7th February 2018, 16:46 | #5081 | Link | |
Thanks again for your advice. |
10th February 2018, 15:54 | #5082 | Link |
Following what I wrote here:
https://forum.doom9.org/showthread.p...34#post1833334 I installed ffmpeg and tried this command: https://imgur.com/a/i5qY6 Is this correct? Either is taking too much time or it's stuck there. |
10th February 2018, 21:02 | #5083 | Link |
I have a few episodes in mkv file format that i want to remove the Japanese language audio from but i have noticed if i add the 10 or so files to MKVToolNIX GUI input window it just seems to output 1 large file and not there own separate files, how do i get MKVToolNix to output each files individually?
10th February 2018, 21:06 | #5084 | Link |
MKVToolNix author
Go to the "Preferences" → "Multiplexer" and set "When dropping files" to "Always ask the user". The drop the files & select the appropriate action from the dialog that'll pop up.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
10th February 2018, 21:24 | #5085 | Link | |
Each file lists... MPEG-4p10/AVC/h.264 AAC ENG AAC JPN SubRip/SRT Is there a way i can select 'AAC JPN' for removal for all the episode files in 1 go or do i have to click on each episode individually and remove the AAC JPN? Last edited by BlockABoots; 10th February 2018 at 21:27. |
10th February 2018, 21:33 | #5086 | Link |
MKVToolNix author
Well, on the shell (with "bash" or "zsh"; thinks will look differently with "cmd.exe" which I cannot help you with) you could do something like this:
for file in *.mkv ; do mkvmerge -o "out/$file" -a '!jpn' "$file" done If you don't get that to work, you can still deselect the Japanese tracks manually.
10th February 2018, 21:49 | #5087 | Link |
Yes that worked!, had to tick 'Video' and 'Subtitles' and then add 'English (eng)' to the 'selected' window. Then after that all files i added had the 'ACC JPN' line unticked. Thanks
10th February 2018, 21:56 | #5089 | Link |
MKVToolNix author
Why don't you have a look in the "Multiplexer" menu?
12th February 2018, 13:14 | #5093 | Link |
MKVToolNix author
That's called "splitting by parts" in MKVToolNix.
21st February 2018, 18:43 | #5095 | Link |
Regarding that problem where the output of mkvmerge -J is truncated after the first Unicode character when running MKVToolNix 14+ from a QProccess on MacOS, it was caused by LANG.
The problem specifically is that on MacOS LANG is not in the list of Qt system environment variables. Running printenv LANG on MacOS returns en_GB.UTF-8, so LANG is set on the system. However, if I print out the list of environment variables returned by the below, LANG isn't present on MacOS, though it is present on Linux. Code:
QProcessEnvironment::systemEnvironment().toStringList().join('\n') Two questions: 1) A since QProcessEnvironment::systemEnvironment() doesn't report LANG on MacOS there's no way to get the LANG for the system. I was therefore going to set LANG to en_US.UTF-8 on all systems. Would running MKVToolNix in en_US.UTF-8 create any problems on non-English systems? 2) Would you consider it an bug that LANG isn't present in the Qt systemEnvironment() on MacOS? If so I'll file a bug report with Qt. |
21st February 2018, 19:21 | #5096 | Link | |
MKVToolNix author
As UTF-8 is Unicode, output should work regardless of system language and content. I really couldn't say.
23rd February 2018, 00:33 | #5097 | Link |
Thanks for the new version 19 & 20.
Based on your release announcements, we knew that certain options and features would be retired (e.g., text options files, -I). So I was playing around and using the new -i. If I also use a -v for verbosity — it doesn’t seem to have an effect. Is there a valid use case for making -i -v kind of like the old -I. I can’t say I ever used the extra info from the old -I (e..g., private codec data). If that’s something you want to do one day, say as much and I’ll write it up. |
23rd February 2018, 07:13 | #5098 | Link |
MKVToolNix author
No. The old verbose identification format is gone for good. Use the JSON identification format instead. It contains all the information the verbose format did in a standardized format.
24th February 2018, 11:22 | #5099 | Link | |
MKVToolNix author
MKVToolNix v21.0.0 released
Hey everyone.
It's time for MKVToolNix v21.0.0. The biggest change is that mkvinfo's GUI portion has been removed. Its functionality is now incorporated into MKVToolNix GUI. I am aware that the functionatliy isn't on par yet, but it will be in time for release v22.0.0. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG and the source code. The Windows and macOS binaries are available already. The Linux binaries are still being built and will be available of the course of the next couple of hours. Here are the NEWS since the previous release: Quote:
