Old 25th October 2019, 00:41   #3621  |  Link
ifb
Originally Posted by Myrsloik View Post
You've most likely hit the ram bandwidth limit. Run it with a single/few threads and the difference should be obvious.
core.num_threads = 1
R48 RC4   avx2  5975.40  1.0062
          sse2  5938.56  1.0125
R46       sse2  6012.63  1.0000
I only did 1 run each, but still ~1% faster.
ifb is offline   Reply With Quote
Old 25th October 2019, 00:41   #3622  |  Link
_Al_
@l00t
MATRIX =  {
                     0:'rgb',
                    1:'709',
PRIMARIES = { .....}
TRANSFER = {....}
try:
    lines.append(f'Matrix: {MATRIX[f.props["_Matrix"]]}')
except Exception as e:
    lines.append(f'Matrix: {str(e)}')
try:
    lines.append(f'Primaries: {PRIMARIES[f.props["_Primaries"]]}')
    lines.append(f'Primaries: {str(e)}')
_Al_ is offline   Reply With Quote
Old 25th October 2019, 08:13   #3623  |  Link
l00t
Where's my loot?
Thanks for the idea, modified the script accordingly
Originally Posted by _Al_ View Post
l00t is offline   Reply With Quote
Old 27th October 2019, 20:08   #3624  |  Link
MonoS
Since version R46 i get the error "Failed to initialize VapourSynth environment" even execuiting a simple vspipe -v
I've tried R46, R47 and R48-RC6, all giving me the same error, this on two different machine, one Win 10 the other Win Server 2019 even after reboot
Installing R45 it works without problem.
What could be the issue? what can i do to help you diagnose the problem?
MonoS is offline   Reply With Quote
Old 27th October 2019, 20:54   #3625  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Which install type? Did you really install the vs2019 runtimes? You can simply run vspipe in a debugger if you still can't figure it out since I've even included pdbs for the main dlls.
Old 28th October 2019, 09:02   #3626  |  Link
MonoS
64bit non portable version, installed vs2019 runtimes the first time, then in subsequent install skipped that.
For setting up the debugger what should i do? Download the source and put a breakpoint inside real_init and see what fail?
Old 28th October 2019, 11:13   #3627  |  Link
Myrsloik
Myrsloik's Avatar
Yes, that should work and give you the best information.
Old 28th October 2019, 16:52   #3628  |  Link
MonoS
Ok, i'll try to take a look, but it will probably take me about a week as i'm currently doing an encode.
Old 28th October 2019, 23:12   #3629  |  Link
Myrsloik
Myrsloik's Avatar
R48-RC6
Fixes premultiplied maskedmerge and a few expr problems that most likely were never encountered by anyone.
4 days without any bugs found! Final release when bug free for a whole week. Keep testing!
Old 29th October 2019, 19:22   #3630  |  Link
Patman
Patman's Avatar
R48 final based on python 3.7.x module? Which version of Vapoursynth will be based on python 3.8?
Gesendet von meinem HMA-L09 mit Tapatalk
Tools for StaxRip | x264 - x265
Patman is offline   Reply With Quote
Old 29th October 2019, 19:38   #3631  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by Patman View Post
Yes, it will use python 3.7.x. I'll switch to 3.8.x when cython adds official support for it.
Old 29th October 2019, 19:41   #3632  |  Link
Patman
Patman's Avatar
Thanks for the info.
Old 31st October 2019, 23:07   #3633  |  Link
Myrsloik
Myrsloik's Avatar
R48 is released!
Old 3rd November 2019, 15:52   #3634  |  Link
stax76
stax76's Avatar
Is there a particular reason why vsrepo downloaded files don't have original timestamps?
staxrip has packages with lost timestamps and I would like to recover them.
Old 3rd November 2019, 17:43   #3635  |  Link
Myrsloik
Myrsloik's Avatar
Because the way I'm handling things it's kinda annoying to set them. And it's not like you can ever trust them anyway...
Old 9th November 2019, 08:25   #3636  |  Link
hydra3333
just checking,
does that mean the v48 portable version
will run under portable python 3.7.5 ?
but not 3.8.0 ?
hydra3333 is offline   Reply With Quote
Old 9th November 2019, 09:09   #3637  |  Link
l00t
Where's my loot?
Originally Posted by hydra3333 View Post
just checking,
but not 3.8.0 ?
exactly
Old 20th November 2019, 15:58   #3638  |  Link
Jukus
What needs to be done to make a video have different FPS?
For example, I want to do something like that
from vapoursynth import core
import havsfunc as haf
clip = core.d2v.Source('index.d2v')
clip1 = core.std.Trim(clip, 0, 5579)
clip1 = haf.QTGMC(clip1, Preset='Very Slow', Sharpness=0.5, FPSDivisor=1, SourceMatch=3, Lossless=2, MatchEnhance=0.75, TFF=True)
clip2 = core.std.Trim(clip, 5580, 24186)
clip2 = haf.QTGMC(clip2, Preset='Very Slow', Sharpness=0.5, SourceMatch=3, MatchEnhance=0.75, InputType=1)
clip = clip1+clip2
clip.set_output()
but this code will not work correctly.
Jukus is offline   Reply With Quote
Old 20th November 2019, 17:12   #3639  |  Link
poisondeathray
clip = clip1+clip2
clip.set_output()
Internally in vapoursynth, it has to be CFR (constant frame rate)
1) You can duplicate frames and framerate in the second section (but same content speed). eg. by using core.std.Interleave
Or ,
2) you can temporarily assign a 2xFPS to the 2nd section using core.std.AssumeFPS to append sections (so it plays double speed), then use external timecodes (timestamps) method to make it VFR
Old 20th November 2019, 18:57   #3640  |  Link
DJATOM
DJATOM's Avatar
No. You can splice mixed fps clips, or even mixed resolution clips, vapoursynth can handle that. But encoding app might fail to understand such clip, that depends on what you're using.
I made x264 input filter and successfully provided vapoursynth timecodes (but code is a bit dirty), you can pick it here and compile: https://pastebin.com/QhjQ26qG
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
speed, vaporware, vapoursynth
