19th January 2018, 09:15 | #62 | Link | |
21st January 2018, 16:35 | #63 | Link |
I've had success but most of the time, before I can even get it into a folder format, TSMuxer gives me this error:
Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: H:\Batman v Superman Dawn Of Justice (2016) (UHD) (BD100)\BDMV\STREAM\00000.m2ts Any ideas, suggestions or settings? All I am doing is dropping in the m2ts and creating Blu-ray folder. The film "Hidden Figures" loses it's HDR for some reason too after running through TSm2UHD |
21st January 2018, 19:09 | #64 | Link | |
Elit Amans
The reason it looses the HDR is discussed earlier in this thread. //LD |
22nd January 2018, 06:41 | #66 | Link |
I ripped (via MakeMKV) then demuxed and remuxed (both via tsMuxeR) the main movie file of my copy of BladeRunner 2049. I did not reencode video or audio, as I wanted to make sure all streams were 100% UHD-BD compliant (though I did cut out a couple of foreign language audio tracks). The resulting BD structure was 81 GB, so I burned to a new Sony BD-RE XL 100GB disc using my new Asus BW-16D1HT at the rated maximum of 2x burn speed.
The resulting disc was not recognized as UHD-BD at all in either my LG UP870 UHD-BD player, nor my Xbox One S. I then ran TSM2UHD on the remux from above, and reburned as above: same results on both players. I don't have UHD-BD playback ability on my PC, as the requirements are insane, but reading from the same drive that burned it, I can play back the main-movie m2ts file, for what that's worth. To do further testing, especially on the disc itself, I remuxed a very brief pre-movie m2ts file from a different UHD-BD title, burned it to the same BD-RE XL 100GB disc, and attempted to play it back: raw tsMuxeR output failed to be recognized by either player, as did the TSM2UHD-processed files burned later. Realizing that the above may point to nothing other than the possibility that (my) UHD-BD players do not play nice with BD-RE XL 100GB discs, I reburned the final TSM2UHD-processed files to a BD-RE DL 50GB disc: it did play on both players, though with stuttering. This was ripped from a 66GB UHD-BD, and the Xbox showed spikes of 100 Mbps, so that is not surprising. Anyway, I don't yet have any (non rewriteable) BD-R XL 100GB discs to test with, those these may (hopefully will) be readable in my players (and all players generally). I am unaware of any UHD-BDs that have been pressed to 50GB discs, and I am still unsure of how to get 100% UHD-BD compliance when reencoding video, so for now I'm at an impasse as regards contributing to testing. If anyone is aware of any available UHD-BD releases on 50 GB discs, please let me know. Last edited by A.Fenderson; 22nd January 2018 at 06:49. |
22nd January 2018, 08:52 | #67 | Link |
BD50 UHD's Alien Covenant Hidden Figures Boss Baby, The Captain Underpants - The First Epic Movie Despicable Me 1 and 2 Lego Batman Movie Rise Of The Planet Of The Apes Prometheus Texas Chainsaw Massacre (1974) Underworld 5 - Blood Wars Dark Tower, The Emoji Movie, The Fantastic 4 (2015) Hitman - Agent 47 Keeping Up With The Joneses Lego Movie, The Mike and Dave Need Wedding Dates Peanuts Movie, The Rough Night Trolls Wild Lego Ninjago Movie, The Morgan Sausage Party Also, BD-RE XL do not work in my Oppo 203 either. BD-R XL do. I sent them some test copies and they updated their firmware. |
22nd January 2018, 09:17 | #68 | Link |
I spot-checked a few of those titles against the blu-ray.com and highdefdigest.com listings, and all were stated to be 66GB discs. Where did see them stated to be 50 GB discs?
I did order a 5-pack of BD-R XL 100 GB discs for testing. |
22nd January 2018, 14:54 | #70 | Link | |
23rd January 2018, 16:14 | #74 | Link | |
@geheim Did DVDFab mux in an ATMOS track with it? |
23rd January 2018, 17:42 | #75 | Link | |
24th January 2018, 18:57 | #77 | Link |
Anyone:
I've found another extension related to UHD-BD. It is in the index.bdmv file and is identified by ID1=3, ID2=1. Does anyone have any idea what this extension contains? As for the extension found in the MPLS file, I thought I'd share that after dumping it out and some investigating, it contains the HDR information for the playlist. It is represented by ID1=3, ID2=5 and holds the HDR specifics including: G, B, R and white point (WP) x/y pairs in units of 0.00002. The Luma (L) min (in units of .0001) and max (as a whole number), the maximum content light level (MaxCLL) and the maximum frame average light level (MaxFALL). The G,B,R,WP information has been consistent with Display P3 in every example I've seen (where HDR is present). Last edited by jdobbs; 24th January 2018 at 19:04. |
24th January 2018, 21:50 | #79 | Link | |
"ExtensionData": [ { "ID1": 3, "ID2": 1, "data_block": [ 0, 0, 0, 8, 81, 0, 2, 0, 0, 0, 0, 0 |
25th January 2018, 01:50 | #80 | Link |
I have some good news. The extension (see the reply above from ocean) to the index.bdmv has fixed some issues.
The comments I'd made earlier about always having to reencode because of bitrates doesn't seem to apply now. I've taken several original streams and muxed them directly without reencoding and they appear to work fine when burned to a BD-50 (both RE and R). The cause of the stuttering was apparently caused by the lack of the index.bdmv extension providing the player some needed information. My thanks to ocean and geheim for helping close another gap on the backup capability of UHD-BD. I'll release a new version of TSM2UHD with this and a couple other fixes in day or two. Last edited by jdobbs; 25th January 2018 at 01:53. |
