main to High? Thanks.
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
22nd May 2011, 14:05 | #9624 | Link | |
Yes! It works fine! @ Trayman & Atak_Snajpera Thank you for your support and your fast replay. Sorry that slipping me that I need AnyDVD for decryption. Cheers |
22nd May 2011, 14:33 | #9625 | Link | |
22nd May 2011, 15:25 | #9627 | Link |
Atak,
I am running into a problem again with "Vicky Christina Barcelona" where RipBot gets stuck on "Please wait...initializing." Back in an earlier version of RipBot you released an update to handle the weird 3.1 audio that some discs, like this one, have, and I am wondering if that is the problem again. I can see in processes that "Aften.exe" is running, but it doesn't seem to be working. Any ideas? |
22nd May 2011, 16:29 | #9628 | Link | |
Or, If you know what you're doing... Open any TXT Profiile, configure and Save as... [HIGH 3.1] Custom Last edited by jandor; 22nd May 2011 at 17:41. |
22nd May 2011, 17:16 | #9629 | Link |
22nd May 2011, 21:29 | #9630 | Link | |
For movies that are 29.97 and have horrible interlace lines I choose reverse telecine in ripbot and leave decimate restore to 23.976. It's worked so far on all the other movies. Doing that the audio is still way off. I've also tried switching to mkv and just doing a stream copy of the audio and that is also out of sync probably because ripbot is seeing that 39881ms delay. Ripping the movie with ripbot gets me the same length as in handbrake according to mediainfo, 1h 52mn. |
23rd May 2011, 06:13 | #9633 | Link |
Stuck at 99.9%
Hi everyone. I'm having a problem with encoding some of my files to .mkvs. Some of my files will only get to 99.9% and then just sit there. In every case that this happens, the x264 process is not running anymore. Unfortunately, it doesn't create a log file in Ripbot's log directory. Is there any information I can pull from the job's directory that might help? I also have a screenshot below to show how the encode is "stuck". Any ideas? Thank you!
23rd May 2011, 16:38 | #9634 | Link | |
GPAC maintainer
Hi guys,
I'm sorry to answer to this old message but as a developer I need to bring some explanations: Quote:
That being said, all runtimes support large files except some official mingw/mingw32 ones which rely on the microsoft visual 6 (1998) C runtime. You can actually ask for using newer runtimes at build time but the support is incomplete. The solution is to use a unofficial mingw or to patch some mingw (resp. mingw32) headers to directly call the right functions. We've discussed this among developers and concluded we would wait for mingw to provide some support to a runtime newer than 1998 (which is in the roadmap). On Windows, cygwin and microsoft free tools (http://gpac.wp.institut-telecom.fr/2...soft-visual-c/) work with no restriction. I hope it is clearer now. Romain |
23rd May 2011, 19:07 | #9635 | Link |
Solving asynchrony while encoding a DVD
Solving or avoiding asynchrony when you encode from DVD files:
Process from an original DVD... The encoding of DVD files is still a reality. I wait that my written English is correct, and doesn't come for confuse them. When joining the VOB files have two methods that do the same thing: PgcDemux and "DVD Shrink". First, you must make a copy (decrypt) of the DVD for the HD only the main movie and without compression, or 100% of his size using the DVDFab or AnyDVD. The "DVD Shrink" also removes the protection of DVD, but he is out of date for some things. Not always a difference of length of the audio will be a delay. Always consider the whole files. A partial copy or a cutting doesn't serve as a parameter. Follow the reading... Code:
Use PgcDemux to join the VOB files. The PgcDemux doesn't solve problems of interlaced, but when you join the VOB files with your application, certainly solves the problem of delay. The PgcDemux really stabilizes, while joining the VOB files, ending any asynchrony. He works from the IFO file. Single process... DVD Shrink, It does the same thing as the PgcDemux. 1º) Open DVD Shrink -> Edit -> Preferences -> Output Files -> uncheck the last two items - Split VOB files into 1GB size chunks (recommended) - Logical remapping of enabled streams. 2º) Then click the tab Re-author In "DVD Browser" locate the DVD folder with VOB files. 3º) Going for the directory, open the folder with the DVD files. 4º) You will visualize the VOB files totalized into a single file -> click 2x on the file. 5º) Double click "Title 1" to create the DVD file structure The file is totaled transported for the window of the side. 6º) In the Compression Settings tab -> Video -> change for No Compression 7º) As soon as it opens the window "Backup DVD" -> in the tab "Target Device" -> in "Select backup target " -> change or stay as "Hard Disk Folder" Choose the destination to save the new copy... below, disable "Create VIDEO_TS and AUDIO_TS subfolders" Remembering that while entering in the RipBot264 in "Properties", if closed "Deinterlace" and the "Decimate", is a sign that everything is OK, and will not occur asynchrony. When a software encoder accepts only ISO images... File tab -> click Backup... Once you open the window DVD Backup -> Target Device tab -> under Select backup target: leave as "ISO Image File" Choose the destination to save the ISO image. Other methods to create ISO image, DVD folders and files... 1. tsMuxeR -> Use "Add" for the VOB first, and "Join" for the remainder -> and select "Demux" -> Start demuxing If you only have a MPEG-2 file, also make the tsMuxeR demuxing before. Will be extracted MPV and AC3 files. continues below... 2. DVDAuthorGUI -> add title -> MPV video file -> AC3 audio file -> File -> select "Create ISO after Authoring" -> author DVD -> Name the new folder -> Save You finished of reassemble the ISO image, folders and files from DVD! Other support tools:DelayCut and Mpg2Cut2 However, if you continue having problems with audio gives a chance for the DelayCut. Make a "demux" of the audio before. The DVDAuthorGUI is also ideal to create the DVD files structure. I hope I have myself made understanding in the explanation of everything, and that come on be useful. You can also do the encoding of the DVD without audio, joining the audio later: "Demux" of everything with the PgcDemux, and AC3 audio without conversion. Joining the audio files in containers: MP4 use the YAMB MKV use the MKVmerge AVCHD use the tsMuxer Extract DVD subtitles: SubRip or Subtitle Edit No installer - portable version. Last edited by jandor; 26th May 2011 at 23:49. |
24th May 2011, 07:08 | #9636 | Link | |
In Ripbot could be changed "me_range" parameter from 16 to other upper value ??
And HOW ??? and what represents these setting ???? each of them... Quote:
My question is directly related to Ripbot although I see a lot of other related topics are discussed, without any connection with the subject, and they receive answers... |
24th May 2011, 13:40 | #9638 | Link |
benjyv,
Macroblocks... this theme is quite extensive: http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC http://mewiki.project357.com/wiki/X264_Settings P.S. Was released MKVtoolnix 4.8.0: http://www.videohelp.com/tools/MKVtoolnix Now working normally with the Windows 7 Download the zip file version: http://www.bunkus.org/videotools/mkv...icode-4.8.0.7z Last edited by jandor; 24th May 2011 at 16:58. |
26th May 2011, 18:08 | #9639 | Link |
I'm having isssus with Ripbot v.4 and 5. I updated to 5 when it came out but then I started having constant video freezing but audio kept going fine. So I reverted back to v4, but same problem. So them I uninstalled Ripbot and all the codecs is needs and ran a regisrty cleaner and checked for orphaned folders and deleted them, rebooted. Reinstalled Ripbot v4 again with all the lastest codecs it requests. Make anothe AVCHD and same problem still, and so I again updated to v5 again. Why am I having this issue? I'm playing this on $ony DVD+R and $ony DVD+R DL on PS3 and standalone Bluray player. Please get back with with a possible resolution. Thanks.
27th May 2011, 14:36 | #9640 | Link | |
