8th May 2010, 05:44 | #7621 | Link | |
eac3to GUI You can use tsMuxer to demux audio tracks and convert them separately. tsMuxer can also remux the video, audio, and subtitle files if you want separate versions. It will do MKVs and AVCHDs. |
8th May 2010, 07:05 | #7622 | Link |
I see that you didn't understand my problem (
Can I encode IN THE SAME TIME 2 , 3 or 4 sound tracks using Ripbot ???...like subtitles , for instance.... I think NO ...also every DTS or other kind of sound tracks is automatically converted to AC3 file. My problem is how to resize the sound files ??? Does eac3to has an interface to easy work with it ??? Last edited by benjyv; 8th May 2010 at 07:25. |
8th May 2010, 11:22 | #7624 | Link | |
EDIT - nevermind, you are talking about burned in subs, I am talking about IDX/SUB subs muxed in
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net Last edited by dbone1026; 8th May 2010 at 11:27. |
8th May 2010, 14:01 | #7626 | Link | ||
8th May 2010, 14:59 | #7628 | Link |
Can do otherwise, only video.
But to convert only the audio will have to use eacto3. This tutorial can help > http://forum.videohelp.com/threads/3...-MKV-720P-file |
8th May 2010, 15:51 | #7630 | Link |
@Atak_Snajpera
I hardly encode these days not even with StaxRip but since I got a new monitor I'm playing around now with different applications checking how fonts look. Until today I had 17" 1024x768 analog monitor, a good Samsung SyncMaster. In RipBot264 fonts were very hard to read, I remember you said you expect people to have a good LCD so I though problem is probably my analog monitor. Now I have a Samsung P2370 which is 23" at 1920x1080 using 150% system font size, it looks just as bad as before , very hard to read. In the 'Encoding settings' dialog, fonts look really really bad here. You probably have perfect eye sight and a perfectly adjusted high quality LCD but I guarantee you there are countless users were things look very very bad due to bad eyes, bad monitor or both. My eye sight is poor, I'm 34 now and sadly it gets a little bit worse every year.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th May 2010 at 16:27. |
8th May 2010, 19:58 | #7631 | Link | |
8th May 2010, 20:05 | #7632 | Link | |
Also, shouldn't I use AVC level 4.1 for DXVA or even 5.1 because I'm using nVidia Ion for decoding? |
8th May 2010, 21:09 | #7633 | Link | |
@stax76
this test will tell you how good display you have there http://www.lagom.nl/lcd-test/ in contrast test I see all steps in black levels i see all blocks. even number 1. in white saturation I barely see 252. 253 and 254 is not visible for me. and everything on my old LG monitor (contrast and brightness set at 65%) font color is 160,160,160 on 255,255,255 background. You should be able to see them very well. Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th May 2010 at 21:19. |
8th May 2010, 22:11 | #7634 | Link |
@Atak_Snajpera
After some monitor corrections according to your test it looks better, still a bit difficult but better.
9th May 2010, 20:45 | #7636 | Link |
I didn't know that x264 is not multithreaded.
10th May 2010, 02:55 | #7637 | Link |
HD-Fan
lol, I know you're mad when someone asks you "easy" things but I do know x264 can run silumtaneously (I do that all the time in MeGUI with multiple workers) but in RipBot264, when I click on RipBot264.exe one more time, it keeps saying it's still in memory! So it won't open up another RipBot264. That's why I asked if it's possible to do the same like MeGUI or not since I'm not completely familiar with RipBot264 yet.
10th May 2010, 09:19 | #7638 | Link | |
It occupies the entire memory or processor and two parallel programs can not work. Moreover the software has been designed to ease your work and not obstruct it.. Supposing you could run two or three programs at once, during the encoding , logic , the time will increase proportionally, no matter how powerful your computer should be.. |
10th May 2010, 14:01 | #7639 | Link | |
HD-Fan
@the time will increase proportionally I don't know how RipBot264 will be programmed to run in parallel later in the future but if it's going to be like MeGUI, then the time won't increase for me. I have tried converting 4 HD (1080p) videos at the same time and they all encoded as fast as if I were running a single conversion. By the way, can the speed of conversion ruin my output quality? Because I am still using the same profile as before (I got 25-30 fps conversion speed) and now when I use this profile on a faster computer it goes up to like 120-140 fps) :\ I like the speed increase but just want to confirm it if quality can be worse before I make profile a little heavier. |
10th May 2010, 23:40 | #7640 | Link |
I've mirrored the file here: http://techmunchies.net/forums/index...pbot264-v1151/
I will continue to update the mirror when new releases come out. |
