Old 25th June 2010, 11:44   #10201  |  Link
tebasuna51
tebasuna51's Avatar
I can confirm the problem, the:
"Removing DTS dialog normalization..."
only work, with dtshd input, when you use:
eac3to input.dtshd output.dts -core
And don't work with:
eac3to input.dtshd output.dtshd
eac3to input.dtshd output.wav
eac3to input.dtshd output.wav -libav
eac3to input.dtshd output.wav -core
eac3to input.dtshd output.wav -core -libav
BTW, if eac3to inform:
"DTS Master Audio, 5.1 channels, 16 bits, 48kHz, dialnorm: -4dB"
you can use this command line:
eac3to input.dtshd output.wav +4dB
tebasuna51 is offline
Old 25th June 2010, 11:50   #10202  |  Link
ACrowley
Ah thank you....i think Madshi will fix it when he have the Time..
But as i say, please, can somebody write a small Tool or Batch to write the extra bytes back to a DTS-HD Header to restore the untouched DTS-HD Header Sadly ive no Skill to code something.
ACrowley is offline
Old 25th June 2010, 12:14   #10203  |  Link
AnryV
Unfortunately this will lead to the fact that we will not obtain the original sound. This will be especially noticeably for 16-bit tracks.
AnryV is offline
Old 25th June 2010, 14:11   #10204  |  Link
tebasuna51
tebasuna51's Avatar
Then use:
eac3to input.dtshd output.wav +4dB -down16
Of course is a workaround, but the process work at 64 bit float, do you think can be especially noticeably?
Maybe any rounding bit.
I don't know for what you need the wav's files.
Old 25th June 2010, 14:25   #10205  |  Link
AnryV
Then use:
Anyway this is the result of processing, but original sound.
AnryV is offline
Old 25th June 2010, 16:29   #10206  |  Link
73ChargerFan
73ChargerFan's Avatar
The dts core is lossy, so 1-bit rounding errors could be considered immaterial.
73ChargerFan is offline
Old 25th June 2010, 17:46   #10207  |  Link
ACrowley
So the DialNorm Problem doesnt exits when DTS-HD is decoded by Sonic Decoder ? Ofcourse it doesnt work on 7.1
ACrowley is offline
Old 26th June 2010, 01:14   #10208  |  Link
Snowknight26
Reducing the bitdepth from 24-bit to 16-bit seems to cause tons of static. Tested on a 5.1 channel 24-bit WAV file. Should reproduce easily.
Snowknight26 is offline
Old 26th June 2010, 04:44   #10209  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I'm seeing odd behavior with Battleship Potemkin, a newly restored BluRay release from Kino. http://www.kino.com/video/item.php?film_id=1076
See below, it's self explanatory!
E:\Potemkin>eac3to d:
1) 00004.mpls, 00045.m2ts+00044.m2ts, 1:12:12
   - Chapters, 20 chapters
   - h264/AVC, 1080p24 /1.001 (16:9)
   - DTS Master Audio, English, multi-channel, 48kHz
2) 00005.mpls, 00047.m2ts+00046.m2ts, 1:11:48
3) 00006.mpls, 00048.m2ts, 0:42:24
   - Chapters, 8 chapters
   - h264/AVC, 1080i60 /1.001 (16:9)
   - AC3, English, stereo, 48kHz
E:\Potemkin>eac3to d:  1)
E:\Potemkin>
When I tell eac3to to give me the stream list from the main movie, it returns nothing
I can easily work around this by directly referencing the M2TS in question... Turns out there are two versions of the film on this disc, one with the original Russian cards (since it's a silent film), and another with English translated cards.
I prefer the Russian cards with English subtitles, so I just peeked at the M2TSs, and fully demuxed the one I wanted. Incidentally this was 00046.m2ts, and I was treated to the lovely PGS renderer that's now a part of MPC-HC!!!
I think eac3to's confusion may stem from the fact that the main movie M2TS files are preceeded by a very short M2TS, which is the Kino logo. But, I'm certainly not Madshi! Anyway, I was able to work around this no problem, but just a heads-up! Everyone should watch this BluRay. It's a great restoration of THE soviet film. Fantastic!
Cheers,
Derek
These are all my personal statements, not those of my employer :)
Blue_MiSfit is offline
Old 26th June 2010, 04:53   #10210  |  Link
Xorp
I'm getting that too and also on a normal 16-bit 7.1 TrueHD to FLAC conversion.
Xorp is offline
Old 26th June 2010, 05:02   #10211  |  Link
Killroy™
E:\Potemkin>
Cheers,
Derek
You have to do the actual file and not the playlist. It's the second one on each playlist. This is another one of the ones that we spoke about earlier.
BTW, if you do the English one you do NOT need the subs as they are the same as the placecards.
Killroy™ is offline
Old 26th June 2010, 06:56   #10212  |  Link
`Orum
Been using eac3to for quite some time now and love it...but I do have a couple of minor requests. First, an option to disable saving the internal logging of the output to a file--typically when batch processing I'll log everything to one file anyway. Secondly, a way to silence the completion "uncorking" sound. It's fairly loud and very annoying when running batch scripts to do some quick remuxing/conversion on lots of files. Other than that it's perfect.
Many thanks, I can't tell you how much time this app has saved me.
My filters: DupStep | PointSize
`Orum is offline
Old 26th June 2010, 08:07   #10213  |  Link
Snowknight26
Rename the wav files.
Old 26th June 2010, 08:14   #10214  |  Link
`Orum
yeah I know you can do that, but I find them useful at times...just thinking a command line flag would be best.
`Orum is offline
Old 26th June 2010, 10:30   #10215  |  Link
Blue_MiSfit
@Killroy:
Yep, that's what I meant to say
Regarding the content, I do prefer to see both the Cyrillic characters and the English subs as well. It feels more... soviet?
Thanks though!
Derek
Old 26th June 2010, 11:02   #10216  |  Link
kypec
User of free A/V tools
kypec's Avatar
If you are annoyed by the sound only in your batch processing then why not try something like this:
rem This goes somewhere before the eac3to.exe is called
rename "C:\Program Files\AVTools\eac3to\error.wav" error.none
rename "C:\Program Files\AVTools\eac3to\success.wav" success.none
rem Here goes your usual processing...
rename "C:\Program Files\AVTools\eac3to\error.none" error.wav
rename "C:\Program Files\AVTools\eac3to\success.none" success.wav
Replace path to eac3to with your real path of course.
kypec is offline
Old 26th June 2010, 11:14   #10217  |  Link
tebasuna51
tebasuna51's Avatar
Maybe?:
"reduce bitdepth of decoded audio data by using TPDF dithering"
Old 26th June 2010, 11:20   #10218  |  Link
`Orum
Yeah, the disadvantage of that is you have to be careful with your batch files. E.g., if I have one batch file, "bat_1.bat", that is
rename "C:\Program Files (x86)\eac3to\error.wav" error.none
rename "C:\Program Files (x86)\eac3to\success.wav" success.none
.\otherdir\bat_2.bat
"C:\Program Files (x86)\eac3to\eac3to.exe" foo.mkv 2:bar.flac
rename "C:\Program Files (x86)\eac3to\error.none" error.wav
rename "C:\Program Files (x86)\eac3to\success.none" success.wav
and a ".\otherdir\bat_2.bat" that is similar, e.g.
"C:\Program Files (x86)\eac3to\eac3to.exe" foo2.mkv 2:bar2.flac
I won't get the intended silent result. Just need to be really careful of the order you do things in, and where you do the renaming. A flag avoids the ordering problems.
`Orum is offline
Old 26th June 2010, 11:49   #10219  |  Link
DaFees
Hello everyone,
I hate to sound like a total noob, but I am having a big problem with eac3to. It simply will not convert TrueHD to LPCM. I'm trying to convert a bdrip for playback on my PS3. I do not know why, but it is specifically TrueHD that fails. I mean I just finished successfully converting a DTS-HD MA track to LPCM. I also know it's not a bad rip or anything because I've tried several different TrueHD tracks and none of them will convert. With a DTS-HD conversion I get the full sound, but with TrueHD I end up with no sound and really speed up and stuttery video.
If it helps I like to use multiavchd to convert my .m2ts files with DTS-HD / TrueHD to .m2ts files with LPCM. I get no errors with DTS-HD but TrueHD always throws the error that eac3to refuses to convert. Yes, I am running the latest version of both multiavchd and eac3to. I don't know what else I would need as eac3to is promoted as supporting TrueHD decoding out of the box without any additional files. I've searched high and low and I am at a loss on this one. I mean usually people have issues with DTS-HD to LPCM not TrueHD to LPCM.
Oh if it makes any difference I am running Windows 7 x64 with the latest windows 7 codec packages
DaFees is offline
Old 26th June 2010, 13:33   #10220  |  Link
tebasuna51
tebasuna51's Avatar
@DaFees
Please put the eac3to log.
eac3to
