14th May 2020, 15:56 | #1783 | Link |
Natty, could you explain what you are trying to do? For instance, are you trying to merge part of video #1 and then append part of video #2, to make just one video? Or do you want specific frames from video #2 interspersed with video #1 as the output video?
14th May 2020, 19:20 | #1786 | Link |
So you are saying that msvc builds are no longer faster than gcc builds on intel cpus? Also, is there a way we can force the encoder to use avx2? I have seen x265 builds with avx2, avx tags and supposedly, for avx2 pcs, avx2 builds are slightly faster.
14th May 2020, 19:35 | #1787 | Link | |
"Performance Options --asm <integer:false:string>, --no-asm x265 will use all detected CPU SIMD architectures by default. You can disable all assembly by using --no-asm or you can specify a comma separated list of SIMD architectures to use, matching these strings: MMX2, SSE, SSE2, SSE3, SSSE3, SSE4, SSE4.1, SSE4.2, AVX, XOP, FMA4, AVX2, FMA3, AVX512 Some higher architectures imply lower ones being present, this is handled implicitly. One may also directly supply the CPU capability bitmap as an integer. Note that by specifying this option you are overriding x265’s CPU detection and it is possible to do this wrong. You can cause encoder crashes by specifying SIMD architectures which are not supported on your CPU. Default: auto-detected SIMD architectures" |
14th May 2020, 20:09 | #1789 | Link | |
Thank you |
15th May 2020, 09:26 | #1794 | Link | |
@Arkana
Code 126 means ERROR_MOD_NOT_FOUND, it should mean DLL could not be found but unfortunately Windows does not tell which DLL, it could be a dependency. Quote:
15th May 2020, 15:02 | #1795 | Link | |
Noob
i can get that to work with my AVS/VS script and there are many other things which can be done but for that to work. i think i would need to index 2 - 3 videos at once. or is it possible without it? |
15th May 2020, 15:22 | #1796 | Link | |
15th May 2020, 15:48 | #1797 | Link |
good morning people,
I'm having problems with staxrip using VapourSynth, since they released the new version r49 I can't use staxrip stable or beta, only previous versions like r48. now released version VapourSynth r50 and the same error occurs see the printscreen. when loading the video file it already gives error of VapourSynth did anyone experience the same problem? NOTE: I have already tried the portable version and the problem continues, if using R48 it works normal, this version of python 3.8 is installed. thank you https://imgur.com/u0s41qb I couldn't post the photo sorry, but I leave the link to the photo. who can help me thank you. Last edited by jonrodrigos; 15th May 2020 at 16:02. |
15th May 2020, 16:42 | #1798 | Link |
@jonrodrigos
Probably your vapoursynth setup does not work, it happens often. If you use the last staxrip beta 2.1.1.2 you can use the included portable vapoursynth version, to do so there are two ways: 1. Uninstall python and vapoursynth 2. Go into the Apps dialog and define a custom path to the included python and vapoursynth version
15th May 2020, 17:27 | #1799 | Link |
staxrip recognized the location? go to apps > manage > on the left list avisynth > KNLMeansCL > status OK? the same for vapoursynth: apps > manage > on the left list vapoursynth> KNLMeansCL > status OK? if not, then go to path > browse and locate the file manually for avisynth and vapoursynth
StaxRip folder\Apps\Plugins\Dual\KNLMeansCL\KNLMeansCL.dll Last edited by almanteka; 15th May 2020 at 17:30. |
15th May 2020, 17:40 | #1800 | Link | |
any video file when it finishes loading it presents this error. I already did a virtual pc to test and the same happens. Last edited by jonrodrigos; 15th May 2020 at 17:44. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
