Old 11th January 2021, 22:55   #61181  |  Link
chros
chros's Avatar
@quietvoid, thanks, really interesting! I'll ask more if I manage to get that far
Old 11th January 2021, 23:29   #61182  |  Link
SirMaster
I also run my HTPC with madVR on a Linux server in a Windows VM and have done so for years.
VMs work just as well as dedicated machines, but easier to manage overall IMO.
SirMaster is offline   Reply With Quote
Old 12th January 2021, 00:12   #61183  |  Link
chros
chros's Avatar
Cheers
Old 12th January 2021, 12:09   #61184  |  Link
Will be interesting to see how the new AI upscaling processors on this years high end sets compare against madVR's algos, things may finally have caught up now.
Old 12th January 2021, 12:38   #61185  |  Link
jkauff
One thing they don't compare to is the price. The AI sets I've seen in the CES 2021 press releases seem to be mostly $3K to $5K.
Old 12th January 2021, 18:30   #61186  |  Link
el Filou
el Filou's Avatar
Originally Posted by senzaparole View Post
Hello! Thanks for the reply.
Here is the screenshot of MPC-HC in playback mode:
Here is the screenshot of MPC-BE in playback mode:
As other people commented, they look close enough at least this doesn't explain the amount of dropped frames.
What happens if in both players, instead of using the internal audio renderers, you manually select the DirectSound audio device (Topping?) ? Do the frame drops stop then?
I know this is not what you want, but it's to find out if the audio renderer is the cause.
Old 12th January 2021, 23:32   #61187  |  Link
senzaparole
thank you so much. Everything works as you thought.
I changed the audio renderer:
now MHC-BE is perfect:
I never thought madVR would get swayed by audio. I'm afraid there are no solutions. I would prefer to select "MPC AUDIO RENDERER" but it is not possible.
MPC-HC with its internal audio Renderer is no problem. MPC-BE only
Thanks everyone for the help, much appreciated.
TV:LG B9 65 Amplifier: Denon X4500H Front Speakers: n. 3 XTZ Cinema M6 Subwoofer: XTZ 10.17 EDGE Atmos Speakers:n. 4 XTZ S2 Surround Speakers: n. 2 XTZ Spirit 2 - HTPC: Fractal Meshify C-RX 5700 XT
senzaparole is offline   Reply With Quote
Old 13th January 2021, 01:05   #61188  |  Link
You should post all relevant info regarding this issue over in the MPC-BE forum so the audio renderer can be improved to prevent this from happening.
Wouldn't hurt to try the releases here download the standalone filters packages (x64)
and register it in the system it will then come up as another audio output that you can select in the drop down, then test and see if you can find a version that works without dropping frames.
Old 14th January 2021, 18:48   #61189  |  Link
robl45
MadVR 3d
Hello, I've been using lav filters and Madvr for 3d for 4 or 5 years now with no issues. About a week ago, it stopped working. Anyone know anything about this? I've reinstalled madvr and lav and still it doesn't work, when it does flip into 3d, its like the 3d is in slow motion. I thought it might be my hdmi to ethernet converters screwing something up so I connected the computer to my spare projector with straight HDMI and it did the same thing. I thought it was one specific file as we had literally watched 3d the day before and then realized it was all of them. Anyone have any ideas? I'm thinking a windows 10 update maybe or something broke it. Its a windows 10 machine with I3 processor Skylake with internal intel graphics.
robl45 is offline   Reply With Quote
Old 14th January 2021, 19:33   #61190  |  Link
el Filou
el Filou's Avatar
Impossible to say without more information, things do not break like that by themselves.
Under "View update history" in Windows Update settings, you can see exactly what date Windows installed updates, and also uninstall them. Maybe check that. Maybe it installed a new graphics driver?
Old 15th January 2021, 04:03   #61191  |  Link
robl45
Tried tonight after days of troubleshooting, reverted to previous version of windows and it works perfectly again, hopefully this helps someone.
Old 15th January 2021, 18:19   #61192  |  Link
el Filou
el Filou's Avatar
When you say "previous version", was it a monthly ("quality") update, or a full new release ("feature update")? Can you give the two versions before/after the update?
Old 15th January 2021, 23:36   #61193  |  Link
senzaparole
@el filou
@ryrynz
I solved the problem!!!!! In the MPC Audio Renderer settings it was enough to change the DEVICE BUFFER from 50 ms to DEFAULT!
Now I don't lose frames anymore and madVR's OSD is perfect!
Thanks for your help!
Old 16th January 2021, 00:40   #61194  |  Link
Cool thanks for letting us know.
Old 17th January 2021, 12:41   #61195  |  Link
webbo
Regarding the screenshot of madVR info - how did you manage to almost set / sync display Hz to video Hz ?
Setting the TV to 23 or 24Hz would that suffice?
Appreciated
HTPC Build : 8700k / 16GB DDR4 / 1080Ti GPU - Setup for FullHD / 4K MKV Playback - PotPlayer + madVR
Display #1 - 32GK850G
Display #2 - LG G3 OLED 55'' (ISF Calibrated)
webbo is offline   Reply With Quote
Old 17th January 2021, 13:18   #61196  |  Link
Klaus1189
23Hz is for 23.976Hz
24Hz is for 24.000Hz
Old 17th January 2021, 19:53   #61197  |  Link
Silver12
I have just downloaded beta 120, is there a way to copy HDR settings for different devices. I want to use the same settings, changing only DPL values. I don't know how to do that. Hopefully somebody can help me, thanks a lot to all of you
Silver12 is offline   Reply With Quote
Old 17th January 2021, 20:08   #61198  |  Link
VBB
VBB's Avatar
@webbo - That's AMD You won't get nearly as close with Nvidia, but it's not too bad right now (about a drop/repeat every 1.07 hours).
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 17th January 2021, 23:12   #61199  |  Link
senzaparole
Appreciated
Hello! It is madVR that changes the TV refresh rate adapting it to the native one of the movie.
Old 18th January 2021, 16:13   #61200  |  Link
ashlar42
I see a GTX 3050 could be coming. Would 4GB of RAM be enough for proper madVR use? I think GPU power should be plenty enough (but correct me if I'm wrong).
