17th August 2014, 13:57 | #1201 | Link | |
EDIT : also, psy-rd/psy-rdoq are not written to the SEI: x265 --rd 4 --psy-rd 1.0 --psy-rdoq 1.0 park_joy_1080p50.y4m -o park_joy.hevc Code:
x265 (build 31) - 1.2+555-866f21378d94:[Windows][MSVC 1800][32 bit] 8bpp - H.265/HEVC codec - Copyright 2013-2014 (c) Multicoreware Inc - http://x265.org - options: 1920x1080 fps=50/1 bitdepth=8 wpp ctu=64 tu-intra-depth=1 tu-inter-depth=1 me=1 subme=2 merange=57 no-rect no-amp max-merge=2 no-early-skip no-fast-cbf rdpenalty=0 no-tskip no-tskip-fast strong-intra-smoothing no-lossless no-cu-lossless no-constrained-intra no-fast-intra open-gop interlace=0 keyint=250 min-keyint=25 scenecut=40 rc-lookahead=20 bframes=4 bframe-bias=0 b-adapt=2 ref=3 weightp no-weightb aq-mode=2 aq-strength=1.00 cbqpoffs=0 crqpoffs=0 rd=4 signhide lft sao sao-lcu-bounds=0 sao-lcu-opt=1 b-pyramid cutree rc=crf crf=28.0 qcomp=0.60 qpmin=0 qpmax=51 qpstep=4 ipratio=1.40 pbratio=1.30 Last edited by a5180007; 17th August 2014 at 15:36. |
18th August 2014, 10:06 | #1203 | Link |
Because it is "stable" now, x265 1.2+557-87400d5c90aa.
18th August 2014, 23:22 | #1204 | Link |
Derek Prestegard IRL
I'm using the build that LigH just posted above ^^ 1.2+557-87400d5c90aa - the 8 bit variety on x64.
I thought I'd do some PSNR and speed tests just for fun, and got some odd behavior. See how it's warning be about setting --tune psnr even though I already have it set? Code:
G:\>x265.exe --input parkjoy.y4m --preset medium --tune psnr --psnr --bitrate 80 00 --vbv-maxrate 8000 --vbv-bufsize 8000 --output parkjoy_x265_8000_medium.h265 y4m [info]: 1920x1080 fps 50/1 i420p8 sar 1:1 frames 0 - 207 of 208 x265 [info]: HEVC encoder version 1.2+557-87400d5c90aa x265 [info]: build info [Windows][GCC 4.8.2][64 bit] 8bpp x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: WPP streams / pool / frames : 17 / 8 / 3 x265 [warning]: --psnr used with AQ on: results will be invalid! x265 [warning]: --tune psnr should be used if attempting to benchmark psnr! x265 [info]: Main profile, Level-4.1 (Main tier) x265 [info]: CU size : 64 x265 [info]: Max RQT depth inter / intra : 1 / 1 x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut : 25 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb / refs: 1 / 1 / 0 / 3 x265 [info]: Rate Control / AQ-Strength / CUTree : ABR-8000 kbps / 0.0 / 1 x265 [info]: VBV/HRD buffer / max-rate / init : 8000 / 8000 / 0.900 x265 [info]: tools: rd=3 lft sao-lcu signhide x265 [info]: frame I: 1, Avg QP:36.74 kb/s: 32723.60 PSNR Mean: Y:32.379 U:35.246 V:37.691 x265 [info]: frame P: 52, Avg QP:36.80 kb/s: 26042.37 PSNR Mean: Y:28.665 U:31.432 V:35.047 x265 [info]: frame B: 155, Avg QP:41.61 kb/s: 2187.03 PSNR Mean: Y:27.569 U:31.301 V:35.014 x265 [info]: global : 208, Avg QP:40.39 kb/s: 8297.68 PSNR Mean: Y:27.866 U:31.353 V:35.035 x265 [info]: Weighted P-Frames: Y:1.9% UV:1.9% x265 [info]: consecutive B-frames: 1.9% 0.0% 1.9% 96.2% 0.0% encoded 208 frames in 26.58s (7.82 fps), 8297.68 kb/s, Global PSNR: 29.198
These are all my personal statements, not those of my employer :) Last edited by Blue_MiSfit; 18th August 2014 at 23:24. |
19th August 2014, 03:13 | #1205 | Link | |
Should be fixed with this patch... https://bitbucket.org/multicoreware/...34de996742d5e8 Last edited by x265_Project; 19th August 2014 at 03:58. Reason: Status update |
20th August 2014, 11:50 | #1207 | Link |
Because many stable and much fixes, wow - x265 1.2+575-80129b1b6260
21st August 2014, 20:55 | #1208 | Link | |
21st August 2014, 21:04 | #1209 | Link |
And a couple of other questions about settings and presets
22nd August 2014, 04:34 | #1212 | Link | |
http://builds.x265.eu/ |
22nd August 2014, 04:44 | #1213 | Link | |
SuperVirus
Version 1.2.581 (8bpp, both 32-bits and 64-bits) @ http://forum.videohelp.com/threads/3...79#post2341579 |
22nd August 2014, 07:02 | #1214 | Link |
I'm going to build it, but the stable merge (1.3+2-2e17cb106b17) seems to have a lot of warnings regarding signed/unsigned comparisons etc., will probably prefer the latest development revision for publishing.
__ x26+1.3+18-bad70432b1d3 Last edited by LigH; 22nd August 2014 at 07:56. |
22nd August 2014, 07:22 | #1215 | Link |
We are pleased to announce that we have reached version 1.3.
The primary changes in this release are the completion and tuning of the psycho-visual optimizations and new support for multiple pass encoding. --psy-rd and --psy-rdoq are now completed and scaled such that their recommended initial values are 1.0. Multipass encodes are now possible with --pass N and --stats FNAME As usual, full documentation is at: http://x265.readthedocs.org/en/1.3/ = API Changes = * param.bEmitInfoSEI, --[no-]info include an SEI identifying the encoder and encoding options. * param.bHighTier --high-tier specify tier (used in conjunction with --level-idc) * param.bEnableFastIntra --[no-]fast-intra Use a gradient descent to scan angular intra modes * param.totalFrames optional indicator of total frame count, may improve rate control * param.scalingLists specify custom quantization matrices, "default" or filename * param.psyRdoq Psycho-visual optimizations for quantization * param.bEnableSlowFirstPass The first pass of multi-pass encodes will run in *turbo* mode unless this option is enabled. |
22nd August 2014, 16:16 | #1216 | Link |
Nice improvements with this version !
Although the 2-pass is not a "pure CRF" yet. And there is a fair difference in first frames and I-frames sizes and ssim : File http://www.diktafon.atw.hu/112.MTS x265 1.3+18 crf28 (48,756 KB) vs --bitrate 6764 --pass 2 (48,738 KB) Last edited by a5180007; 22nd August 2014 at 17:49. Reason: added ssim curve |
22nd August 2014, 18:22 | #1218 | Link |
These algorithms are in the same class... the code is in place, but we haven't spent much time on these functions as we had bigger fish to fry (RDOQ and psy-rdoq, etc.). We'll be turning our attention to these functions, but until we have had a chance to really evaluate how they are working in conjunction with the other changes we recently implemented, we can't recommend using them.
23rd August 2014, 11:46 | #1219 | Link |
Is there somewhere documented which parts of the code (functions ?) are optimised for AVX2 and which is the speed-up of these specific optimisations ?
Are there any functions using floating point numbers ? Thanks!
24th August 2014, 02:34 | #1220 | Link | |
pixel_avg frame_init_lowres_core mbtree_propagate_cost cvt32to16_shl cvt16to32_cnt pixel_satd pixel_var pixel_sad pixel_ssd You can turn off AVX2 or any other specific assembly code optimization using --asm to test the performance difference. |
