Old 27th July 2019, 12:23   #801  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by manolito View Post
Can I safely ignore this for the 32-bit version, or am I playing with fire?
I remember the version you are talking about, as it was the one I was using. One of the things I'm thinking about is that with the old version, whenever a bit-depth higher than 8bit was detected, it used to output 16bit stacked or interleaved by default, while FFMpegSource2 had an option to allow the "10bit hack", otherwise everything was going to be outputted in 8bit by default. Later on, when Avisynth+ came out, ffms2 was updated to support higher regular planar bit depth available on Avisynth+ and the 10bit hack was removed, therefore the poor Avisynth users were left with 8bit only capabilities.
Now, I have no idea whether LWLibavVideoSource has been updated the same way ffms2 has been updated back in the days, but if it was, I'm afraid Avisynth 2.6.1 won't have high bit depth available (I haven't tested the new version, though).
Anyway, I know that you don't really encode high bit depth stuff and you don't make use of particular color curves and so on, so, if this is the only difference between the old and the new version, it might work for what you have to do as well.
Old 27th July 2019, 12:49   #802  |  Link
qyot27
qyot27's Avatar
The 10bit hack was a patch that was only ever present in SAPikachu's builds. It was never present in upstream FFMS2's codebase, and was therefore not 'removed' when support for all* of AviSynth+'s pix_fmts was added.
*for a given value of 'all'. Not even FFmpeg supports all the pix_fmts AviSynth+ does, and FFMS2 is obviously limited to just what FFmpeg supports.
Old 27th July 2019, 13:03   #803  |  Link
StainlessS
StainlessS's Avatar
What confused me is that the readme says that this is a plugin for AVS+ and VapourSynth, no mention of classic AVS. Can I safely ignore this for the 32-bit version, or am I playing with fire?
Unless it says something like "Specifically AVS+ only", then is OK on AVS Standard.
Avs+ (and usually AVS+ plugins) are backward compatible to avs 2.60/61. [there is little reason not to be compatible]
EDIT: I just happened to stumble across this, not long after posting above.
RawSourcePlus
Loading raw video data from files
for Avisynth+ r2150 or greater
This filter is only for Avisynth+MT. Avisynth2.6 is not supported.
requirements
Windows Vista sp2 or later
Visual C++ Redistributable Packages for Visual Studio 2015
Dont think I've ever seen any AVS+ specific filters before.
I sometimes post sober.
Old 27th July 2019, 15:29   #804  |  Link
Groucho2004
This post says otherwise:
https://forum.doom9.org/showthread.p...43#post1768843
Groucho's Avisynth Stuff
Old 27th July 2019, 15:50   #805  |  Link
StainlessS
StainlessS's Avatar
Sorry, that was from Version 2016-08-14,
Chikuzen post from 28th May 2016, so is earlier than my quote.
From rawsourceplus-20160814.zip RawSourcePlus.html
This filter is automatically registerd as MT_SERIALIZED.
You don't have to set it yourself.
original author:Ernst Peché, 2005-10-13
modified by Oka Motofumi, 2011-06-14
Version 2016-07-07 - Modified RawSource26 to Avisynth+ plugin. Version 2016-08-14 - Update for Avisynth+ r2150 or later.
EDIT:Here:- https://github.com/chikuzen/RawSource_2.6x/releases
Chikuzen link to Binary has it on GitHub.
Old 27th July 2019, 15:53   #806  |  Link
Groucho2004
I don't see anything in the code (on github) that would suddenly stop it from working with AVS2.6. That could be tested easily, I guess.
Old 27th July 2019, 15:57   #807  |  Link
StainlessS
StainlessS's Avatar
Yup, I aint tested it, aint even tried it.
Me gots several hundreds of dlls to be tried, one day.
[probably got a dozen or so of yours, which actually just need dumping as using later ones]
Old 27th July 2019, 16:21   #808  |  Link
Groucho2004
Bloody hell
Old 27th July 2019, 17:08   #809  |  Link
StainlessS
StainlessS's Avatar
Bloody hell
A slight underestimation actually (some of below are probably non avs dll's, maybe avs tools or zips which I'm not sure of the contents, but most are avs dll zips[some may be extracted]).
EDIT: Some of the folders are collections, eg mg262 colection, or D.Horman [alas, no longer with us] etc.
EDIT: More than once, someone has made a request for source or dll, and nobody else seemed to have it.
(actually got about 3 or four more Firefox download folders which contain loads of stuff, and as yet uncatagorised, will be loads more dll's/zips in those too).
Old 27th July 2019, 19:02   #810  |  Link
That wallpaper screams A e s t h e t i c s
Old 27th July 2019, 19:34   #811  |  Link
StainlessS
StainlessS's Avatar
Arh, a fellow sybarite, then here just for you, my beloved W95 Red Tile[Admin] + about 4/5 more colors (~=2KB)
http://www.mediafire.com/file/sx5rgz.../TILES.7z/file
Old 30th July 2019, 16:32   #812  |  Link
StainlessS
StainlessS's Avatar
OK, Tried RawSoucePlus() on avs v2.60 standard, crashes.
00000100    16:28:48.211    GetSeq: Multi-SourceFilter Attempt open of Video File
00000101    16:28:48.211    GetSeq:     'D:\GetSeq_Test\TEST\elephants_dream_480p24.y4m'
00000102    16:28:48.398    GetSeq: Has 1 Video streams.
00000103    16:28:48.398    GetSeq: Has 0 Audio streams.
00000104    16:28:48.398    GetSeq: Attempt Open Video with RawSourcePlus.
00000105    16:28:48.414    GetSeq: *** Catch *** Evaluate: Unrecognized exception!
00000106    16:28:48.414    GetSeq: ([GScript], line 83)
00000107    16:28:48.414    GetSeq: ([GScript], line 86)
00000108    16:28:48.414    GetSeq:
00000109    16:28:48.414    GetSeq: !!! Set !!! ... FFMS CacheFile = C:\Users\root\AppData\Local\Temp\elephants_dream_480p24.y4m.ffindex
00000110    16:28:48.414    GetSeq: Attempt Index Video for FFVideoSource.
00000111    16:28:52.142    GetSeq: Attempt Open Video with FFVideoSource.
00000112    16:28:52.158    GetSeq: OK ... FFVideoSource opened Video.
00000113    16:28:52.158    GetSeq: Time taken to Open clip = 3.952888 Seconds(0.065881 Mins)
Old 30th July 2019, 16:47   #813  |  Link
Groucho2004
Script?
Old 30th July 2019, 16:51   #814  |  Link
StainlessS
StainlessS's Avatar
c = vFn.RawSourcePlus(fpsnum=num,fpsden=den)
Old 30th July 2019, 16:54   #815  |  Link
Groucho2004
I don't get what GScript and FFVideoSource have to do with it...
Old 30th July 2019, 17:57   #816  |  Link
StainlessS
StainlessS's Avatar
I'm using it in GetSeq(), via this lot
# END OF GetSeq.avsi
#Import(".\GetSeq.avsi")
#FN="E:\Starwars\SW.avi"
#FN="D:\Parade.avi"
#FN=".\TEST\10Bit_Standard8_Scan_16FPS.avi"     # This 10 bit dont load with Avisource(), [and no audio]
#FN=".\TEST\ALTEST2.mp4"
#FN=".\TEST\heima_720p_500.mp4"
#FN=".\TEST\tears_of_steel_1080pwebm.webm"
#FN=".\TEST\1.wmv"
#FN=".\TEST\2018_0525_135958_020.MOV"
#FN=".\TEST\1.flv"
#FN=".\TEST\CrowdRun_2160p50.x264.CRF25.mkv"
#FN=".\TEST\DJI Inspire Drone Video Long GOP Jerkiness .MOV"
FN=".\TEST\elephants_dream_480p24.y4m"
#FN=".\TEST\1.mpg"
PREF="R" ] order of sourcefilters tried
Getseq(FN,Pref=Pref,fpsnum=33000,fpsden=1001,Debug=True)     # Test 33000/1001
which called
RawSoucePlus(FN,fpsnum=33000,fpsden=1001)
    Req:- RT_Stats, FFMS, LSmash. CallCmd, MediaInfo CLI v0.7.83+ (may work with later versions)
    Function GetSeq(String "vFn",String "aFn",String "Pref"="",Val "fpsNum",Val "fpsDen",bool "Debug"=False,Bool "Verbose"=False)
    Pref, Default "" {Same as "AIFLDR"). Order in which source filters are tried.
        "A" = AviSource() (Only if extension is *.AVI).
        "I" = LSmashVideoSource() (Only if extension is an ISO type file, ie mov, mp4, m4v, 3gp, 3g2, mj2, dvb, dcf, m21.).
        "F" = FFVideoSource().
        "L" = LWLibavVideoSource(), from LSMash.
        "D" = DSS2()
        "R" = RawSourcePlus().
    Specify FrameRate using fpsnum (Numerator) and fpsden (Denominator)    # *** INGNORED if AVI ***
        num only,  eg fpsnum=25.0,               FrameRate = 25.0  FPS
        num & den, eg fpsnum=24000 fpsden=1001,  FrameRate = 23.976 FPS (Both should be type Int).
        neither specified                        FrameRate = UnDefined, ie whatever source filter thinks it is.
        ALWAYS:- use named args if using fpsnum/fpsden, argument order may change.
    FFMS Cachefile (used for .ffindex file) directory can be set using global variable GLB_GETSEQ_FFMS_CACHE_DIR, NO trailing backslash.
        Global GLB_GETSEQ_FFMS_CACHE_DIR = RT_GetSystemEnv("TEMP")  # Set to the Current User's Temp directory.
    If Global variable GLB_GETSEQ_DEL_INDEX_ON_CLOSE is True, then will auto Delete both FFMS and LSMash indexes on clip closure.
        Global GLB_GETSEQ_DEL_INDEX_ON_CLOSE = True    # If true, Auto delete indexes on clip closure. # Could create stub which sets True/False depending upon your own arg.
The file itself is from one of the samples in the Avisynth Usage forum stickies (Consolidated list of test video clip resources).
EDIT: Under Avs v2.60 Standard with GScript. (thats why GScript flagged). [RawSourcePlus works fine under AVS+, where using GetSeq() without GScript]
EDIT: Its a bit big to post GetSeq.avsi and the required MIFO_LIB.avsi. (MediaInfo Library of script functions)
EDIT: Tests only done on Win7 not XP.
Old 31st July 2019, 15:56   #817  |  Link
Is this known issue that VC-1 decoding is totally broken with this plugin?
Old 1st August 2019, 07:29   #818  |  Link
Yes, a little while ago:
Originally Posted by Gser View Post
Yeah the newest L-smash does not work for VC-1 at all,at least not in avs+. Getting super corrupt frames with grey bits everywhere.
Old 2nd August 2019, 16:33   #819  |  Link
Doriandal
Why LSMASHVideoSource displays/decodes inmediatly on my PC while LSMASHAudioSource takes more time? If i load an only-video AVS it takes a split-second to load the player, but if i add LSMASHAudioSource it takes like 4 or 5 seconds to load.
I'm working with Apple ProRes, sound is PCM.
Not a big deal but i'm curious about that.
Doriandal is offline   Reply With Quote
Old 2nd August 2019, 16:41   #820  |  Link
poisondeathray
It's indexing the audio
LSmashVideoSource does not require indexing for ISO Base formats (MP4, MOV)
