18th September 2017, 23:34 | #4661 | Link |
you really don't get it right?
last comment on this topic here. AMD and intel have the same problem the number only looks better but again it is just a number... there are 3 clocks working here and they don't match on AMD on nvidia and even on intel. getting them match is pure luck no matter what. that why you usually need to recreate for all 3 GPU vendors a custom resolution because they can't match all clocks an planet earth. they are not accurate enough and they never will be and there are multiply way to get audio out of a PC system all have different clocks. but feel free to demand some atom clock like precision. |
19th September 2017, 00:02 | #4662 | Link |
Possible bug in ffmpeg decoder.
19th September 2017, 03:23 | #4664 | Link |
19th September 2017, 08:32 | #4665 | Link | |
However, because of an issue I have with MPC-HC I noticed for the first time that in BE's taskbar there is always the GPU symbol/icon present although hardware decoding is active. Is this wanted this way ? In PotPlayer one can even switch between H/W and S/W clicking on it. |
19th September 2017, 08:48 | #4666 | Link |
In MPC-BE it's just the indicator.
19th September 2017, 17:04 | #4667 | Link |
EVR Custom (DXVA2)
http://leakimg.com/uWqkNGY/image.png EVR Sync (GothSync) (DXVA2) ? http://leakimg.com/DHY647p/image.png
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
20th September 2017, 16:56 | #4668 | Link |
@huhn: thanks for helping me per pm with madvr and custom resolution
@devs: Is it just me or is yadi download folder experiencing some problems, like only x86 build in todays "latest" folder and latest folder with numbers complete empty? I saw similar things already some days ago. Last edited by Klaus1189; 20th September 2017 at 17:01. |
21st September 2017, 06:25 | #4670 | Link |
Waiting new certificate
21st September 2017, 06:26 | #4671 | Link | |
21st September 2017, 13:20 | #4672 | Link |
Well, now that I am aware of it, it really bothers me. Maybe you can put it on your to-do list to at least let it switch between H/W and S/W ??
On a side note. Just checked latest build and the problem I had with the recent Arrow-US release of 'Bird with the crystal plumage' is now gone. Don't know if you fixed it or the latest Realtek audio driver. Or both .... but thanks anyway for looking into it !!! Last edited by Grimsdyke; 21st September 2017 at 13:21. Reason: typo |
21st September 2017, 18:55 | #4673 | Link |
There is no practical sense in this. It's just a toy.
23rd September 2017, 20:54 | #4674 | Link |
Well, this may be true for developers and/or power users here who can identify and fix a (configuration ?) problem in seconds.
I am none of that so if BE would have 'warned' me that hardware decoding is inactive on a certain blu-ray that would have saved me some time and headaches. |
24th September 2017, 11:07 | #4675 | Link | |
24th September 2017, 14:14 | #4676 | Link | |
MPC-HC immediately indicated [S/W] on this Blu-Ray !! So was PotPlayer but there it is also possible to switch between S/W and H/W and after switching the Blu-Ray played perfectly. For me that is very helpful and not a toy. |
24th September 2017, 14:18 | #4677 | Link |
Did you already figured out what caused this specific Blu ray to display GPU altough it wasn't using hardware acceleration? Did you use internal filters or external ones? What Codec is used for this specific Blu-ray: H.264, MPEG-2 or VC-1?
For me MPC-BE only shows GPU if hardware acceleration is indeed used. Last edited by Klaus1189; 24th September 2017 at 14:20. |
25th September 2017, 20:36 | #4678 | Link |
Hi
I use mpc-be with my configuration (signature) on a 1920*1080 full hd monitor. I tried with ISR, VSFilter and XYSubFilter but i can't see subs in the black bars when i see a movie. I use madvr and in the zoom settings i've selected to move subs to the bottom. You know why? Thanks
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
26th September 2017, 07:17 | #4679 | Link | |
27th September 2017, 17:34 | #4680 | Link |
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 27th September 2017 at 18:00. |
