Old 23rd January 2009, 22:21   #681  |  Link
gizzin
Run-time error '383':'Text' property is read-only <-- I still get this error frequently. Every couple discs seems to be affected. The last disc I did didn't rebuild properly. It happened again finally.
gizzin is offline   Reply With Quote
Old 24th January 2009, 09:17   #682  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
About Run-time error '383':'Text' property is read-only, could you please be more specific? When does it happen? After a form opening, after a button click, after what event?
About log file you sent me, there is a authoring finalization error. The cause is exactly the same manolito pointed out some posts ago (bug in chapter generation when upsizing fps to NTSC and clip time is very near to a multiple of chapter interval).
I am fixing it and a 2.1.4 release will be out very soon. Please do not throw away the 1:25:00 time clip (title 2 of your log file), because it will be useful to verify the new chapter routine.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 24th January 2009, 10:15   #683  |  Link
Sharc
FPS upsizing is made by applying pulldown flags (DGPulldown is used), after raw video encoding is done. Audio does not have frames.
I see.
As I understand it, this means that we accept the pulldown judder and preserve the audio pitch, and keep the subs easily in sync.
With AssumeFPS(25) and resampling the audio we would avoid the judder but raise the audio pitch, and probably would have to change the time stamps of the subtitles.
It is eventually a matter of preference I guess.
Old 24th January 2009, 10:17   #684  |  Link
gizzin
I add 2 titles, If I highlight title 1, and edit that title, Then click next title in the edit screen, its spits out that error. However If I click edit title on the second title It doesn't seem to do that, I can go back and forth between the titles in the edit screen.
Old 24th January 2009, 16:17   #685  |  Link
leoliver
"Right now, you can avoid that problem by settings 999 mins in chapters interval: it means no chapters at all.
Remember that the bug happens only when the total time is equal to (a multiple of chapters interval) plus (a bunch of seconds)"
Yesterday I had a successfully run with AVStoDVD . It was the usual sort of video file I use : <1/22/2009 6:45:07 PM>
TITLE 1 SOURCE FILES
Video: C:\input\ Emperor.avi
Info: DivX 5 - 794 kbps - 672x272 - DAR 2.471 - 25 fps - PPF - 1:47:05 hours - 160625 frames
Audio: C:\input\ Emperor.avi
Info: MPEG-1 Audio layer 3 - 112 kbps - CBR - 48000Hz - 2ch - 1:47:04 hours
Subs:
[MediaInfoLib - v0.7.8] "
Except this time I used the default chapter creation setting of 5 mins. . And the chapter creation worked fine . After reading this reply :
" Remember that the bug happens only when the total time is equal to (a multiple of chapters interval) plus (a bunch of seconds"
I'll make sure that after all the chapters are created , that there aren't seconds left over to cause any MuxMan errors.
I also wanted to comment that before I ran the last encode job with AVStoDVD , I tried to run the same video file with Nero Vision Express 4 . And about 2 hrs. into the job , Nero Vision "froze up " and failed to finish the job. Then when I loaded the same video file into AVStoDVD , with 5 min. chapters ( no left over seconds after the last full chapter) , AVStoDVD successfully created another high quality DVD movie. So despite a few small bugs , I believe AVStoDVD is shaping up better than the bloated Nero Vision Express. And AVStoDVD certainly creates more readable log files than the log files created by Nero Vision .
Your Friend,
Larry
leoliver is offline   Reply With Quote
Old 24th January 2009, 19:44   #686  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@gizzin
I can't reproduce the error. If any other guy has that type of error, it is better if we continue via PM. Are you using any "unusual" settings (like tweaking AVStoDVD registry key)? Send me some screenshots of the error environment.
@leoliver
Thanks for the feedback. As you can see that clip (not downloaded illegally, I hope) has a duration NOT multiple of 5 minutes.
Bye
MrC
AVStoDVD Homepage
Old 25th January 2009, 16:14   #687  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ok guys, here you are a very small 2.1.4 Alpha release. It is just an update from 2.1.3. Unzip and overwrite the files in AVStoDVD folder.
Change log:
- Some bugs fixed (including the NTSC chapter generation, I hope )
- Changed WAV audio encoder: from 'FFMpeg r14277' to 'Wavi 1.06'
- Improved 'Save/Open Project' routines
- Improved 'Clip Preview' section GUI
Let me know
Bye
MrC
AVStoDVD Homepage
Old 25th January 2009, 16:25   #688  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
For anyone interested, here you are the new routine to create chapters framecount boundaries (MuxMan format). It is VB code, but simple enough to be read by everybody that knows the programming basics:
    FPS = 25
    If Settings.VideoStandard = "NTSC" Then FPS = 2997 / 100
    If Val(Settings.ChaptersInterval) * 60 < Title.TimeTrimmed Then
        Do
            jj = jj + 1
            FrameChapter = Val(Settings.ChaptersInterval) * jj * 60 * Round(FPS)
            If FrameChapter < Title.TimeTrimmed * FPS Then
                Create_Chapters_List = Create_Chapters_List & FrameChapter & vbCrLf
            End If
        Loop Until FrameChapter > Title.TimeTrimmed * FPS
        If Right(Create_Chapters_List, 2) = vbCrLf Then
            Create_Chapters_List = Left(Create_Chapters_List, Len(Create_Chapters_List) - 2)
        End If
    End If
Bye
MrC
AVStoDVD Homepage
Old 27th January 2009, 03:55   #689  |  Link
leoliver
Today I used the new 2.1.4 Alpha release with success. It encoded a 700 MB. file in a little over 2 hrs. The last AVStoDVD job, done with release 2.1.3 took almost 3.5 hrs. . And that job was with another 700 MB. AVI file. However with the 2.1.4 Alpha release job , I didn't use FFDShow which may have speed-ed up the job.
If anyone needs a source of free, legal audio/video downloads , check out : NewTeeVee » Ten Sites for Free and Legal Torrents . The videos on those sites are not new Hollywood releases , but many are very good movies .
Your Friend,
Larry
Old 3rd February 2009, 03:53   #690  |  Link
leoliver
Error when I try and use the Fire Web menu template
Today I decided to use the "Fire Web" DVD menu template.
But after selecting that template , and then clicking on the "Menu Edit" button , I received this error message :
" Run-time error:'308'
Invalid property value "
And after the error message AVStoDVD shut down , requiring me to restart the program and selecting another DVD menu template . And all the other DVD menu templates work just fine. The only problem is with the "Fire Web" template.
So I thought I would bring this issue to your attention.
Your Friend,
Larry
Old 3rd February 2009, 08:47   #691  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks leoliver for the bug report.
The reason could be that the Fire Web template requires truetype font "Garamond" to be installed on your system.
In 2.1.4 final I will add a font check routine to prevent those errors.
Bye
MrC
AVStoDVD Homepage
Old 3rd February 2009, 16:52   #692  |  Link
leoliver
Bye
I checked my Font folder for "Garamond" , and it was not installed on my system . So that must have been the cause of the error.
Your Friend,
Larry
Old 8th February 2009, 18:04   #693  |  Link
gizzin
I love this piece of software. It just gets better and better with each revision. And the quality top notch (HC and Aften). Good work MR.C. Don't use inferior software (convertx).
Old 9th February 2009, 17:32   #694  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.1.4 is out.
Change log:
- Some bugs fixed
- Added support to VCD resolutions (PAL 352x288, NTSC 352x240)
- Revised (and fixed) SubtitleCreator profiles
- Changed 'Video Lower Avg BitRate' min value in 'Settings'/'AudioVideo': from 1000 kbps to 500 kbps
- Changed 'Fire Web' font: from 'Garamond' to 'Times New Roman'
- Improved 'Keep DVD compliant Video/Audio' routines
- MediaInfo updated to 0.7.10
- HelpMaker (software used to create Help Section) updated to 7.4.4.0
In italic changes from 2.1.4 Alpha. No big news, just some polishing.
Bye
MrC
AVStoDVD Homepage
Old 10th February 2009, 16:11   #695  |  Link
PINOBIRD
First of all thanks for this wonderfull app.
Last night I did some testing and I downloaded some of these files.
AVS2DVD won't create a DVD it even won't encode these files.
Maybe it's caused by the low framerate of these files.
PINOBIRD is offline   Reply With Quote
Old 10th February 2009, 19:08   #696  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi Pinobird,
they are standard low res wmv files, there's no reason that AVStoDVD cannot encode them. Could you please be more specific about the error? Screenshots and/or log files would be useful
Bye
MrC
AVStoDVD Homepage
Old 10th February 2009, 19:41   #697  |  Link
PINOBIRD
<10-2-2009 19:35:27>
START PROCESS
DVD SETTINGS
DVD Titles number: 1
DVD Video Standard: PAL
DVD Chapters Interval: 5 min
DVD Menu: Static DVD Menu
DVD Size: 220/4435 MB (5%)
DVD Output Setup: DVD Folder
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Save Log file: Yes
Output Folder: H:\DVD Output
Video: I:\WM Recorder\ediustuts\05 Deck Settings - DSL.wmv
Info: WMV3 - 314 kbps - 480x360 - DAR 1,333 - 15 fps - PPF - 3:29 minutes - 3144 frames
Audio: I:\WM Recorder\ediustuts\05 Deck Settings - DSL.wmv
Info: WMA2 - 32 kbps - CBR - 32000Hz - 2ch - 3:29 minutes
Subs:
[MediaInfoLib - v0.7.10]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("I:\WM Recorder\ediustuts\05 Deck Settings - DSL.wmv", CacheFolder = "D:\!Systeem\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,576)
Audio = A2DAudioSource("I:\WM Recorder\ediustuts\05 Deck Settings - DSL.wmv", CacheFolder = "D:\!Systeem\Temp")
Audio = Audio.SSRC(48000)
AudioDub(Video, Audio)
<10-2-2009 19:35:39>
Encoding Profile: HCenc OPV 1-pass
Target Video FileSize: 212,8 MB
HCenc Parameters: -ini "D:\!Systeem\Temp\05 Deck Settings - DSL_0_Title_01.HCenc.ini"
HCenc ini file:
*INFILE D:\!Systeem\Temp\05 Deck Settings - DSL_0_Title_01.avs
*AVSRELOAD
*OUTFILE H:\DVD Output\05 Deck Settings - DSL_0_Title_01.m2v
*LOGFILE D:\!Systeem\Temp\05 Deck Settings - DSL_0_Title_01.HCenc.log
*MAXBITRATE 9000
*CQ_MAXBITRATE 1
*BITRATE 8500
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*BIAS 80
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<10-2-2009 19:36:41>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <H:\DVD OUTPUT\05 DECK SETTINGS - DSL_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.1.4
HCEncoder says ERROR, invalid MPEG2 framerate
Old 10th February 2009, 21:19   #698  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Nasty wmv files! I really hate them!
Go to 'Title Edit'/'AviSynth', toggle off 'Auto AviSynth Script', replace "#Using DGPulldown to upsize FPS" with "Video = Video.ConvertFPS(25)".
It should work
Bye
MrC
AVStoDVD Homepage
Old 11th February 2009, 07:45   #699  |  Link
PINOBIRD
Works like a charm.
Old 14th February 2009, 02:42   #700  |  Link
Milardo
Cool! Thanks for the bitrate and video size features. Can't wait for the custom chapter points feature. By the way, does AVStoDVD support either having motion backgrounds with music/motion title buttons (where you see a preview video of the chapter/title you can select)? Just trying to get clarification on that.
Milardo is offline   Reply With Quote
[IMG] code is Off
