Old 31st August 2009, 14:13   #5621  |  Link
m0nkie
is ripbot264 source code available for download?
m0nkie is offline   Reply With Quote
Old 31st August 2009, 22:14   #5622  |  Link
Betsy25
Hi Atak,
I have a problem with the PS3 not detecting a .AVCHD file.
It's the first time I actually use RipBot264 and I quite love it, but I don't know why the PS3 doesn't want to play it.
I copied over the output AVCHD folder and all its subfolders onto a USB-stick, perhaps that's not the correct way to do it ?
Betsy25 is offline   Reply With Quote
Old 31st August 2009, 22:55   #5623  |  Link
stryker412
Has anyone had any luck converting "The Dark Knight"? It stops only 1 minute or so into the process.
stryker412 is offline   Reply With Quote
Old 31st August 2009, 23:01   #5624  |  Link
dbone1026
I converted The Dark Knight without a problem with Ripbot (8GB mkv) but this was done when teh movie first came out on Blu Ray so it would have been an older version of RipBot
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline   Reply With Quote
Old 1st September 2009, 00:16   #5625  |  Link
use dvd+rw. copy only directories inside .avchd folder.
Old 1st September 2009, 00:40   #5626  |  Link
stryker412
Yep I tried again and it crashed x264_x86.exe. It's odd because Ripbot has been working fine on other movies.
Old 1st September 2009, 08:02   #5627  |  Link
m0nkie
Originally Posted by m0nkie View Post
atak_snajpera
why am i being ignored???
Old 1st September 2009, 13:54   #5628  |  Link
Betsy25
Well, my first .mkv to .AVCHD hasn't quite produced what I expected, the output .m2ts produces extremely tall and skinny persons (wrong .DAR i suppose).
Input File:
General
Complete name : O:\Other DVD\Short Circuit\Converted\shortcircuit.mkv
Format : Matroska
File size : 1.07 GiB
Duration : 1h 38mn
Overall bit rate : 1 559 Kbps
Encoded date : UTC 2008-05-30 18:36:30
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 38mn
Nominal bit rate : 1 355 Kbps
Width : 720 pixels
Height : 352 pixels
Display aspect ratio : 2.424
Original display aspect ratio : 2.045
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.223
Writing library : x264 core 59 r859M ce13bb6
Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / fgo=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1355 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : A_AAC
Duration : 1h 38mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 16 bits
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Output:
General
Complete name : C:\RipBotOutput\AVCHD\shortcircuit.AVCHD\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.90 GiB
Duration : 1h 38mn
Overall bit rate : 5 668 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, ReFrames : 3 frames
Duration : 1h 38mn
Bit rate : 4 795 Kbps
Nominal bit rate : 4 691 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 1.500
Standard : NTSC
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.579
Stream size : 3.30 GiB (85%)
Writing library : x264 core 68 r1195M 5d75a9b
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc=2pass / bitrate=4691 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 451 MiB (11%)
Language : eng / eng
This is the script used in RipBot264.
#MT
#VideoSource
video=DirectShowSource("O:\Other DVD\Short Circuit\Converted\shortcircuit.mkv",audio=false).ConvertToYV12()
#Deinterlace
#Decimate
#Crop
video=Crop(video,0,0,-0,-0)
#Resize
video=Spline36Resize(video,720,462).Sharpen(0.2).AddBorders(0,9,0,9)
#Colors
#Denoise
#Subtitles
Loadplugin("C:\Program Files\RipBot264\Tools\AviSynth plugins\VSFilter\VSFilter.dll")
video=TextSub(video,"E:\temp\RipBot264temp\job1\shortcircuit.srt",-1,23.976)
#AudioSource
LoadPlugin("C:\Program Files\RipBot264\tools\AviSynth plugins\BassAudio\BassAudio.dll")
audio=BassAudioSource("E:\temp\RipBot264temp\job1\audio.1.aac")
audio=ResampleAudio(audio,48000)
#DownMix
Import("C:\Program Files\RipBot264\Tools\AviSynth plugins\Scripts\DownMixAudio.avs")
audio=DownMix2Stereo(audio)
#Delay
audio=DelayAudio(audio,0)
#Tempo
#Normalize
#AudioDub
audio=ConvertAudioTo16bit(audio)
AudioDub(video,audio)
#Triming
#AVSameLength
#ColorSpace
ConvertToRGB
Input file plays perfectly fine, output file play everything stretch out horizantally.
Please excuse me, I'm only starting.
Old 1st September 2009, 14:04   #5629  |  Link
Where did you get the MKV file?
Old 1st September 2009, 14:31   #5630  |  Link
Betsy25
Hhhhhh, here we go again....
As I stated early, I created an .mkv backup (as that was the best method that time) of my ORIGINAL dvd about a good year ago, I bought the DVD for, as far as I remember €6.95 if you want as much details as possible. I sold it on Yezzz! (a Belgium second held site for selling and buying second hand stuff).
I created an .mkv because that was then the best format regarding quality/size-wise.
I'll try to find an AnyDVD log file, hopefully it wasn't deleted since I altered quite a lot on my XP partition since then.
May I ask you a question neuron, don't take this as an attack, but why is the trend here to help and support countless touls that are aimed at creating an .MKV from a DVD, but once someone is willing to use that .mkv as an imput all hell breaks loose, and the pirate fingers are all around.
I now don't have the original anymore, and I want to watch the movie on my PS3, but this ones doesn't support .mkv (If I only knew that, I perhaps wouldn't have bought a PS3 in the first place, since I only use it for media, not for it's (crap) games)
May I ask you this serious request : PLEASE! BAN every front-end creators that allows users to create an .mkv file from a DVD source. At least then your own soul will be treated.
Old 1st September 2009, 16:44   #5631  |  Link
I've deleted all posts subsequent to this rule violation. I'm striking this due to your poor attitude. Do not post about this issue again.
Old 1st September 2009, 22:32   #5632  |  Link
prettyboy85712
Negative
prettyboy85712 is offline   Reply With Quote
Old 2nd September 2009, 02:42   #5633  |  Link
Tycketoryde
Ripbot & 1080i and 29.97 fps
Ripped a Region "A" Disk. TSmuxer shows it as 1080i and Ripbot's "Media Info" as 29.97 fps. Its quite obvious watching the M2TS File that the Movie is interlaced, and needs to be deinterlaced.
I'm certain I did not accidentally change the FPS anywhere, as that's is, for all Intents and Purposes, rather pointless.
.ts or .m2ts file Loaded into Ripbot (without making any changes to the "Output Speed" or changing any "Default Settings" within the "Properties" Button), it shows as follows:
FPS: 1387.35
Frames: 12,391,495
Duration: 2:28:51:773
There is no Way it's 1387.35 FPS, nor 12 Million plus Frames. The only Thing correct here is the Duration of the Movie. So I go ahead and start the 2-Pass encode, and it tells me it takes 143 Hours to finish the first Pass.
So I abort, and try the 23.976 FPS Setting, hoping this might correct things, since most rips are 23.97 FPS.
And now it reads as follows:
FPS: 23.976
Frames: 12,391,495
Duration: 143:33:49:123
In other words, the Movie would be 143 Hours long when done.
Ripbot's "Deinterlaced" Function is greyed out, so obviously either Ripbot or the h264 Encoder cannot deal with it.
This is the first and only time I have ever run into this, and only with this particular Title.
Your average Movie has about 150,000 Frames, not 12 Million, so I figure it must be accounting for the interlaced picture portions, maybe not?
Nevertheless, what is the Solution for this? Where is the Hitch that prevents x264 encoding, preferably in under 300 Hours? With well over 250 encodings using Ripbot, I have never even run into even 1 single Hick-up with it, but this one has left me utterly dumbfounded.
Old 2nd September 2009, 02:48   #5634  |  Link
hbcsavage
I have a bit of a problem im trying to backup a bluray with ripbot.I know how to use ripbot but this is the first time i get an error when i load the file into ripbot. After it says analyzing there is no playlist no audio and no subs. When i click ok i get this DirectShowSource:
couldn't open fileL:\temp\ripbot264temp\job1\video1.mkv:the system cannot find the file specified.
command line: "C:\Users\Savage\Downloads\RipBot264v1.14.3\Tools\eac3to\eac3to.exe" "C:\Users\Savage\Documents\00000.m2ts"
The format of the source file could not be detected. <ERROR>
Error: The source file 'L:\temp\RipBot264temp\job1\video.mkv' could not be opened successfully, or retrieving its size by seeking to the end did not work.
Do i have some off settings or something?Can someone help?
hbcsavage is offline   Reply With Quote
Old 2nd September 2009, 15:05   #5635  |  Link
stryker412
Has anyone gotten "The Dark Knight" to work with ripbot?
Old 2nd September 2009, 18:41   #5636  |  Link
roise_r
hello there, i didnt realize that there is a specific RipBot thread, so i posted my question here. if u guys can , please take a look.
roise_r is offline   Reply With Quote
Old 2nd September 2009, 20:41   #5637  |  Link
@Tycketoryde
Can you send me 50 mb sample? Use DGSplit and this site www.mediafire.com
Old 2nd September 2009, 22:36   #5638  |  Link
mcgoxel
im getting error when clicked RipBot264.exe
vista 64 bit enterprise sp2
note:its first click to enter the progrram.
mcgoxel is offline   Reply With Quote
Old 3rd September 2009, 03:58   #5639  |  Link
TheProfosist
TheProfosist's Avatar
i have a huge problem it started after i re did 2 pc's i wil setup a files to srt click start and it will immidately tell me the file is finished converting. this has only happened once i re did 2 computer and i can figure out what im doing differently that is causing this to happen
TheProfosist is offline   Reply With Quote
Old 3rd September 2009, 04:01   #5640  |  Link
Tycketoryde
@Tycketoryde
Done. ---> 50MB Sample
50MB (00001.ts_0) uploaded, done with DGSplit. Shows the first Half Minute Warsaw City Overview 1939 in Black & White as Background Lead-in Intro for the Main Movie Feature filmed in 2001.
I loaded that very first split Part into Ripbot and it reads as follows:
FPS: 1387.5
Frames: 44301
Duration: 0:0:31.932
Again, the "Duration" is correct, "FPS" & "Frames" are off.
The other Parts, even if renamed to .ts ... will not load into Ripbot without "avs" Error Messages.
I also copied a 50MB Chunk from the beginning of the Movie with TSRemux, and loaded that into Ripbot as well. All Infos were 100% correct. It appears DGSplit & TSRemux do not function the same Way when extracting a Portion. I sent up per your Request the DGSplit Portion.
However, larger than 200 MB Chunks extracted with TSRemux also show the Errors as above.
I also just tested this Movie by dropping it into "ConvertXtoDVD 3.51". Did the Job in the usual Time, burned the DVD-R, plays perfectly on my Home DVD Player.
"TMPGEnc 4.0 Express" correctly shows 267,685 Frames, but hangs after 2 Minutes of encoding to BDVM. Pretty much the same happens when encoding to DivX.
In "ConvertXtoBD" (or whatever that Front End is called), also lists the Movie as having more than 12 Million Frames, detecting it primarily as a "Telecine" Composition.
