Old 8th May 2019, 16:15   #56181  |  Link
chrisssj2
peak nits should be choicen on your display performance not the movie.
so no.
do you have tearing no? then Vsync is working. this doesn't need checking as long as it works.
yes it means a performance hit not sure if it is measurable.
yes Vsync should be who even gave you the idea that this may not be the case?
if you have problems you can try this option and it was needed in the past things changed.
RGB end of story if your screen can do it.
and this is the case with games too as long as the game is still rendered in 10 bit that's different from madVR where rendering in 8 bit is not rarely superior to 10 bit.
i don't care about some random reddit user that make a list same for AVS.
Ok so you saying so use RGB FULL 8 BIT@60 hz for SDR games and HDR games and SDR movies?
And then the RGB 12 BIT FULL @23 hz for HDR/MADVR movie playback?
Isn't it weird to use only 8 bits for HDR games?
chrisssj2 is offline   Reply With Quote
Old 8th May 2019, 19:07   #56182  |  Link
Asmodian
No, they dither too. 8 bit is much better than losing 1/3 of the video data (YCbCr 422) or running 30 Hz. Can you tell if the game is running in 8 or 10 bit? Of all the things you can sacrifice the bit depth has the least impact.
Have a third party randomly change it and then try to determin what the bit depth is, do you do better than 50:50?
madVR options explained
Old 8th May 2019, 22:48   #56183  |  Link
@chrisssj2 you don't need to quote an entire reply consisting of answers to your questions when you post. If there are many branches of conversation it can be useful to quote but there's no real need when the topic is focussed, it just wastes space on the forum, cheers.
Old 9th May 2019, 00:36   #56184  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by toki View Post
the first thing is to turn off Aquaman. that movie is so terrible!
It was a great movie, it had amber hurd.
Ghetto | 2500k 5Ghz
Old 9th May 2019, 14:29   #56185  |  Link
toki
I couldn't even finish it, it was that bad
toki is offline   Reply With Quote
Old 10th May 2019, 16:30   #56186  |  Link
SirMaster
Does anyone have much experience with the anamorphic lens option in madVR?
I am helping set up a new HTPC for a friend and we put in a RTX 2070. Anyways, with the settings we are using the render time is about 28-30ms which seems decent.
However, when I enable the anamorphic lens option, the render times go way up to 130-150ms!
Also, the anamorphic mode on his actual projector will stretch the content off the top and bottom edges of the screen (which is intentional). Like if it's a 16:9 native video and he wants to view it on his 2.40 screen, the 16:9 needs to be vertically stretched where the top and bottom get stretched off the screen. How can you do this with madVR anamorphic mode? I tried playing with the stretch numbers, but I can't get it to stretch the video vertically off the top and bottom of the screen. Maybe I have to use the "define visible screen area by cropping masked borders" feature?
I just assumed madVR would be really flexible with this sort of video manipulation, but I just can't seem to figure it out.
Anyone have any insights on either of these issues (the terrible anamorphic stretch performance) and (getting 16:9 content to vertically stretch)?
SirMaster is offline   Reply With Quote
Old 10th May 2019, 16:59   #56187  |  Link
a screen of the OSD should help but using a lens can increase render times heavily you have to do at least an extra scaling.
if you mean with stretching of the screen cropping you have to tell the player to do that that would be touch window from outside in MPC-HC no sure why someone would do something like that and removes big parts of movies but that'S how it is done.
Old 10th May 2019, 19:36   #56188  |  Link
el Filou
el Filou's Avatar
I think leeperry just raised this issue a few posts earlier: when using 'touch window from outside', image gets scaled to bigger than screen size and then displayed with areas outside the screen, which wastes GPU, instead of being pre-cropped then scaled to full screen.
Also, when using NGU in combination with anamorphic scaling you can possibly end up using two different scaling steps depending on how you configured NGU settings.
For example I get this with broadcast SD when scaling to FHD:
luma x: 720 > [NGU] 1440 > [selected upscaling algorithm] 1920
luma y: 576 > [NGU] 1152 < [selected downscaling algorithm] 1080
Even if I choose the exact same algo for both upscaling and downscaling in NGU config, e.g. Lanczos 3 AR, the OSD still shows two different scaling steps for x and y.
Old 10th May 2019, 19:42   #56189  |  Link
SirMaster
Yeah, I am getting 2 NGU steps, but I can't see how to avoid this.
Honestly I just want a simple scale for the stretch heh.
I can post my madVR settings and my OSD later tonight.
Old 10th May 2019, 20:28   #56190  |  Link
el Filou
el Filou's Avatar
I'm not sure it's two NGU steps, I think it doubles with NGU, then (for my example) upscales in the x direction with the upscale algo, then downscales in the y direction with the downscale algo, so 720x576 > 1440x1152 > 1920x1152 > 1920x1080
But I may be wrong. I'll check later with ShowRenderSteps.
Old 11th May 2019, 01:28   #56191  |  Link
@sirmaster. Plz don't quote entire lengthy posts directly above yours. You can edit them down or just not quote at all. Makes for a lot less wasted space on the forum, cheers.
Old 11th May 2019, 13:15   #56192  |  Link
Warner306
Try the playing with the zoom control settings. I know the two can interact, but I can't remember how the last person configured these settings to get all aspect ratios to fit. It might be possible to find past posts on this topic through Google. I think I was reading a post at the JRiver forums.
Old 11th May 2019, 19:04   #56193  |  Link
tp4tissue
tp4tissue's Avatar
Is there a way to change zoom percentage on MPCHC or Madvr ? for fine control ?
Ghetto | 2500k 5Ghz
Old 11th May 2019, 19:33   #56194  |  Link
numpad has the zoom control hotkeys. 9 is zoom in.
Old 12th May 2019, 00:42   #56195  |  Link
x7007
Careful with Nvidia 430.64
It revert output Dynamic Range to Limited everytime I turn my TV
x7007 is offline   Reply With Quote
Old 12th May 2019, 02:28   #56196  |  Link
SamuriHL
SamuriHL's Avatar
Alright, madvr, let's see what you got. I just upgraded my HTPC to a 9900k, 32 gigs of 3200 ddr4, and a founder's edition 2070. I'm tired of being on the edge of UHD playback. Now to re-tweak madvr after I get this clean driver install done and configured for these new 20xx cards.
Old 12th May 2019, 07:29   #56197  |  Link
chros
chros's Avatar
This is not an HTPC but a power plant!
Old 12th May 2019, 07:42   #56198  |  Link
Alexkral
Is there any way to use the Nvidia noise reduction with madVR? I'm fed up with the grain/noise added to some UHD videos. I've tried all the decoding options but it doesn't work. I'm testing the Gradual Denoise from ffdshow now, but the performance is not very good and produces some artifacts. Some other alternative?
Old 12th May 2019, 08:32   #56199  |  Link
svengun
I would like to know this as well
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build
svengun is offline   Reply With Quote
Old 12th May 2019, 08:38   #56200  |  Link
Asmodian
Have you tried madVR's?
There is no way to use Nvidia's but madVR's processing -> artifact removal -> reduce random noise on 2-4 works pretty well for me, on content with grain that bothers me.
