Old 20th July 2017, 12:11   #2341  |  Link
sneaker_ger
The wiki says the color format is available. Not a function of the same name.
Try:
ConvertBits(10) #if source depth != 10
ConvertToYUV422()
or maybe
ConvertBits(16) #if source depth != 16
ConvertToYUV422()
ConvertBits(10)
Not really sure what's better.
Old 20th July 2017, 12:26   #2342  |  Link
Magik Mark
Thanks will give it a try
Old 20th July 2017, 12:53   #2343  |  Link
Magik Mark
Tried:
ConvertToYV16(matrix="Rec709")
ConvertBits(10)
Video Greenish. Source is 4:2:0 8bit. what did I miss?
Old 20th July 2017, 13:18   #2344  |  Link
sneaker_ger
Log? Screenshot? In which software is it displayed green? The script or the encoded file?
Old 21st July 2017, 11:35   #2345  |  Link
Natty
Noob
source and encoded file?
Natty is offline   Reply With Quote
Old 22nd July 2017, 11:08   #2346  |  Link
Patman
Patman's Avatar
Hi Stax,
1.5.3.4 unstable test build
fix: the main window stayed in the background instead of being activated to be top most
Problem still exists. When loading first file everything is ok, but when loading second file, window still stayed in background. Please check.
Patman is offline   Reply With Quote
Old 22nd July 2017, 11:44   #2347  |  Link
stax76
stax76's Avatar
Hi Patman, I'll check it.
Old 22nd July 2017, 13:05   #2348  |  Link
stax76
stax76's Avatar
Patman, I've tried a couple of things but so far I'm not able to reproduce it.
Old 22nd July 2017, 21:06   #2349  |  Link
drizzit
First of all thank you for the program!
Still really new to this program so I might be doing something wrong but I'm having trouble with warnings about 260 character limit.
No matter what I set the temp files folder as the initial check when I try to open a source file seem to assume the original file location as the temp files location and if that path is too long I get an error.
Example:
File located at d:/temp movies/test.series.season 01/file.mkv
Temp path set as d:/temp/%source_name%_temp\
When initially opening the file (please assume my path above is long enough to trigger the 260 char warning for the sake of the example) I get an error saying the temp path might be too long and it gives me the original path as such
d:/temp movies/test.series.season 01/test.series.season 01_temp/file.mkv
However if I shorten the path to the original file so I manage to open the file without triggering the above error as soon as the file is opened the temp path is now handled correctly as set in the settings.
My expectations would be that the set path is used for the inital check too but this doesnt seem to be the case unless I'm missing something?
Edited to add I'm using latest test build 1.5.3.4
drizzit is offline   Reply With Quote
Old 23rd July 2017, 10:07   #2350  |  Link
Schattenspieler
Well, drizzit, the problem is probably -> obviously not the path to the temp-folder, but to the source. If either one is longer that 260 chars, you get an error. Or did I misunderstand you?
Schattenspieler is offline   Reply With Quote
Old 23rd July 2017, 11:23   #2351  |  Link
stax76
stax76's Avatar
@drizzit
There is a open issue on the tracker, I'll examine it after the upcoming release.
Old 23rd July 2017, 12:14   #2352  |  Link
Zetti
MKVToolNix v14.0.0 is released.
Old 23rd July 2017, 13:58   #2353  |  Link
drizzit
@drizzit
Ah I missed that
Sorry about the duplicate and thank you very much for the answer. Good to get confirmation its not me doing something wrong.
I'm a recent convert but I'm really loving your work, please keep it up!
@Schattenspieler The source path is long but not too long. The problem is that IF I would use the source path as temp directory it would be too long and the error check ignores the manually set temp files folder that would make the path short enough to not trigger the error. Hope that made more sense?
Old 23rd July 2017, 15:11   #2354  |  Link
Schattenspieler
Aye, now I got it, drizzit! ^^
@stax76: Importing of command line options seems to work so far, but the CRF value is not changed. No big deal for now, since one can change it easily. Didn't have time to check it further, though, yet.
Old 25th July 2017, 21:14   #2355  |  Link
stax76
stax76's Avatar
The stable release is available now. Things will be slower or even paused but I will be back!
https://github.com/stax76/staxrip/releases/tag/1.6
Old 25th July 2017, 21:22   #2356  |  Link
NikosD
You were throwing new releases like a machine gun!
Latest nightly I tried it was a very impressive work especially in the working progress window of the various stages of the transcoding pipeline.
I'll probably try tomorrow the new stable release.
Thank you for the new version.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 26th July 2017, 00:49   #2357  |  Link
drizzit
for the update!
Old 26th July 2017, 09:45   #2358  |  Link
Vulpix
I am so happy that you didn't leave us, @stax76 ! StaxRip is the best encoding tool for people who aren't afraid to go a little deeper!
Vulpix is offline   Reply With Quote
Old 26th July 2017, 13:43   #2359  |  Link
craigpro
thank you so much stax76!
craigpro is offline   Reply With Quote
Old 27th July 2017, 09:47   #2360  |  Link
burfadel
Here's a new one for you:
ManagementException
Call cancelled
System.Management.ManagementException: Call cancelled
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
at System.Linq.Enumerable.<OfTypeIterator>d__93`1.MoveNext()
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.String.Join(String separator, IEnumerable`1 values)
at StaxRip.LogBuilder.WriteEnvironment() in D:\Projekte\VS\VB\StaxRip\General\LogBuilder.vb:line 72
at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isNotEncoding) in D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 1906
I was running two encodes at a time, the message therefore showed twice.
