Old 16th October 2023, 20:07   #281  |  Link
szabi
Originally Posted by szabi View Post
This 7.1ch DD+ encoding does not developing quickly.
My first post near 6 years old asking it.
Hi
Since my previous ask now I am in the situation I would like to do it again.
Are there any move forward regarding 7.1ch DD+ encoding?
Regards
szabi
szabi is offline   Reply With Quote
Old 17th October 2023, 09:14   #282  |  Link
richardpl
Nope, as nobody come to sponsor such feature.
Old 17th October 2023, 20:00   #283  |  Link
szabi
My first question about it is 8 years old.
This is a said story.
Old 21st October 2023, 10:23   #284  |  Link
richardpl
It is not sad story when nobody comes around to sponsor additions and expect miracle happens.
There are no miracles.
Old 21st October 2023, 21:38   #285  |  Link
tebasuna51
tebasuna51's Avatar
If you want DD+ use any commercial encoder, if you want 7.1 with open encoders use OPUS, the quality/size is equivalent.
Old 22nd October 2023, 08:26   #286  |  Link
szabi
Unfortunately my home theater amplifier does not support OPUS.
Old 22nd October 2023, 13:32   #287  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
How about 7.1 channel LPCM or 7.1 channel Flac?
Out of interest... What's the make and model number of your AVR. And what playback device are you using to access your surround sound audio files?
Old 24th October 2023, 18:38   #288  |  Link
szabi
I would prefer dolby digital plus 7.1ch.
Old 2nd November 2023, 18:36   #289  |  Link
SquallMX
Special SeeD
If you want DD+ 7.1 just use Adobe Audition.
SquallMX is offline   Reply With Quote
Old 24th November 2023, 08:45   #290  |  Link
j7n
j7n's Avatar
Didn't Adobe remove all their Dolby encoders a couple years ago due to a major disagreement about licensing?
TotalCode seems to have most features exposed. It can do uncommon channel layouts such as Quad, disable the highpass filter, disable dynamic compression. The rear and side channels in 7.1 can be swapped in the GUI. DTS channel order is completely wrong, but AC-3 remapping from WAV order seems to happen within the encoder itself. It takes RF64 without DirectShow, which can be produced in Reaper. To access blu-ray disk encoding mode with an AC-3 core and bitrates over 1 Mbit, you have to pull a Blu-ray preset, and can then remove the video stream. In the normal mode the core is EC-3. The SRC has atrocious quality, and the inputs must be resampled to 48000 Hz if they are not already.
An older version of TotalCode 2.1.0 has impractical bitrates up to 3 Mbit, but only 5.1, and the other sampling frequencies selectable for regular AC-3, and a HD-DVD flavor of EC-3 with small frames. But it reads from DirectShow and may lose samples or quality.
Download the channel test in p=1963170
Almost no software of old vintage plays that. Yes, the latest and greatest 64-bit ffmpeg does. AAC wouldn't be my first choice for a surround format. AAC even has a weird default layout for 7.1.
j7n is offline   Reply With Quote
Old 24th November 2023, 11:21   #291  |  Link
tebasuna51
tebasuna51's Avatar
I tested Adobe Audition 2017 but also MainConcept TotalCode Studio v5.3.0 but is useless for me because my audio system is 3D 5.1.2 (L R C LFE Ls Rs Vhl Vhr), layout not present in TotalCode, and not the standard 2D 7.1 (L R C LFE Ls Rs Lrs Rrs)
Old 24th November 2023, 12:22   #292  |  Link
tormento
Acid fr0g
tormento's Avatar
Do you use DEE for that setup? What are the “switches” you touch?
@turment on Telegram
Old 24th November 2023, 12:53   #293  |  Link
tebasuna51
tebasuna51's Avatar
I test DEE v5.2.0 and only output the standard 2D 7.1 (L R C LFE Ls Rs Lrs Rrs) even if the input wav (RF64) file have a correct 3D 5.1.2 channel mask FL,FR,FC,LFE,SL,SR,TFL,TFR
Old 24th November 2023, 13:35   #294  |  Link
tormento
Acid fr0g
tormento's Avatar
So, what do you use?
Old 24th November 2023, 19:18   #295  |  Link
tebasuna51
tebasuna51's Avatar
If I want less size I use Audition 2017 to recode Atmos sources and I downmix standard 2D 7.1 to 5.1 and encode it to AAC without DN/DRC problems.
Old 24th November 2023, 21:02   #296  |  Link
tormento
Acid fr0g
tormento's Avatar
So no 5.1.2?
Old 24th November 2023, 23:24   #297  |  Link
tebasuna51
tebasuna51's Avatar
5.1.2 only from Atmos sources, I listen a mix of Side (90º) and Back (135º) in my Surround (120º) speakers, does not have sense use my Top Front speakers.
Old 25th November 2023, 03:15   #298  |  Link
j7n
j7n's Avatar
Looks like Audition 2017 is more complete and probably involves less hassle to prepare the input. I didn't know 5.1.2 layout existed in ec3.
Old 1st January 2024, 14:44   #299  |  Link
fla56
7.1 Windows hell...
hi buddy, did you ever get a chance to finish / release the Powerscript?
just going thru Windows 7.1 vs 5.1 transcode hell now, any help much appreciated
Originally Posted by Lollaskates View Post
The ffmpeg in the transcoder is old, and it doesn't decode dtshdma 7.1 . After testing of it's decoding and looking at the resulting audio, its only decoding 5.1 DTS core. This also means when plex thinks its transcoding DTSHDMA -> AAC 7.1, its actually taking 5.1 DTS and upmixing it to 7.1 (probably just copying the side channels to rear). Modern ffmpeg does decode DTSHDMA correctly, so to maintain all channels we can decode 7.1 dtshdma to FLAC or similar lossless with modern ffmpeg, then input the FLAC to Plex transcoder/eae to encode 7.1 EAC3.
eae doesn't seem to respect the bitrate you set with ffmpeg args, it'll always encode at 1024kbps. I'm looking into it too.
I've also written a windows equivalent in powershell (that accepts args) and has an accompanying batchfile with drag and drop functionality. It only works with audio: drop in audio and get out eac3 7.1. that's all I'd use it for, I'd use modern ffmpeg for any other operation. There's no need to pass the transcoder ffmpeg video related information, can just do simple audio conversion.
truehd_eae seemed to decode and produce the same file that modern ffmpeg decodes with its truehd codec, so no issue there. The only useful thing here imo is eac3_eae. After I polish up this powershell implementation i'll look into hooking it nicely into Staxrip or something for ease of use.
fla56 is offline   Reply With Quote
Old 4th August 2024, 22:26   #300  |  Link
BuccoBruce
I might be autistic...
Interesting that Dolby themselves don't offer 6.1 as an output option at all in DEE/DME, but I guess there really aren't any new 6.1 ES/EX mixes being created. That stanky old version of Audition is useful after all! I only kept it installed because I was too lazy to migrate all of my different effect and effects rack presets.
It works much the same as encoding to 7.1 does, including required channel remapping. Audition's DD+ export (incorrectly) assumes that the channel layout is 3/3 (L R C LFE Ls Rs Cs) whereas anything you import (FLAC with a plugin, WavPack with a plugin, WAV, etc) will all correctly assume L R C LFE Cb Ls Rs when decoded.
If you're using eac3to to decode your DTS-HD-MA-ES/TrueHD6.1 - make sure to add -0,1,2,3,5,6,4. This moves the extra (SPEAKER_BACK_CENTER) channel to where Audition's encoder is expecting it. If you forget, you can use the "channel mixer" effect in Audition, but it's slow and it will gobble up extra temp space because effects have to be applied to the file before you can export, at least in 2015.2.
The rest (bitrate, pre-processing, DRC, etc.) is up to you, but I only ever enable LFE Lowpass if it's needed since it does the filtering in parallel with the encode. 768k is probably overkill when an opus or AAC half the size would do, but at least I don't have to worry about my AVR or Windows or whatever screwing channel mapping up with bitstreamed DD+.
Hopefully this'll help anyone encoding the tiny amount of content out there with a discrete 6.1 mix.
BuccoBruce is offline   Reply With Quote
eac3
