1st February 2018, 22:17 | #2841 | Link | |
Can someone tell me that how can i merge two different videos into one? I want to use my intro but staxrip keeps giving errors.
Last edited by Malphie; 2nd February 2018 at 21:08. Reason: describing my problem |
3rd February 2018, 15:29 | #2842 | Link | ||
i'm not sure about audio. one file uses aac the other one flac(?). maybe that's your problem |
4th February 2018, 13:07 | #2843 | Link |
@Balthazar2k4
There was a bug forcing mod 16 instead of using the mod value defined in the options which has 8 as default.
4th February 2018, 21:43 | #2844 | Link |
Hello Stax, few tools that might need an update :
AVSMeter - 2.7.1 KNLMeansCL - 1.1.1 masktools2 - 2.2.13 MediaInfo - 17.2 VSFilterMod_x64 - r5 see : https://github.com/stax76/staxrip/issues/348 & https://forum.doom9.org/showthread.p...36#post1829836 FFmpeg 3.4.1 ( i had various issues one month or so ago with the one in Staxrip and some actions performed, getting a newer build resolved them, well no issues linked to ffmpeg since a while so... ) Plugins_JPSDR - 2.0.5 if i understood correctly it have now aWarpSharpMT so aWarpSharp2 might be removed, need confirmation. Not sure if all are needed or if there is incompatibilities when mixed, so far i had no problems but not mixing them much. Thank you. Edit : @ sausuke : You might be interested by this : https://github.com/satishsampath/fra...ment-362878180 Someone finally made Debugmode frameserver compatible with x64 ( win7 only for now ), no need of MP_Pipepline anymore for this now Last edited by Yanak; 4th February 2018 at 22:48. |
5th February 2018, 05:22 | #2845 | Link | |
5th February 2018, 11:15 | #2846 | Link |
Hello I need a new Laptop to run Stax, i currently use Nvenc to convert my Blu-ray collection to HEVC with stax, which do you think is the better combination of the 2 below?
Intel® Core™ i5-6300HQ processor with GTX 1060 Graphics or.. Intel® Core™ i7-7500U processor with GTX1050 Graphics. Any advise would be appreciated. |
6th February 2018, 07:19 | #2847 | Link |
So. Would like to first say thank you for the GUI and all your hard effort Stax, I've been a fan for a while now.
Recently I've been using a program by the name of Hybrid GUI for a bit easier time denoising video and line darkening (since the line darkeners are 32-bit). This is how I discovered an oddity and also a bit of an issue using SMDegrain in Stax (since Stax is more reliable in some ways and also has mClean to boot!). Using the following in Hybrid results in ~1.8 FPS in Hybrid using x265 custom very slow settings. Code:
SMDegrain(tr=12,thSAD=800,thSADC=400,contrasharp=true,interlaced=false,subpixel=3,prefilter=0,blksize=16,search=5,Truemotion=false,thSCD1=2400) So for now I'm running the script with contrasharp turned off and here's the other weirdness. Stax is not utilizing the cpu to its' full potential, the usage info in taskmanager for Hybrid shows ~75-98% usage. Stax shows a max of 88% and hovers in the 30s and 40s for the most part and the FPS shows this @ ~0.75-1 FPS. To be clear, I've updated all versions of the softwares used (x265 etc.) to the same versions where possible (due to Hybrid using 64-bit and 32-bit) and checked the settings dozens of times to be sure before I posted anything. Stax and Hybrid are within margin of error speed wise (to be expected with the same version of x265) with no filters enabled so... yeah just weird. So I don't know if the speed problem is Stax's fault but I thought I would at least let you know about the contrasharp issue and maybe you'd have some insight into the speed issue. Also, if I could I would like to request some deband options be included. Last edited by phazer11; 6th February 2018 at 07:37. |
7th February 2018, 09:10 | #2848 | Link | |
for quality you probably pefer cpu encoding, so i7-7500 would be your choice. in terms of gpu decoding/encoding i don't think there would be a significant difference between gtx 1060 and 1050. even my 1030 does a perfectly fine job at decoding 4k hevc 10bit streams |
7th February 2018, 14:27 | #2849 | Link | |
Nvidia quotes the 1060 as having twice as many coda cores as the 1050? |
7th February 2018, 19:04 | #2850 | Link |
ffmpeg supports AMD's VCE (over AMF), https://ffmpeg.zeranoe.com/forum/vie...?t=4231#p12946
Is it possible to use it in StaxRip (instead of VCEEnc)? |
8th February 2018, 04:41 | #2851 | Link | |
8th February 2018, 13:45 | #2852 | Link |
It's probably possible to write a script that renders subtitles separately on alpha and overlay it onto the 10 bit video in AviSynth+.
But: since StaxRip supports VapourSynth you might want to try that. Should be easier than AviSynth since it supported 10 bit from the beginning. |
8th February 2018, 18:17 | #2853 | Link | |
https://github.com/sorayuki/VSFilterMod/releases 29 days ago r5 … support YUV420P10 and YUV420P16 for vapoursynth. |
8th February 2018, 18:39 | #2854 | Link |
VapourSynth has another subtitle renderer integrated. (I don't know if StaxRip uses that or VSFilter(Mod) by default.)
http://www.vapoursynth.com/doc/plugins/subtext.html If you need updated build of VSFilterMod you can download it here: https://www.nmm-hd.org/newbbs/viewtopic.php?f=17&t=1989 |
8th February 2018, 20:33 | #2855 | Link | |
1) 10 bit pipeline by default (at least using ffms2 as a source filter) 2) Hardcoded subtitles now work *Bonus* I can hardcode SUP subtitles without converting to IDX |
8th February 2018, 21:35 | #2856 | Link |
Using latest straxrip 1.7 64bit
Video encoding second pass using x265 2.5+14 failed with exit code: 1073807364 (0x40010004) Happens with UHD 4k files on second pass. First pass on bitrate works fine. Cost me 30 hrs close to throwing this program out. Last test running bitrate and bitrate quality mode. If it fails then I'm uninstalling. |
8th February 2018, 21:47 | #2857 | Link |
Always post the log when reporting problems.
I would at least update StaxRip + x265 before I try again if the problem is reproducable. (And I'd test with shortened file, like 10 seconds. Not encode 30 hours just for testing.) https://github.com/stax76/staxrip/bl...r/changelog.md https://forum.doom9.org/showpost.php...postcount=5882 |
12th February 2018, 16:12 | #2858 | Link | |
It is mentioned in the 1.7.0.2 version:
Also is the "FrameRateControl" script the latest 1.2 version in 1.7.0.6? If I want to update scripts or encoders like x265, is it just enough to overwrite the versions in the folder? One thing Ive noticed is (compared to 1.7.0.0) that the 1.7.0.6 version (with overwritten x265.exe in the folder by the newest version 2.6-37) was actually encoding slower than 1.7.0.0 at exactly same settings. Also I had a freeze (app crash) at like 50-60% or so. Its something like 2.5 fps vs 1.5 fps speed difference. The only script I was using is QTGMC within Vapoursynth (exactly same QTGMC preset), so I cant really tell if the slowdown was caused by newer x265 version or newer QTGMC version, because I think 1.7.0.0 has older version than 1.7.0.6, but Im not sure if only Avisynth version of it or also VS version was updated as well.. I know 1.7.0.6 is a beta build still. So for now I went back to 1.7.0.0 and will do some more comparisons... Other than that its a great program, esp. since QTGMC seems to work pretty consistently out of the box. |
