Old 29th July 2011, 13:21   #12541  |  Link
Have you tried uninstalling all components and then reinstalling everything? Sometimes other software that is installed will "intercept" CODECs, causing problems, and give no indication of doing so. Also, if you have any "codec packs" installed -- remove them. All the CODECs you will ever need are included in FFDSHOW.
Interesting that the section where it is failing is only 24 frames long... have you changed MIN_M2TS_SIZE?
[Edit] Look like you posted while I was answering... BD-RB should recognize a menu and for BD-25 in most cases it should not change it.
Old 29th July 2011, 13:30   #12542  |  Link
jagjockey
Just locked up at 71%.
jagjockey is offline   Reply With Quote
Old 29th July 2011, 13:33   #12543  |  Link
jagjockey
Not installed any other codecs besides Rebuilder ones.
I can select oo81 in vlc and it plays fine.
I have just rebooted the pc and I'll rerun RB to see if it stops again.
thanks for replying.
Old 29th July 2011, 13:38   #12544  |  Link
jagjockey
Now this is being reported:
[13:35:13] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
- Input BD size: 25.90 GB
- Approximate total content: [01:56:35.988]
- Target BD size: 21.97 GB
- Windows Version: 6.0 [6002]
- MOVIE-ONLY mode enabled
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[13:35:15] PHASE ONE, Encoding
- [13:35:15] Extracting A/V streams [VID_00060]
- Extracting A/V to M2TS [VID_00060]
- Error in attempt to extract audio/subs.
[13:35:16] - Failed to retrieve audio, aborted
[13:35:44] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
[13:35:46] PHASE ONE, Encoding
- [13:35:46] Extracting A/V streams [VID_00060]
[13:35:47] - Failed to retrieve audio, aborted
[13:36:13] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
- Input BD size: 36.53 GB
- Approximate total content: [04:09:53.536]
[13:36:14] PHASE ONE, Encoding
- [13:36:14] Extracting A/V streams [VID_00081]
[13:36:15] - Failed to retrieve audio, aborted
[13:36:39] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
[13:36:39] PHASE ONE, Encoding
- [13:36:39] Extracting A/V streams [VID_00081]
[13:36:40] - Failed to retrieve audio, aborted
[13:37:10] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
[13:37:10] PHASE ONE, Encoding
- [13:37:10] Extracting A/V streams [VID_00060]
[13:37:11] - Failed to retrieve audio, aborted
Old 29th July 2011, 13:40   #12545  |  Link
What did you use to rip it? An error in extracting subs is very rare -- and could indicate a corrupt source.
Old 29th July 2011, 13:44   #12546  |  Link
jagjockey
Anydvd - full/latest version, not trial
Old 29th July 2011, 13:54   #12547  |  Link
jagjockey
Now getting the same error as in message 12545 log, on other discs
Old 29th July 2011, 14:05   #12548  |  Link
Something is installed wrong. Since it worked and then stopped again, I have to think that some other software on your system is changing the settings back...
Old 29th July 2011, 14:08   #12549  |  Link
jagjockey
It's just about a bare system, software wise. Just reinstalled a clean Windows. I don't understand the workings of RB or all the settings.
When I installed it about 6 months ago it worked straight out the box. Wonder if it is worth downgrading to an earlier version?
Old 29th July 2011, 14:53   #12550  |  Link
Capsbackup
This is definately not the solution. you have a setup issue, Windows Admin. privilege issue, etc..
Where do you have BD-RB's install folder? Try putting it on the desktop or on C: directly.
Old 29th July 2011, 15:01   #12551  |  Link
jagjockey
RB is installed on a usb attached HD. It has always been there.
Everything else on the pc works fine, all dvd and mts files plays with no problem.
Old 29th July 2011, 15:46   #12552  |  Link
sytyguy
Try ripping the disc to harddrive with AnyDvd, and then use BD-RB from the HDD. It might resolve your problem, or it might discover some errors on the disc?
Just a thought!
sytyguy is offline   Reply With Quote
Old 29th July 2011, 16:00   #12553  |  Link
jagjockey
I have tried ripping from the discs and ripping to HD first.
Same result.
I have ran RB from Desktop, c Drive and Ext HD, same result.
I am thinking of reinstalling Vista again.
Old 29th July 2011, 16:04   #12554  |  Link
Just for the heck of it, try uninstalling HAALI and then installing the previously recommended HAALI version.
Old 29th July 2011, 16:05   #12555  |  Link
jagjockey
Ok. Be back in a minute.
Old 29th July 2011, 17:16   #12556  |  Link
jagjockey
This is what I get now:
[17:14:19] BD Rebuilder v0.38.04 (beta)
- Source: CARS_GBR
[17:14:19] PHASE ONE, Encoding
- [17:14:19] Extracting A/V streams [VID_00060]
[17:14:19] - Failed to retrieve audio, aborted
This is with Movie only and Full disc
Old 29th July 2011, 17:17   #12557  |  Link
jagjockey
I must be doing something wrong. Every disc and ripped folder now fail.
Old 29th July 2011, 17:47   #12558  |  Link
jagjockey
It fails instantly as soon as I press Backup.
Old 29th July 2011, 17:51   #12559  |  Link
jagjockey
I uninstalled Haali splitter and it made no difference to RB, I presume it shouldhave.
So could it be that Haali is the problem even when I had it installed?
Old 29th July 2011, 17:53   #12560  |  Link
jagjockey
Just found that I had Xiph.org Open codecs 0.85.17777 installed.
