3rd August 2017, 16:30 | #4842 | Link |
MKVToolNix author
Most likely not. First of all, the new GUI's track selection works quite a bit differently than the old GUI's: you can select multiple tracks, operate on all of them at once, and the new GUI has good support for keyboard navigation and selection. Focusing another element breaks all of those interactions in a bad way.
Second, focusing does not necessarily cause the panel to scroll back up so that the input is visible. If it isn't visible, then that's bad because the user doesn't realize that input is now focused, and she cannot see what she's typing. However, if I change this to scroll up automatically, then it'll annoy all users that have legtimiate business in the lower parts of the track properties panel because now they have to scroll down again. Third, if you want to jump to the track name quickly just hit Alt+k (that's the keyboard shortcut for that input field if the GUI's language is English). You're putting your fingers on the keyboard anyway, so why not use that? Getting such functionality right with the new GUI would be very tricky and therefore prone to annoying the users until I've gotten it right. I wouldn't rule it out completely, but it's a strong "not likely".
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
6th August 2017, 14:27 | #4844 | Link |
I have a concert bluray, which is 1080i 29.97fps. I have re-encoded it to 720p 59.94fps - however using latest mkvtoolnix, muxing the 264 stream and the audio and then checking the file with Mediainfo, it shows a frame rate of 60fps, with an 'original' frame rate of 59.94fps. Even when I specify 6000/1001p in mkvtoolnix, the fps gets changed to 60fps. Any tips? |
6th August 2017, 14:45 | #4845 | Link |
Is the file in-sync to the end (and long enough for the difference between 60.0 fps and 59.94 fps to result in perceivable desync)? Then everything is fine and it's probably just MediaInfo misdetecting the fps. Timecodes in mkv have limited accuracy and it is not trivial to detect "correct" fps in every case - especially if only looking at the start of a file instead of parsing it completely.
If not: upload a sample and show mkvmerge command and log. |
19th August 2017, 09:20 | #4848 | Link | |
MKVToolNix author
MKVToolNix v15.0.0 released
Here's the brand new version 15.0.0 of MKVToolNix. A lot of work has gone into improving support for new track header elements important for video archival purposes. A couple of bugs have been fixed, too, as usual.
Changes for package maintainers: libEBML v1.3.5 is now required. An option has been added to 'configure' for compiling without the code that checks online for new releases. See below for details. Deprecation warning This is a reminder that certain features having been deprecated since v9.7.0. They're scheduled to be removed in the first release of 2018. These features are:
Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG and the source code. The Windows and macOS binaries have already been built and uploaded. Linux binaries are still being built and will be available shortly. Here are the NEWS since the previous release: Quote:
19th August 2017, 21:12 | #4849 | Link |
Thanks for the new version...
For hello_hello and all other Win XP users: The workaround from this post: https://forum.doom9.org/showthread.p...31#post1813131 still worlks. Cheers manolito |
20th August 2017, 17:33 | #4850 | Link |
Matroska find' ich toll
Hi Mosu
I set the TrackDefaultFlag to true for an audio track(the first track), and a second audio track these Flag is set to false. After the muxing I load the mkv to the Header-Editor and there is no TrackDefaultFlag Element present. Same in mkvInfo-GUI. I tried version 14 and 15 of MKVToolNix x64 with the GUI and CLI with the Options.json file. |
20th August 2017, 17:39 | #4851 | Link |
MKVToolNix author
Read this fine FAQ entry. The summary is: TrackFlagDefault's default value (= the value a player must use if the element is not present) is "true". As you're setting that flag to "true", mkvmerge does not have to write it and doesn't do so, because its absence means implicitly that it is "true".
7th September 2017, 19:11 | #4853 | Link |
I've seen some people uses "--clusters-in-meta-seek --disable-track-statistics-tags --engage no_cue_duration --engage no_cue_relative_position" options to improve compatibility. What are the others pros and cons to allways use it ? Thank you ! |
7th September 2017, 19:14 | #4854 | Link |
https://github.com/mbunkus/mkvtoolni...y-with-players
If it adds data: more overhead. no_cue_duration/engage no_cue_relative_position: seeking into the middle of a subtitle line works in players that can make use of those (e.g. LAV/MPC-HC). |
7th September 2017, 20:04 | #4855 | Link |
When appending MKVs, MKVToolNix accounts for any existing audio/video delays or gaps etc and maintains sync, unless one of the MKVs being appended contains no audio at all.
For example, if you append three MKVs, and the second MKV contains no audio, in a perfect world it'd be treated as an audio gap and the video/audio sync for the third MKV being appended would be unaffected. What seems to happen though, is the audio in the third MKV is appended to the audio in the first MKV as though individual streams were being appended. I don't know if the same applies to subtitle streams. Is that a bug or intended behaviour? Cheers. PS. Keep in mind I'm using manolito's workaround with MKVToolNix version 15 (thanks manolito), given I'm running "no-ding" XP, although I doubt it's related to the problem.... |
7th September 2017, 22:15 | #4856 | Link | |
I don't know if I must use it or not, I can test my players now but in few months perhaps I'll use new devices so I can't know if these options will be supported... Difficult choice |
10th September 2017, 19:23 | #4857 | Link |
Hi Mosu
I have noticed that when I load a UHD-Bluray m2ts or mpls to MTX then all languages are well defined. In an older version of MTX all languages was set to "und". Have you improved your UHD-Bluray parser? Where you got this new infos? |
10th September 2017, 19:43 | #4858 | Link |
MKVToolNix author
I didn't really change anything regarding languages on Blu-rays. If the language is present in the MPLS/CLPI files, then it is used. Simple as that.
14th September 2017, 15:53 | #4859 | Link |
Hi Mosu
I have some questions about mpls. In the identify.json for all streams exists a "stream_id" with a number. This number seems to me not always match with the number in the mpls. Here is an example of the Terminator 2 Bluray. mpls 00018: there are 2 DTS-Express audio tracks and a second video track. Video 2: "stream_id": 6912 -> binary 1B 00 DTS 1: "stream_id": 6656 -> binary 1A 00 DTS 2: "stream_id": 6657 -> binary 1A 01 But I don't found this binary values in the mpls. Why is the order of the streams in MTX different to the order in the mpls? Best regards |
14th September 2017, 16:19 | #4860 | Link | |
MKVToolNix author
It's quite possible those streams are simply not listed in the MPLS.
