29th July 2020, 15:58 | #59822 | Link | |
29th July 2020, 16:34 | #59824 | Link |
@clsid
Ah, found it. It stays in 8 bit when fullscreen windowed or just windowed. Okay, but unfortunately this is not the root of my issue, the frame drops are still. So the change between 8 bit and 10 bit is not the issue :\ |
29th July 2020, 17:31 | #59825 | Link |
try to disable the IGPU in the bios for a test if that system allows that.
your system may just switch between the GPU when the 3D application stops using full screen. another thing you can try is forcing a GPU to run with MPC-HC. what so ever you get rendertimes that are clearly not normal and that may explain it. |
29th July 2020, 18:37 | #59826 | Link |
That is extremely unlikely any time soon. He is focused on launching the Envy. He had popped into the AVS thread a few weeks ago and said a new build was maybe going to drop "in a few weeks" but then came back and said he was being overly optimistic. And that new beta build is very unlikely to fix this problem even when it does eventually drop. So, we either live with the problem or stick with older drivers for now.
29th July 2020, 20:59 | #59827 | Link |
@huhn
The BIOS allows me to disable the Intel GPU. But the result... is the same. I also tried to set MPC-HC to use only Intel GPU, but the result is even worse with AMD. Still, I think AMD is always responsible for video out. You can't disable it. So at least one more confirmation that I think it is a AMD hardware/driver bug in relation to Windows OS. Sure, with high rendertimes, the result are frame drops. But I still don't know what's the cause (and why there is no issue in Vista mode...). When I set the task-manager on front, there is also no issue. So to fix the issue, "something" have to be displayed to keep Windows GUI busy (a 1x1 invisible pixel would be nice...?). And since the issue is also with other videoplayers, like the Netflix App (navigation bar fade in and out) or with Microsoft Movies & TV, it is unrelated to a software or madVR. But all have "something" in common. I created a new short video to summarize and show a little more detailed (with OSD): https://www.dropbox.com/s/axk0p9ois7...oppy5.mp4?dl=0 |
31st July 2020, 18:20 | #59830 | Link |
Is that how the BT2390 tonemapper works? compressing peak white to diffuse white?
EDIT: So where it says Target Peak Nits I should input 48nits? It doesn't allow any lower than 100nits which is only valid for surrounds of 5 nits -not dark surrounds-. Last edited by Dogway; 31st July 2020 at 18:50. |
31st July 2020, 19:44 | #59831 | Link |
Hi there, I'm wondering if someone might be able to point me in the right direction here. I'm trying to get 3d framepacking working.
I have Nvidia 3d 1080p/24 framepacking mode automatically being enabled when I start a 3d file. However the content is being displayed in Side-by Side mode rather than frame alternating. my display output is set to auto, the renderer settings are set to output 3d. I'm definitely using the LAV MVC filter. It seems to be actually mostly working, my TV is going into 1080p framepacking mode properly, the MVC stream must be decoded properly but it's showing in side-by-side mode for some reason. I can select other display outputs like over under etc and they work too, but I can't get it to output as framepacked even though my TV is going into framepacked mode just fine. one thing to note, I had to uncheck 'use DX11 for presentation' or it would outright crash the player when opening the file. Windows 10 1803 MPC-HC 1.9.6.7 LAV Filters 0.74.1 madVR 0.92.17 Nvidia 441.08 with 3D vision injected RTS 2060 Super 9700k Thanks. |
31st July 2020, 20:17 | #59832 | Link |
SDR should be calibrated to 100-120 nits, this way with BT.2390 a 10000 nits HDR peak white is mapped to 100 nits, and 100 nits are mapped to around 48 nits. If the HDR peak white is less than 10000 nits the compression is also less, for example, if it equals 1000 then 100 nits are mapped to around 69 nits.
31st July 2020, 20:56 | #59835 | Link | |
If you are in a black box (dark surround) diffuse white should map to 48 nits, 100 nits is for mastering or dim surrounds (link1, link2). I will ask madshi if he can allow lower target peaks, or better yet allow diffuse white mapping instead of target peak. This way we can lower SDR content from 100 nits to 48 within madVR, and do the same (via a profile group) with HDR content. |
1st August 2020, 22:58 | #59837 | Link | |
FYI, new nvidia drivers with 3d vision works excellent in 3d games, and 3d framepacked MVC players like Stereoscopic player and PowerDVD also work fine. (but can't compare to madvr quality!) |
