7th July 2019, 16:24 | #41 | Link |
7th July 2019, 18:08 | #42 | Link |
Pig on the wing
Looks like a 3700X is the new 1700X as the best bang for buck. Hopefully we'll see a benchmark for the most used presets like slow, slower and veryslow.
We should really thank AMD for keeping the socket the same for all these years, upgrading gets very cheap.
7th July 2019, 18:56 | #45 | Link | |
used my x265 fhd benchmark http://forum.pclab.pl/topic/1184884-x265-FHD-Benchmark/ That guy also used the same benchmark but instead of fps showed elapsed time in seconds. To get fps you have to do this 2500/seconds. https://youtu.be/rcFUGSElZEs?t=8m18s
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th July 2019 at 19:01. |
7th July 2019, 19:34 | #46 | Link | |
Intel Xeon E5-2687W v2 @ 3.4GHz ( 8C / 16T ) y4m [info]: 1920x1080 fps 50/1 i420p8 sar 1:1 unknown frame count raw [info]: output file: NUL x265 [info]: HEVC encoder version 2.2+15-a18ab7656c30 x265 [info]: build info [Windows][GCC 6.2.0][64 bit] 8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main Still Picture profile, Level-4.1 (Main tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 5 / wpp(17 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut / bias: 50 / 500 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 rskip signhide tmvp strong-intra-smoothing x265 [info]: tools: lslices=6 deblock sao encoded 2500 frames in 131.23s (19.05 fps), 7025.74 kbps, Avg QP:37.21 I realize this is only one particular x265 test scenario, but if I can get a 3x speed improvement with the much slower preset I normally use for 1080p x265 I should be in the car heading to Microcenter to buy a Ryzen 3900X system right now. |
7th July 2019, 19:44 | #47 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th July 2019 at 19:47. |
7th July 2019, 21:40 | #51 | Link |
The 3900x is impressive, but I would also like to see some real world results. Benchmarks are great, but no one uses crf 28 to encode, or at least they shouldn't haha. I as well would like to see some crf 18-20 at slow, slower, very slow, slowest and placebo. Right now I encode my TV/Movie blurays on slow (1080P gets 5-7 fps), and anime on slower (1080P gets 0.8-1 fps if I am lucky!), with a Ryzen 2700. I haven't tried 4k yet as I don't own a compatible drive to rip the few 4k movies I own.
I score 21.97 fps on Atak's benchmark, and 3.03 on Sagitare's. |
7th July 2019, 21:46 | #52 | Link |
Some other x265 tests I found:
https://www.techpowerup.com/review/a...-3900x/13.html TPU seems to meassure plain x265 and x264 at crf mode and slow preset, instead of frontends like handbrake. https://nl.hardware.info/reviews/939...4-x265-en-flac Staxrip x264 + x265. They have interactive graphs and comparison with a lot of CPUs. |
8th July 2019, 00:13 | #54 | Link | |
I've been encoding 1080p at CRF 16 placebo 10-bit (8-bit source). It's ~0.25fps on my 8 or 10 core Ivy Bridge E5's. I have a lot of cores, but an old'ish CPU architecture. |
8th July 2019, 00:20 | #55 | Link | |
https://www.gamersnexus.net/hwreview...marks-vs-intel
8th July 2019, 04:40 | #56 | Link | |
I know not everyone will agree with me, but as someone who encodes and encodes, fps is far more important to me as every fps gained is an extra 2 or so minutes of footage encoded per hour (if I did the math right). Hence why I would like the actual results in that instead of time. |
8th July 2019, 10:05 | #58 | Link |
Slightly off topic but apparently the hardware HEVC encoder in the Navi RX 5700 is way powerful, much faster than h264 implementatin
See https://www.youtube.com/watch?v=Yi-_T3vsv-Q and https://www.youtube.com/watch?v=fY2fbAzFiUE |
8th July 2019, 18:00 | #59 | Link |
Ryzen 1600 vs 2600 vs 3600 in x265 FHD Benchmark
https://www.youtube.com/watch?v=-Zru...utu.be&t=3m28s
8th July 2019, 18:37 | #60 | Link | |
Ryzen 5 1600 - 18.73 fps Ryzen 5 2600 - 21.10 fps Ryzen 5 3600 - 32.71 fps The Ryzen 9 3900X has twice as many cores as the Ryzen 5 3600 and is almost twice as fast. It looks to be pretty close to linear. So the Ryzen 9 3950X should be about 33% faster than the 3900X in the benchmark (presuming the TDP doesn't clobber it). Last edited by Stereodude; 8th July 2019 at 18:40. |
