25th April 2016, 19:23 | #1481 | Link |
It can be represented in ANSI charset and therefore should work with AviSynth (which don't support Unicode), if you like you can post a sample to the StaxRip thread.
25th April 2016, 19:32 | #1482 | Link |
Indeed there is: http://forum.doom9.org/showthread.ph...55#post1733655
25th April 2016, 19:38 | #1483 | Link | |
Please, DeInterlace me!
Now it works! Thanks for all folks!
Who am I?! I'm GOD... 8for it... father of my godchilds. |
25th April 2016, 19:43 | #1485 | Link |
25th April 2016, 20:25 | #1486 | Link |
Hi pinterf!
I get error Code:
--------------------------- VirtualDub Error --------------------------- Avisynth read error: CAVIStreamSynth: System exception - Access Violation at 0xae1fc65 --------------------------- ОК --------------------------- If I comment line with Colormatrix a get other message Code:
--------------------------- VirtualDub Error --------------------------- Out of memory (unable to allocate 7116224 bytes) --------------------------- ОК --------------------------- |
25th April 2016, 21:48 | #1487 | Link | |
If it works, then one of the filters possibly cannot run in mode 2, only mode 3, (this is serialized mode). Edit: For me it works from avsmeter, though max memory consumption is 1860MB (see when set memory max to 2400). YUY2 conversion inside QTGMC is eating a lot of memory, and speed. Using SetMemoryMax(1536) it really uses around 1500M but it's not optimal. Last edited by pinterf; 26th April 2016 at 13:21. Reason: more testing |
26th April 2016, 13:32 | #1490 | Link |
The profile editor supports multiline:
parentMenu | profileName = Loadplugin("C:\Portable Apps\StaxRip\Apps\Plugins\avs\MSharpen\msharpen.dll") MSharpen(threshold = 10, strength=100, highq=true, mask=false)
26th April 2016, 13:42 | #1491 | Link |
@yup
This is my script that worked. I had no YUY2 source so I converted to YUY2 right after the source filter. Code:
SetMemoryMax(2400) # or SetMemoryMax(1536) SetFilterMTMode("DEFAULT_MT_MODE",2) SetFilterMTMode("AviSource",3) Edibob=Avisource("dv_avi_sd_test.avi").ConvertToYUY2() #Edibob=AVISource("pre14last.avi")## source YUY2 50 fps bobbed Edibob=Edibob.AssumeTFF() Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, Edithreads=1, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5) nnedi3_rpow2(rfactor=2,nns=2, qual=1, fwidth=1004, fheight=752,cshift="Spline36Resize").Crop(22,16,-22,-16) unsharp(varY=465,varC=232,strength=0.3,U=3,V=3) ConvertToYV12(interlaced=false) ColorMatrix(mode="Rec.601->Rec.709") Prefetch(8) Code:
AVSMeter 2.2.2 (x86) AviSynth+ 0.1 (r1849, MT-pfmod, i386) (0.1.0.0) Number of frames: 139381 Length (hh:mm:ss.ms): 01:32:55.240 Frame width: 960 Frame height: 720 Framerate: 25.000 (25/1) Colorspace: YV12 Frame (current | last): 3349 | 139380 FPS (cur | min | max | avg): 21.09 | 9.361 | 26.31 | 18.52 Memory usage (phys | virt): 1868 | 1894 MiB Thread count: 67 CPU usage (current | average): 87% | 89% Code:
Edibob=Avisource("dv_avi_sd_test.avi").ConvertToYUY2().ConvertToYV12() Code:
AVSMeter 2.2.2 (x86) AviSynth+ 0.1 (r1849, MT-pfmod, i386) (0.1.0.0) Number of frames: 139381 Length (hh:mm:ss.ms): 01:32:55.240 Frame width: 960 Frame height: 720 Framerate: 25.000 (25/1) Colorspace: YV12 Frames processed: 3320 (0 - 3319) FPS (min | max | average): 5.220 | 52.07 | 31.33 Memory usage (phys | virt): 824 | 844 MiB Thread count: 69 CPU usage (average): 91% It will continously shrink the memory demand, less caching, thus the speed is lower (13.6 vs 18.5 fps) compared to the non-memory limiting version. Code:
AVSMeter 2.2.2 (x86) AviSynth+ 0.1 (r1849, MT-pfmod, i386) (0.1.0.0) Number of frames: 139381 Length (hh:mm:ss.ms): 01:32:55.240 Frame width: 960 Frame height: 720 Framerate: 25.000 (25/1) Colorspace: YV12 Frames processed: 3270 (0 - 3269) FPS (min | max | average): 7.503 | 18.69 | 13.63 Memory usage (phys | virt): 1212 | 1250 MiB Thread count: 67 CPU usage (average): 75% - SetMemoryMax as we can see is not a 100% limit, setting it to 1000 still uses 1000-1200 MB, minor overshoot is possible. - Seems that YUY2 is not the optimal format for processing |
26th April 2016, 16:42 | #1492 | Link |
Excessively jovial fellow
It's the standard Avisynth thing. It didn't support Unicode in 2001, everything must be backwards compatible all the way to 2001 and therefore you can't ever change anything, or if you do you have to jump through a bunch of hoops to make it backwards compatible which makes it so complex that it never gets done. It's not a huge deal, just another one of the countless minor irritations about it. Most people just rename their files if they need to.
27th April 2016, 00:30 | #1493 | Link | |
1- more data than yv12 2- processing hack (Interleaved to Planar or reverse) if we have yv16 support for all filters it will be faster and less memory processing
See My Avisynth Stuff Last edited by real.finder; 27th April 2016 at 00:49. |
27th April 2016, 19:52 | #1494 | Link |
pinterf!
Increasing SetMemoryMax increase fps, when using avsmeter, but during open in VirtualDub I get error, also I am try using ffmpeg for conversion to AVI I see frame with green and pink bars. All problem gone when Prefetch place after QTGMC call, may be unsharp (when I am replaced nnedi3_rpow2 and unsharp), but not lower (appear color bars in output video). Folowing script work fine in VirtualDub Code:
SetMemoryMax(2400) # or SetMemoryMax(1536) SetFilterMTMode("DEFAULT_MT_MODE",2) SetFilterMTMode("AviSource",3) Edibob=AVISource("pre14last.avi")#.ConvertToYV12(interlaced=false) #.Trim(0,10000) Edibob=Edibob.AssumeTFF() Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5) #QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, Edithreads=1, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5) unsharp(varY=310,varC=155,strength=0.15,U=3,V=3) #unsharp(varY=465,varC=232,strength=0.3,U=3,V=3) ConvertToYV16(interlaced=false) Prefetch(8) nnedi3_rpow2(rfactor=2,nns=2, qual=1, fwidth=1004, fheight=752,cshift="Spline36Resize").Crop(22,16,-22,-16) #unsharp(varY=465,varC=232,strength=0.3,U=3,V=3) ConvertToYV12(interlaced=false) ColorMatrix(mode="Rec.601->Rec.709") #Prefetch(8) yup. |
27th April 2016, 21:21 | #1495 | Link |
Prefetch must be placed at the end of the script.
Also, make sure the latest version of the MT modes .avsi file (linked to from here) is in the plugin autoload directory. |
2nd May 2016, 07:44 | #1499 | Link |
Soul Architect
OK I'm doing some tests with AVS+.
Here's my script. Code:
P="Encoder\" LoadPlugin(P+"LSMASHSource.dll") LoadPlugin(P+"KNLMeansCL.dll") LoadPlugin(P+"Shaders\Shader.dll") Import(P+"Shaders\Shader.avsi") LoadPlugin(P+"nnedi3.dll") LoadPlugin(P+"FTurn.dll") Import(P+"edi_rpow2.avsi") LoadPlugin(P+"svpflow1.dll") LoadPlugin(P+"svpflow2.dll") Import(P+"InterFrame2.avsi") Import(P+"ResizeX.avsi") SetFilterMTMode("DEFAULT_MT_MODE",2) SetFilterMTMode("LWLibavVideoSource",3) SetFilterMTMode("LWLibavAudioSource",3) SetFilterMTMode("KNLMeansCL",3) #SetMTMode(3,8) file="F:\NaturalGrounding\2002 Rahtree\Original\Meu-Ayw-Tua-Lae-Tur.mpg" LWLibavVideoSource(file, cache=false, threads=1) AudioDub(LWLibavAudioSource(file, cache=false)) Crop(0, 0, -8, -0) ConvertToYV24() #SetMTMode(5) KNLMeansCL(D=1, A=2, h=2.1, cmode=true, device_type="GPU", device_id=0) #SetMTMode(2) ConvertToYV12() SuperRes(2, 0.6, 0, """edi_rpow2(2, nns=4, cshift="Spline16Resize", Threads=2)""", MatrixIn="601") InterFrame(Cores=8, Tuning="Smooth", NewNum=60, NewDen=1, GPU=true) SuperRes(2, 0.6, 0, """edi_rpow2(2, nns=4, cshift="Bicubic", a1=0, a2=.75, fWidth=1012, fHeight=778, Threads=2)""") ResizeX(1004, 768, 0, 5, -8, -5, kernel="Bicubic", a1=0, a2=.75) Prefetch(8) Code:
AVSMeter 2.1.6 (x86) AviSynth 2.60, build:Feb 20 2015 [03:16:45] (2.6.0.5) Number of frames: 13726 Length (hh:mm:ss.ms): 00:03:48.767 Frame width: 1004 Frame height: 768 Framerate: 60.000 (60/1) Colorspace: YV12 Active MT Mode: 2 Frames processed: 338 (0 - 337) FPS (min | max | average): 2.133 | 1000000 | 10.07 Memory usage (phys | virt): 885 | 1236 MB Thread count: 311 CPU usage (average): 37% Time (elapsed): 00:00:33.563 Code:
AVSMeter 2.1.6 (x86) AviSynth+ 0.1 (r1847, MT-pfmod, i386) (0.1.0.0) Number of frames: 13726 Length (hh:mm:ss.ms): 00:03:48.767 Frame width: 1004 Frame height: 768 Framerate: 60.000 (60/1) Colorspace: YV12 Frames processed: 508 (0 - 507) FPS (min | max | average): 1.103 | 1000000 | 8.148 Memory usage (phys | virt): 738 | 1109 MB Thread count: 345 CPU usage (average): 41% Time (elapsed): 00:01:02.344 |
2nd May 2016, 07:58 | #1500 | Link |
Soul Architect
I also tried replacing KNLMeansCL with xNLMeans.
Documentation says: "XNLMeans is a MT_NICE_FILTER for Avisynth_MT or Avisynth+, but without SIMD instructions or GPU acceleration." This works Code:
SetFilterMTMode("xNLMeans",2) Code:
SetFilterMTMode("xNLMeans",1) |
