4th October 2018, 06:12 | #52961 | Link |
https://forum.doom9.org/showpost.php...16&postcount=2
feel free to send him one and don't forget the API. and there a not many screens that work with 24 hz or lower even through for video rendering there is an easy workaround. |
4th October 2018, 06:27 | #52962 | Link |
I see some comments saying we should choose 10 bit RGB instead of 12 (although it's not yet an option for nvidia users) because 12 could introduce banding aftee dithering, may I ask is that the case for Tv that supports 12 bits colors too? It says on the properties page in madvr that my TV can handle 12 bits, so will I get banding problem if I'm using 12 bit RGB full range or should I switch to 10 bits when it's an available option?
Sent from my SM-G9350 using Tapatalk |
4th October 2018, 06:40 | #52963 | Link |
every none entry TV supports 12 bit input.
nvidia does not provide 10 bit for RGB when using HDMI because "reasons". if your screen can't deal with 12 bit properly you may end up with banding but it's only the fault of your TV. madVR doesn't change it's dithering based on that option. i don't see a reason to send 12 bit if 10 bit is available but in the end it all depends on the quirks of your screen. |
4th October 2018, 06:51 | #52964 | Link | |
Sent from my moto g(6) using Tapatalk |
4th October 2018, 08:42 | #52966 | Link |
@madshi
I don't want to turn this thread into nvidia topic but I would appreciate if you or someone else could clarify one thing for me. I'm using madVR custom resolutions and I've been told a while ago that the last driver that supports that is 390.65 but since then there are a lot of new releases. Since you have your nvidia contact I assume this was discussed as well at some point. Can you advise what's the last version that works with madVR custom resolutions? Currently I'm able to get '1 frame drop every 2 days' or even 'no frame drops/repeats expected' so I would hate to lose it by updating and not knowing if I still will be able to set this up. I realize some drivers can introduce other problems so if someone can advise which one has the least amount of them + supports madVR custom resolutions that would be very helpful. |
4th October 2018, 09:47 | #52967 | Link |
@creativeopinion
You will not get the answer you want. Not because there are no answers out there, it all is very subjective. For example, if you do not have any issues, and you do not have any frame drops, why would you want to change ? I am guilty of this as well as I feel as though I am missing out, but the reality is, this computer is just for HTPC and browsing, so always roll back to 399.xx. Some people have working custom resolutions with later drivers, but other things break, or don't. The simplest reply is it all depends what you want to do, what graphics card you have, rev of Windows, but if it is working for what you want it to do, my advice would be leave it as is. |
4th October 2018, 10:41 | #52969 | Link |
I'd like to thank Madshi for the new option (finally) in calibration section to report BT.2020 to display (good for 4K non/HDR content and displays that are not HDR but support BT.2020) and it works.
The only gripe would be that one cannot apply the change if you check/uncheck only the option. If you select BT.709 you must also uncheck "report BT.2020" at the same time or you won't be able to do it if you only change to BT.709 and forget to change "report BT.2020". It's just a hassle, not a deadlock. |
4th October 2018, 12:17 | #52970 | Link |
RTX 2160 ti no frame packed 3D
Just recieved my new RTX 2010 ti card and has suddenly no frame packed 3d in madvr only side by side. Thought it might have something to do with the new Windows 10 build 1809, so I reverted back to my old Windows 8.1, but it's exactly the same, what the f**k are going on???
Nvidia driver version are 411.70 Anyone else??? |
4th October 2018, 12:25 | #52971 | Link |
The 411.xx drivers have some issues. I guess you can't use older drivers on the new RTX cards, so you might just have to wait for a fix from Nvidia.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
4th October 2018, 12:28 | #52972 | Link |
BRAZEN1 is the Nvidia 3D expert on here, he should be able to help if he's about.
4th October 2018, 13:46 | #52973 | Link |
Nvidia has just released new Driver 416.16 WHQL with fixes for recent Win 10 1809 build. http://us.download.nvidia.com/Window...ease-notes.pdf
Win 10 x64 LTSC 1809, 16 GB RAM, Nvidia GTX1080, AMD FX-8350 |
4th October 2018, 14:02 | #52974 | Link | |
Was just wondering what works in win7 now as I have an old machine I might put in my bedroom which I didnt upgrade to win 10 when I should have.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions Last edited by mclingo; 4th October 2018 at 14:16. |
4th October 2018, 14:23 | #52975 | Link | |
Where do you think this conversation will go, what works on Windows 7 ? |
4th October 2018, 14:37 | #52976 | Link |
fair play, yes i'm trying to get this kind of thing over to the other thread but also mend some bridges around here, at last for those who are willing to meet half way.
I meant what works in MADVR for windows 7, dont think this is an unreasonable question and I gave a reason for asking it. I would have asked it on the general thread if he'd gone there with that information.
4th October 2018, 14:43 | #52977 | Link | |
4th October 2018, 16:02 | #52978 | Link | |
4th October 2018, 16:04 | #52979 | Link | |
4th October 2018, 16:11 | #52980 | Link | |
Then, my friend has advised me that someone on this forum confirmed that nvidia did 'something' and that the last one that works with madVR CR is 390.65. I've installed it on the same day and I was able to find the correct pixel clock after like 2 mins without any problems. I just tested few different ones to get the best results and currently this vary from few hours/days to even no frame drops/repeats expected. Now If i would aim to update my drivers I would like to make sure this can still be something I could set up. If I can benefit from newest drivers when it comes to HDR and other things I would like to. |
