25th January 2013, 23:52 | #14021 | Link |
Hi Nev,
thanks for your great work! Itīs the only freeware that plays broadcast AVC-Intra atm. There only seems to be a problem with the automatic field order detection. When field order is set to "auto" the motion in the video looks wrong. When I set it to "top field first" the video is fine. Iīve tested AVC-Intra clips from different sources, like Avid, Omneon, Quantel...all with the same result. MediaInfo reports all of them as top field first. Iīve uploaded a file for you, where the motion jitter is clearly visible: http://free-vsts.com/files/MXF/AVCI100_1080_sps.mxf Thanks for your help! |
26th January 2013, 01:31 | #14023 | Link |
Software Developer
nev:
Do you think you can support DVD Fast Forward with audio and pitch correction when decoding the audio? The "IDVDControl2" interface supports it through the "SetOption" function with the "DVD_AudioDuringFFwdRew" flag. I apply this flag in Zoom Player when the following setting is enabled: Adv. Options / Playback / DVD / DVD Values - Maintain audio during fast forward / rewind |
26th January 2013, 07:01 | #14024 | Link |
I could probably enable audio somehow, but not with pitch correction. Faster audio just sounds funny then.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th January 2013 at 08:43. |
26th January 2013, 07:28 | #14025 | Link | |
I'm not sure what is the better assumption, really. Not sure how one would figure this out from this stream, i find no indications of field order. But thats what the option is for, to override it on the occasional file which doesn't tell us this.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th January 2013 at 07:44. |
26th January 2013, 09:01 | #14026 | Link |
Nev,
if you haven't already done it and you have access to this parameter when select the field order you can use the framerate as a helper. If I'm not mistaken most PAL (50i) content ... except DV which I'm not sure is that popular nowadays .... is TFF. Most 60i contenet is BFF. I can't test the file right now to see if follows this rule because I'm on my tablet but I hope post could help.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
26th January 2013, 09:03 | #14027 | Link |
ffmpeg only has a flag called "top_field_first", which can be 0 or 1, it doesn't exactly tell me if it actually determined the file is BFF, or if thats just the value being unset =p
26th January 2013, 09:40 | #14030 | Link | |
26th January 2013, 10:01 | #14032 | Link |
Well, you may think that now, but when you play such a broken file that is BFF, you wouldn't notice that its broken, because it defaults to BFF.
26th January 2013, 10:36 | #14033 | Link |
As far as I know, bff was originated by the NTSC standard. All HD codecs and PAL SD codecs are tff. Exept DV25, DVCPro25 and DVCPro50, which are bff in PAL and NTSC.
So maybe you could let the fieldorder automatic check if the video is not dv, but 25fps or HD and then switch to tff? |
26th January 2013, 10:38 | #14034 | Link |
Didn't i already mention that it doesn't tell me if it detected a movie to be BFF, or just didn't detect anything at all? There is no distinction there.
Feel free to request this from the ffmpeg developers, i don't have the resources to fix every problem in ffmpeg myself.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th January 2013 at 10:47. |
26th January 2013, 16:55 | #14036 | Link |
nev, I cannot get Camtasia files to play with the LAV decoder. LAV Splitter seems to be doing everything correctly and detects it, but the LAV decoder doesnīt get invoked. The file has the (new) TechSmith Video Codec 2 (which comes with Camtasia Studio 8, older versions only support TechSmith Video Codec). My source (like the sample at the bottom) is an AVI export from the original .camrec file that Camtasia produces when recording.
Am I doing something wrong here? I have enabled .camtasia in the LAV decoder, still doesnīt work. I even tried to manually build a graph with GraphStudio, but the video output pin just wonīt connect to the LAV decoder input pin. Am I doing something wrong? If I play the file with the AVI Decompressor (quartz.dll) I get heavy image corruption, thatīs why I thought LAV would work, but strangely, it doesnīt. You can get a sample here: https://ffmpeg.org/trac/ffmpeg/ticket/1533 Thanks a lot for looking into it! Last edited by iSunrise; 26th January 2013 at 17:06. |
26th January 2013, 17:05 | #14037 | Link |
Whoever said it was supposed to work?
But it will work in the future.
27th January 2013, 12:22 | #14040 | Link |
Two question:
1. does Lav Video Decoder support HW deinterlace on AMD Radeon in future? Or only NV/cuda/QS? I interesting only in "copy-back" deinterlace for recoding and SmoothVideo Project 2. YADIF seem to be worst than linear blending. What can I do fo better deinterlace quality with LAV Video? Or may be LAV Video can make software linear deinterlace in newer version? yeah, it is not perfect, but better than nothing and chip for CPU. LAV + YADIF FFDSHOW + Linear blending Last edited by Rimsky; 27th January 2013 at 12:27. |
