10th December 2004, 23:30 | #102 | Link |
AviSynth plugger
Recently I developed first beta (alpha) version of MVtools to Depan interface, as MVDepan function of MVTools.
The global motion extraction algorithm is still not very clever and robust in this version, but it works as idea. But it can estimate rotation too. Try latest version on MVTools 0.9.8.2 and above http://forum.doom9.org/showthread.ph...0&pagenumber=3
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
15th December 2004, 20:01 | #103 | Link |
AviSynth plugger
Version 1.1.4, December 15, 2004 - damping parameter in DePanStabilize is now variable (was accidentally fixed =0.9 in all previous versions
1st January 2005, 16:05 | #104 | Link |
AviSynth plugger
Version 1.1.5, December 31, 2004 - bug fixed in DepanEstimate (erroneous motion data) for fftw=true with show=false and info=false
I really wander why it bug was not fond before (it present since v.1.1) Happy Mew Year!
3rd March 2005, 08:33 | #106 | Link |
Hello Fizick,
Excellent work on a wonderful plugin! I do have but one problem, it may be due to my own stupidity though. Glabally speaking, if I use mdata = DePanEstimate(range = 4, trust=5, dxmax=8, dymax=8, improve=true, fftw=true) DePanStabilize(data=mdata, dxmax=8, dymax=8, prev=1, next=1, info=false, cutoff=0.5) I still obtain black bars where the panning occurs. Would this be because I've limted the dx and dy? I'd really like to remove the black bars if possible. Thanks nmap |
4th March 2005, 05:40 | #108 | Link |
AviSynth plugger
nmap,
it is most hard question, we do no know what must be in place of black borders. try use "addzoom", and "mirror" to fill it. I often use use greater "cutoff" = 2.0 Note. The used values of dxmax and dymax are too low, try defaults. Lucky depaning!
29th April 2005, 22:11 | #109 | Link |
AviSynth plugger
Version 1.2, April 1, 2005 - added fitlast parameter to fit some last frames range to original position
Version 1.3, April 29, 2005 - added blur parameter to somewhat hide the sharp mirrored details; blur is horizontal only, at left and right border.
29th May 2005, 16:20 | #110 | Link |
AviSynth plugger
Version 1.4, May 7, 2005 (published May 29)- DePanStabilize: Zoom adaptive mode addzoom is improved. Adaptive zoom decreasing rate is slower than zoom increasing rate now. Thus, the black empty borders are decreased, and zoom value is more stable now.
30th May 2005, 23:38 | #111 | Link |
and now the WWW button is... unvisible!
31st May 2005, 03:46 | #112 | Link | |
31st May 2005, 05:46 | #113 | Link |
AviSynth plugger
Yes, this is a great forum enhancement.
BTW, DePab version 1.4.1 released (bug fixed with log)
6th June 2005, 03:00 | #114 | Link |
AMD fan
There is new version DePan v.1.5 - Stabilizer adaptive zoom mode improved more.
Thanks to Fizick for regular improve! |
23rd June 2005, 19:22 | #116 | Link |
AviSynth plugger
J%J,
Did you try MVDePan? http://forum.doom9.org/showthread.ph...027#post580027 Hm, I now found that MVDePan info is missed from Depan 1.5 English doc after edition So, i restore it and relese a new 1.5.0 zip archive (the same binary DLL).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 23rd June 2005 at 19:31. |
26th June 2005, 13:37 | #117 | Link |
Wow, MVDepan can work!
But I can't get the stable outcome as Deshake. My Avs : LoadPlugin("C:\Program Files\GordianKnot\AviSynthPlugins\deflicker.dll") LoadPlugin("C:\Program Files\GordianKnot\AviSynthPlugins\depan.dll") LoadPlugin("C:\Program Files\GordianKnot\AviSynthPlugins\MV\MVTools.dll") sourcefile="CIMG0297" BaseLayer=DirectShowSource(sourcefile+".avi",fps=29.970).AddBorders(96,96,96,96) vectors = BaseLayer.MVAnalyse(isb = false,lambda=40000) globalmotion = BaseLayer.MVDepan(vectors, pixaspect=1, thSCD1=40000,thSCD2=40000,zoom = false,error =90) Midway=DepanStabilize(BaseLayer, data=globalmotion, cutoff=2.0, mirror=0, pixaspect=1).deflicker(percent=99,scene=25) Return(Midway) Thanks for your answering..... |
29th June 2005, 08:21 | #118 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Thank you, Fizick Thank you, Manao I must do many more tests, but it seems to be a huge improvement. But I have noticed the rotation estimation is not 100%. (sometimes in the wrong direction.) Also, on scenes with very fast moving objects and fast panning at the same time sometimes there is a jump in time beween two frames. But this is easy to solve with very low thSCD1 parameter. But then stabilising is not so good anymore. Yes, Deshaker is still a little better, but needs two passes. On the other hand, too much stabilising looks artificial sometimes, and you get lots of blurred frames. Resumed: I am verry happy with MVDepan, I think I'm gonna use it on all my files in the future. But if someone has a better solution for the time-jump between frames, I would be even more happy. Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
29th June 2005, 21:14 | #119 | Link | |
AviSynth plugger
30th June 2005, 06:38 | #120 | Link | |
You made it.. You know it. But movement is smoother with MVDepan, then why? Fred.
