10th February 2012, 21:22 | #12062 | Link | |
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
10th February 2012, 22:31 | #12063 | Link | |
And your right I am using HDMI at Limited RGB at 1920x1080 (I thought that was preferred for TV/Video). I'll do some tests later at full RGB. |
10th February 2012, 23:10 | #12064 | Link | |
11th February 2012, 00:56 | #12066 | Link | |
What you need to change to RGB Full is the equivalent to "pixel format" which unfortunately for some (most?) people requires a PC resolution, or doing a custom HDTV resolution.
11th February 2012, 01:06 | #12067 | Link |
@entrecour Before you go chasing rainbows and making or testing a bunch of settings, I want you to know that I tested on my setup and the grayramp.ytp looks identical with my card. To test for gradient transitions, try looking at the smallramp.ytp or just get a regular grayscale ramp test pattern, such as the one from the AVS HD 709 calibration disc or MP4 files. You can easily tell when dithering isn't being used on a pattern such as this.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
11th February 2012, 09:49 | #12068 | Link | |
11th February 2012, 10:08 | #12069 | Link | ||
Every time I have tried setting up a custom resolution in the past my TV doesn't like it and I had to plug in another monitor to reset, so in the end I left it at the 1920x1080 native HD setting. I guess I can have another shot at it though. Quote:
smallramp.jpg avcgreyramp.jpg |
11th February 2012, 12:06 | #12070 | Link |
I have gone back to .79 again. It seems when I find one fix it brings up other issues. It seems with .80 I have to use the old render path with 25hz material on a 50hz display and the new render path for 23.976 material on a 23.976 display. All in all it seems for what ever reasons 080 gives my system problems filling the backbuffers. Going back to 079 and all is well again.
Raz |
11th February 2012, 13:30 | #12073 | Link |
Ya know, the present queue doesn't have to be full, as long as its above 0 and there are no drops.
11th February 2012, 13:35 | #12074 | Link | |
Yes I do and here is where the problem is..... in 079 it does not really drop and if it does dip it never goes to zero. In 080 it does drop, quite often at and hits zero at regular intervals. |
11th February 2012, 14:08 | #12075 | Link |
If anything that seems to be beneficial. I'm far more likely to get presentation glitches when the present queue is full rather than not. In fact, I suspect that if the "limit rendering times" option limited them enough that it would never fill up, it might fix my problems—your suggested flush settings really helped, but didn't eliminate presentation glitches with longer videos.
11th February 2012, 14:27 | #12076 | Link |
Gah, I (hopefully temporarily) bricked my 5770, reporting here that the good old 4670 is working fine with madVR's new options too! I miss the "dynamic range" option in CCC though, anyone knows if this can be accessed with DXVA Checker and which setting it is? I have 3 settings that say "dynamic range", but they don't seem to do anything. Also, I'm running Win 7-64, but I assume with madVR I have to run the 32-bit DXVA Checker version, right?
11th February 2012, 15:23 | #12077 | Link | |
11th February 2012, 15:29 | #12078 | Link |
with 0.80, when switching between deinterlacing and no deinterlacing, theres still the difference that colours look more vibrant when deinterlacing is off compared to when it is activated (or the other way round, colours look more washed out with active deinterlacing). is this how its supposed to be? it looks like as if levels get set to TV when deinterlacing is active in these cases.
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 11th February 2012 at 15:31. |
11th February 2012, 15:35 | #12079 | Link | |
11th February 2012, 16:59 | #12080 | Link | |
All those other video processing options, if they work they do only when deinterlacing as well, like nevcairiel said above, and most of us disable them.
