27th June 2013, 15:23 | #12361 | Link | |
Now I can remux my movies much faster... |
1st July 2013, 21:43 | #12362 | Link | |
NY Frame of Mind
What is the video frame duration @23.976 fps? Next question. I extracted a Dolby THD track to wavs, where the track has a video delay of -32ms. The log shows (note lines 2 and 7): Code:
[a03] Extracting audio track number 3... [a03] This track begins with a non-major frame. <WARNING> [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with DirectShow (Nero Audio Decoder 2)... [a03] DirectShow reports 5.1 channels, 24 bits, 48kHz [a03] Applying RAW/PCM delay... [a03] Writing WAVs... So, does the "applying RAW/PCM delay..." mean that I don't have to apply any delay when muxing the DTS track back with the video?
"Talk to me Goose" |
1st July 2013, 21:56 | #12363 | Link | |
1000 ms / 23.976 = 41.7 ms
1st July 2013, 22:18 | #12364 | Link |
NY Frame of Mind
@tebasuna51
As always, thank you for the quick and knowledgeable response. I'm always a bit confused by audio/video delays. Also, this is the first time I've seen "This track begins with a non-major frame. <WARNING>"
2nd July 2013, 08:43 | #12365 | Link | |
I don't know TrueHD specs.
2nd July 2013, 20:41 | #12366 | Link |
NY Frame of Mind
A TrueHD stream is composed of Major sync frames and non-major frames. Apparently tracks are supposed to start with a major frame.
This may have accounted for the -32ms delay and the warning.
3rd July 2013, 21:10 | #12367 | Link |
Love how useful this tool is. I have 2 feature requests:
1) A SoundTouch type Tempo adjustment. The ability to speed up and a slow down a track without any change to the pitch is sometimes preferable. 2) Dolby Pro Logic II/IIx/IIz Upmix. I often want to expand the number of tracks on a stereo source to 5.1 or 6.1. Manually doing this is labor intensive and requires multiple programs and in between conversions. Be nice to just: Eac3to StereoTrack.wav SurroundTrack.ac3 -upDpl6 |
3rd July 2013, 21:39 | #12368 | Link | |
SuperVirus
then possibly he'll do that for you Last edited by filler56789; 3rd July 2013 at 21:44. Reason: typo |
3rd July 2013, 22:01 | #12369 | Link |
Hi
Any news about fix for left view / right view with MVC flag ? This case is open in Mantis : http://bugs.madshi.net/view.php?id=86 Thanks ! |
5th July 2013, 06:08 | #12371 | Link | |
French Love
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
5th July 2013, 06:17 | #12372 | Link | |
French Love
Small tool for detect AVC/MVC <=> MVC/AVC order
10th July 2013, 21:19 | #12373 | Link |
EDIT - Careful searching found that for any 6.1 format the remap must be done to accomplish -double7 processing correctly.
Hey everyone, I have a 6.1 channel .w64 file with L C R LFE BC SL SR channel mapping, and I need to upmix to a 7.1 .w64 file for proper muxing with TSMuxer (TSM does not like 6.1, and converts it to 7.0, putting my LFE channel in one of my rear surrounds). Can I simply use the -double7 feature, or do I need to remap channels as I have found when searching for how to use the '-double7' feature? I was wanting to just use: eac3to input.w64 output.w64 -double7 Will this work? Thanks in advance, JSS Last edited by maxmercy; 10th July 2013 at 21:47. |
12th July 2013, 15:52 | #12376 | Link |
Anime addict
Would be possible implement option for output wav on 32 bit float??
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
14th July 2013, 17:00 | #12377 | Link |
Could we please get a replacement of the FLAC encoder with the one in ffmpeg 2.0 with "-compression_level 12" ?
It now properly supports 24bit. I have tested up to 24bit 7.1 channel FLAC and it plays fine on all the players I have tried (XBMC, MPC-HC, etc...). "-compression_level 12" allows to shave off another 100 to 200Mb on my MKV backups. It's a little cumbersome to compress to FLAC with eac3to and then to recompress it again to FLAC with compression level 12 with ffmpeg. It would be nice if we could do it in one go. Thanks. |
14th July 2013, 17:53 | #12379 | Link |
I am using the HD-DVD/Blu-Ray Stream Extractor (the MeGUI version as it allows to queue tasks - this way I can set up 20 or more MKV to FLAC taks in the queue and have it run in one go), so I don't think it's possible to setup piping with the gui.
Thanks for the feedback. |
14th July 2013, 19:31 | #12380 | Link |
Pig on the wing
I tested simple piping to ffmpeg and it doesn't seem to work properly :/ The resulting file is only a part of the source, maybe it's due to some filesize restrictions. I couldn't find a way to force ffmpeg to ignore any audio length. The documentation of that application is just not very clear (I've ran into that many times in the past), but some googling told me that ffmpeg should support large files without a problem. There is something funny there anyway, I also tried decoding to wav and then using ffmpeg on the result but it didn't help either.
eac3to |
