31st March 2023, 14:43 | #20041 | Link | |
Friend of a friend..
And Trim video & audio tracks. |
31st March 2023, 16:23 | #20042 | Link |
You mean by adding fake frames?
1st April 2023, 09:24 | #20043 | Link |
Well, if that's what you want to call it!
But it would be a lot more useful than using AssumeFPS...I mean, who'd want to speed up their video & audio, expect for a novelty, like a "Chipmunk's" movie... It would just be nice to have a few more video & audio editing & encoding options. |
2nd April 2023, 04:43 | #20044 | Link |
Formally known as .......
Subtitle font size..
Would it be possible to add an option to change the size of the subtitle font, especially when Rendering them ("burning them in") ?
I found this old post on VideoHelp... https://forum.videohelp.com/threads/...synth-vsfilter) Code:
video=TextSub(video,"C:\Temp\RipBot264temp\job1\ca ptions-3.srt",-1) Last edited by TDS; 2nd April 2023 at 05:30. |
2nd April 2023, 07:20 | #20045 | Link |
2nd April 2023, 07:29 | #20047 | Link |
If I recall correctly font style and size was controlled by external file .style.
example Code:
[V4 Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding Style: Default,Tahoma,18,&Hffffff,&H00ffff,&H000000,&H000000,1,0,1,2,1,2,20,20,20,0,1 YourSubtitle.srt.style or YourSubtitle.style I do not remember now...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd April 2023 at 07:32. |
4th April 2023, 04:18 | #20049 | Link |
Hardcoded subtitle option:-
Atak,
I have been looking around at how to add hard coded subtitles (.srt, .ssa), and it was suggested to me to try "assrender" (an unfortunate name). It's very simple & basic, and I think you could easily integrate this into RB (but ONLY for rendered subs), there are lots of options, but the main options are font size & font style/type. More info here :- AssRender And a simple script:- Code:
LoadPlugin("%AVISYNTHPLUGINS%\assrender\assrender.dll") video=assrender(video, "subtitle path & name.srt", scale=0.8, srt_font="Sans") Last edited by TDS; 4th April 2023 at 10:26. |
5th April 2023, 15:53 | #20050 | Link | |
Font size
I simply edited the "default.style" file with notepad located in the ripbot program folder under "Tools" and then "srttossa", I changed the Fontsize from 18 if I remember correctly to 16 and now each new file what load in which I print the subtitles above, it gives them to me immediately with this default, I hope I have been of help. |
6th April 2023, 01:03 | #20051 | Link | |
OMG, that has been a LOT of help, thankyou. Even Atak had forgotten about this, I think, that VideoHelp link where he mentions how to edit that "default.style" was slightly off in its location, but there you have it. So now it's just a matter of what to change to get the desired result These are the default settings :- Code:
[V4 Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding Style: Default,Arial,20,16777215,65535,65535,-2147483640,0,0,1,2,1,2,10,10,10,0,1 EDIT:- I just had a play around with these settings, and as far as I could tell, it does not change anything...there must be some other subtitling going on somewhere else I even removed the srttossa & ssatosrt folders, and I still got subtitles in the preview, when set to render. Last edited by TDS; 6th April 2023 at 03:24. |
6th April 2023, 02:55 | #20052 | Link |
Hi Atak,
I have run into a strange issue... When using this call:- Code:
video=FrameRateConverter(video,NewNum=60000,NewDen=1000) However, in "single" mode, it works without issue. Any ideas ?? |
6th April 2023, 03:03 | #20053 | Link | |
Like once enabled, some drop down lists appeared, and you could change the font name, size & colour. EDIT:- This post is probably irrelevant, now Last edited by TDS; 6th April 2023 at 03:25. |
6th April 2023, 05:15 | #20054 | Link | |
I'm sorry it didn't work for you, I don't know if it's relevant but I use ripbot version 1.26.0, maybe there was some change to these settings with new versions. |
6th April 2023, 08:01 | #20055 | Link | |
I would very much doubt that the subtitle function has been changed in a long time, but maybe I could try 1.26.0 for myself. Thanks for the suggestion in the first place |
6th April 2023, 10:13 | #20056 | Link |
Let's say that for now I'm not interested in updating, I stayed with the 1080p resolution because the 4k format disappointed me especially for the choice of HDR which worsens the image for me, I did many tests, so for now the program is for me it works perfectly i have no DE problems, problems with resolutions and compression times and therefore i prefer not to mess with new problems, that's all so more for a personal choice.
7th April 2023, 05:01 | #20057 | Link |
DE just doesn't seem to like any kind of FPS increasing script..
I have now tried several FPS filters/scripts, whatever you want to call them, and DE just doesn't produce correct, usable chunks.
As per previous post. The ONLY call that seems to work is:- Code:
video=FrameRateConverter(video,FrameDouble=true) |
7th April 2023, 15:15 | #20058 | Link |
can you add NVEnc to ripbot264
https://github.com/rigaya/NVEnc/releases
i know x264 or x265 is best compression , and i only need Interlaced to progressive file ,ripbot264 is best qtgmc deinterlace is gpu denoise,and file to video ai upscale,so big file ,fast encode is need. |
7th April 2023, 15:23 | #20059 | Link | |
You will have to try another app, StaxRip, FastFlix, Hybrid, and maybe even Handbrake. |
8th April 2023, 04:02 | #20060 | Link |
Grumpy Old Man.
Extra SMDegrain scripts to try..
I was asked why there weren't certain scripts/filters included in the last "Lite" build, so I have made available, some extra scripts that you can try, and see if they are more suitable for you..
Note, these are already included in the full build. Simply click on the link in my signature...
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 8th April 2023 at 04:07. |
