19th February 2014, 05:47 | #19281 | Link | |
Not sure about PowerDVD. Are you sure it is burning without errors? I'll do a couple of full backups of some series discs tonight to BD-9 just to make sure nothing has happened. But, honestly, I don't think there will be any issues. Last edited by jdobbs; 19th February 2014 at 06:01. |
19th February 2014, 06:49 | #19282 | Link |
Ya my player plays avchd all the time. Like i said, this is the first time ive done a TV Series type disc and i dont know if they need to be ripped/burnt some specific way...
If you get a positive working backup, let me know how you did it! Id greatly appreciate it! |
19th February 2014, 08:04 | #19283 | Link |
Pop-up error: tsmuxer.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
Seriously, that log was about it. Here is the full log going from a BD25 to BD25 movie only (just for the quick log): Code:
[02/19/14] BD Rebuilder v0.46.13 (beta) [01:59:35] Source: *** - Input BD size: 21.79 GB - Approximate total content: [02:09:44.777] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), CRF - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [01:59:37] PHASE ONE, Encoding - [01:59:37] Processing: VID_00001 (1 of 1) - [01:59:37] Extracting A/V streams [VID_00001] - Error in attempt to extract audio/subs. - Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com [02:00:07] - Failed to retrieve audio, aborted Edit: Yeah, swapped out the tsmuxer.exe with an older one and it works fine. Something hinky in new version. Edit 2: Just tested a dozen versions of tsmuxer, I can't run any version past 1.10.6. Something in the new code either doesn't like my WinXP or old CPU. Hopefully, I can keep copying 1.10.6 into your new releases and it'll work. My PC isn't getting upgraded any time soon and I sure won't want to be doing without BDRB. Edit 3: Noticed something else. "Input BD size" shown in the log still includes the disabled audio and subtitle tracks. I've now seen this force an unnecessary re-encoding. It probably also causes undersized discs. Last edited by DoctorM; 19th February 2014 at 09:40. |
19th February 2014, 14:55 | #19285 | Link | |
19th February 2014, 15:55 | #19287 | Link |
hey jdobbs, any luck with the season bd?
Any possibility the issue could be similar to what Sharc was having? Maybe i should be using Quick-Play instead of Full Backup options for TV series blurays and BDR is having an issue with menus for them? |
19th February 2014, 16:15 | #19288 | Link | |
I had a crash during my series backups last night (something entirely my fault due to some test code), so they didn't complete. I'll have to run them today sometime. |
19th February 2014, 16:45 | #19289 | Link |
I decided to play with this a little... one other note (in addition to my original response): It seems FRIMDecode can't decode VC-1 interlaced files (or at least the one I'm trying right now from M2TS imput). It seems to just freeze and never output anything.
19th February 2014, 17:51 | #19290 | Link |
Did a Full backup of La Grande Illusion (StudioCanal Collection) to BD25 on BD-RB v0.46.11. Process finished without errors but the backup won't play on anything. A Blu-ray mastering application could not open the backup, it simply complained something about being unable to initialize BDMV content.
I'll do another run on the new version of BD-RB. |
19th February 2014, 19:20 | #19293 | Link |
DVD5 is brutal. How much video is there?
Or to make it short...what bitrate is used to reencode? For HD you really shouldn´t go below 4Mbit. Differences will be visible eventually. On my 55" Samsung TV BD Backups look fine....With my Epson Beamer on 90" Canvas I can see the difference between original Blu-Ray and BD25 !!! |
19th February 2014, 19:40 | #19296 | Link | |
My settings are the default that comes with BD-RB, except I am using DGDecNV. But that would have no effect on the structure of the output. |
19th February 2014, 19:50 | #19297 | Link |
I completely understand you not supporting a really old CPU. I'll continue to swap tsmuxer or use old versions as long as I have to. That's my problem.
But the calculations for that take place before Tsmuxer becomes involved. Unless you've addressed an issue with the "BD Input Size" being wrong recently, you should take a look. Same log: http://forum.doom9.org/showthread.ph...41#post1669241 The original M2TS is 21.79gb as being reported, but more than a gig of audio tracks were disabled there. BDRB doesn't deduct that and forces a re-encode even though only a rebuild is needed. True for Movie Only and Movie with Menus. |
19th February 2014, 19:57 | #19298 | Link | |
The determination as to whether it is kept intact is made when the file is extracted. If the video + kept-audio + kept-subtitles are small enought to hit the target without encoding... then encoding is avoided. Last edited by jdobbs; 19th February 2014 at 20:09. |
19th February 2014, 20:41 | #19300 | Link | |
Also, DGDecNV is not freeware and does not come with BD-RB. Your best bet might be to uninstall BD-RB, AVISYNTH, HAALI, and FFDSHOW -- and then reinstall everything following the first post of this thread exactly. Last edited by jdobbs; 19th February 2014 at 20:44. |
